Flying through known or forecast icing
Old December 14th 05, 09:35 PM posted to rec.aviation.ifr,rec.aviation.piloting
Default Flying through known or forecast icing
No, the prohibition is in the FARs--specifically, 91.527, quoted in my
previous note in this thread.
That applies only to "large or turbine powered multi-engine" aircraft.
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Old December 14th 05, 09:23 PM posted to rec.aviation.ifr,rec.aviation.piloting
: No. Legally, forecast ice is "known icing."
Not to tangent too much, but doesn't that regulation regarding "prohibited
flight into known icing conditions" without certified de-ice equipment
loophole old
planes? I seem to recall something about if the POH for the aircraft does
not say the
magic words, "Flight into icing conditions prohibited," then it's not
illegal.
Certainly not a good idea and guaranteed to bite you on "careless and
wreckless" if
something happens, but strictly speaking not immediately illegal.
No, there isn't any such loophole in the wording of the FARs: "91.527(b)
Except for an airplane that has ice protection provisions that meet the
requirements in section 34 of Special Federal Aviation Regulation No. 23, or
those for transport category airplane type certification, no pilot may
fly-(1) Under IFR into known or forecast moderate icing conditions; or (2)
Under VFR into known light or moderate icing conditions unless the aircraft
has functioning de-icing or anti-icing equipment...".
Notice that there is an explicit prohibition against flying into *known or
forecast* moderate icing conditions (that's under IFR; under VFR, the
prohibition applies to known (not forecast) light or moderate icing).
There is an exception though: "91.527(d) If current weather reports and
briefing information relied upon by the pilot in command indicate that the
forecast icing conditions that would otherwise prohibit the flight will not
be encountered during the flight because of changed weather conditions since
the forecast, the restrictions in paragraphs (b) and (c) of this section
based on forecast conditions do not apply".
So if there's a forecast for icing, but other evidence (such as PIREPs)
indicates that the predicted icing conditions have not come about, then the
forecast becomes moot. But a mere absence of PIREPs (or other evidence)
leaves the forecast-based prohibition intact--to override the forecast, you
need evidence of non-icing conditions, not just non-evidence of icing
conditions.
--Gary
Old December 14th 05, 09:39 PM posted to rec.aviation.ifr,rec.aviation.piloting
Sorry Garry...91.527 doesn't apply unless you are flying a large or
turbine powered aircraft.
Old December 14th 05, 09:44 PM posted to rec.aviation.ifr,rec.aviation.piloting
Sorry Gary...91.527 doesn't apply unless you are flying a large or
Oops, my mistake. Thanks for the correction.
--Gary
Old December 14th 05, 10:47 PM posted to rec.aviation.ifr,rec.aviation.piloting
According to Scott Dennstaedt's article in the latest IFR magazine, we won't
be seeing Airmets (or Area Forecasts) after early 2006. Better graphic
displays will take their place. Big plus is that the forecast area is more
precisely defined in both scope and time.
Bob Gardner
loophole old
not say the
illegal.
wreckless" if
With the scAIRMETS for icing constituting "known-icing" everywhere north
of
the Carolinas for significant chunks out of the year, most GA planes are
operating
illegally.
-Cory
* Cory Papenfuss *
Old December 15th 05, 07:00 AM posted to rec.aviation.ifr,rec.aviation.piloting
The general icing AIRMET always contains the qualifier "in clouds and
precipitation". You're perfectly legal if you stay out of the clouds
and precipitation.
Old December 16th 05, 02:43 AM posted to rec.aviation.ifr,rec.aviation.piloting
On Wed, 14 Dec 2005 16:33:31 GMT, George Patterson
John Doe wrote:
1) If the cloud layer is forecast to potentially have icing, can you legally
and would you climb through the layer to get up high for your trip? how
thick a layer, type of forecast, time spent in the layer, etc. What would
you be willing to risk transition through possible icing?
A bit of a distortion.
The phrase in the regulations is "known icing conditions". A forecast that
mentions icing satisfies this as the conditions (leading to potential) icing
are indeed known -- if you have read the forecast -- and you are required by
regulations to obtain all relevant information for the flight which includes
a weather forecast.
Many pilots try to parse the requirement as "known-icing conditions" whereas
the FAA has defined it to mean "known icing-conditions" -- a subtle but
inportant difference when it comes to defending oneself against a
certificate action. A forecast of icing constitutes "known
icing-conditions."
4) Let's say yoru trip starts off VFR but by the time you get to your
destination, a cloud layer has formed that has reported icing in it. Can or
or would you be willing to transit this layer to land at this destionation
or would you turn around or divert to land someplace to stay out of the
clouds?
If I want to stay VFR, I won't be transiting any clouds. Being unwilling to risk
a violation if I file IFR and then fly through reported icing, I would divert.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Jay.
(remove dashes for legal email address)
Old December 16th 05, 03:02 AM posted to rec.aviation.ifr,rec.aviation.piloting
"Jay Somerset" wrote in message
that
icing
by
includes
a weather forecast.
whereas
icing-conditions."
What you say appears to have been true in the past, but not currently. As
noted earlier in this thread, the FAA now defines the terms as follows:
"Forecast Icing Conditions--Environmental conditions expected by a National
Weather Service or an FAA-approved weather provider to be conducive to the
formation of in-flight icing on aircraft."
"Known Icing Conditions--Atmospheric conditions in which the formation of
ice is observed or detected in flight."
(AIM 7-1-23, http://www.faa.gov/atpubs/aim/Chap7/aim0701.html#7-1-23)
--Gary
Have you ever... Jay Honeck Piloting 229 May 6th 05 08:26 PM
Known Icing requirements Jeffrey Ross Owning 1 November 20th 04 03:01 AM
Interesting. Life history of John Lear (Bill's son) Big John Piloting 7 September 20th 04 05:24 PM
Wife agrees to go flying Corky Scott Piloting 29 October 2nd 03 06:55 PM
