Fiber optic guide for nav lights
Old December 7th 05, 09:57 PM posted to rec.aviation.homebuilt
Default Fiber optic guide for nav lights
I was wondering if anyone has considered using a lightpipe or
fiberoptic bundle for nav lights. I am considering it for the rear nav
light (white) on my Europa. Is it feasible? Anyone know where I can buy
these lightpipes?
Old December 7th 05, 11:33 PM posted to rec.aviation.homebuilt
I should clarify. I don't mean the small acrylic stub on Cessna wings
that lets you see the nav light from the cockpit. What I mean is a
lightpipe to send the light from an LED illuminator lcoated inside the
fuselage to the tip of the rudder (or wings).
Old December 8th 05, 10:51 PM posted to rec.aviation.homebuilt
fuselage to the tip of the rudder (or wings).\
I don't see the advantage of doing what you are proposing.
The typical nav LED nav light has a cluster of several LED's, both for
pattern, and for brightness. I don't believe you could get the necessary
brightness for one location, let alone multiple locations, using a single
LED, or even a couple.
Even if you clustered the LED's at a central location, and piped them out to
the remote locations using fiber optics, do you think the weight or
complexity would be less? I can't imagine how. You might need lenses to
correctly distibute the light also, which would not be needed with the LED's
out at the locations.
Panel Lights - Need Help Barnyard BOb - Home Built 2 May 29th 04 07:51 PM
Anti collision light mod for Piper Arrow 1968 model? Frode Berg Owning 4 May 20th 04 05:16 AM
Building chasing airport lights -- Attn: Jim Weir? Jay Honeck Owning 79 February 29th 04 02:10 PM
