Another Cirrus Down
Old December 19th 05, 08:53 PM posted to rec.aviation.student,rec.aviation.piloting
Default Another Cirrus Down
Yes, in fact there is a lot more information now concerning car crashes
being given to Firefighters. Apparently, in addition to the risk of
undeployed airbags, suspension struts are now considered highly
dangerous to Firefighters. There have been several documented cases in
which a car, on fire, as released its struct at a very high velocity.
Apparently it can easily cut a hole in a firetruck. Fireflighters die
trying to rescue people from their burnnig cars more often than people
realize.
-Robert
Old December 20th 05, 04:10 AM posted to rec.aviation.student,rec.aviation.piloting
Apparently the pressure is building...
It is an expensive unit, and some people are getting upset..
The magnets are very difficult to remove, Garmen has made it
abundantly clear that this will void the warranty, and have no
interest in exchanging it for one without magnets, which of course
they don't make ..
Or something like that...
WHAT were they thinking? (or were they) Surprising from a company with
long experience in aviation GPS units....
Dave
On Sun, 18 Dec 2005 23:59:14 -0500, "Morgans"
I predict that Garmin will finally give in and make a new type of antenna.
(I hope)
Old December 20th 05, 04:18 AM posted to rec.aviation.student,rec.aviation.piloting
Morgans wrote:
"Dave" wrote\
And in an aircraft that was not engineered to willingly assist the
pilot to maintain, recover to, and sustain controlled flight..
I'm not sure if that is the whole picture. The Cirrus was not certified for
spin resistance and recovery because it would have been so expensive to do
so, up to the FAA's standards. That is not to say that it would not meet
them, if they tried to do so.
Simply put, they took the cheap way out, with the *added* benefit of another
mode of recovery for other types of situations, such as pilot
incompacitation, loss of flight controls, loss of power over inhospitable
terrain...
It was cheaper to design, test and certify a BRS than it was to take
the plane up and do a couple of spins? I think not. The CAPS tests
themselves required the destruction of at least one airframe. Spin
testing just has to show recovery after a couple times around.
The reason the Cirrus was not spin tested is because it is very stall
resistant. Any maneuver that could throw this plane into a spin might
be so violent as to be unrecoverable. There have been accidents
attributed to people trying deliberately to spin the Cirrus. There is
no reason to attempt to spin the airplane anyway. It is unlikely to
enter a spin accidentally, so it is not as if it is a needed emergency
procedure.
Some people claim the airplane will successfully recover from at least
an initial spin. Fine. But why bother? Cirrus strongly discourages it.
It is not really certified for it. There is no training advantage to
it. If I want to do spins then give me an airplane where they will be
fun; even Aerobat. Doing spins in a Cirrus would be like doing
motocross in a Ferrari.
Old December 20th 05, 06:25 AM posted to rec.aviation.student,rec.aviation.piloting
Myself, I don't think it is too surprising.
You have the hardware gurus with the aviation permanent mount receiver
department. Then you have the hardware guys for the handheld units. Lots
of difference in the hardware, most likely different people. The software
is the most common thing between the two, but the software people don't care
what is running it, as long as the unit is capable of running it, which is
what the hardware guys can tell them.
The aviation guys know what they have to have for permanent mount antennae
on airplanes. No magnets, right?
The handhelds have antennae in the units, with a few having the added
capability of an added antenna. Who uses those? For one, the XM guys, and
the car GPS receiver guys. People with steel car roofs, thus the magnets.
The XM people say, "hey, why not use a basic design we already use." The
left hand didn't anticipate the different needs of the right hand.
So how long does it take to realize there is a big problem, design a
different antenna, get it to manufacturing and distribute it? My guess is 6
months, minimum. Added to that the fact that they already have made a big
production run of the wrong antennae, which they would no doubt like to
sell; otherwise it takes directly away from the per unit profit. These
people kill to save pennies per unit, but now they are going to have to take
a hit for several tens of dollars per unit? Someone up top is *not* a happy
camper, at Garmin, I'll bet.
Old December 20th 05, 06:35 AM posted to rec.aviation.student,rec.aviation.piloting
"cjcampbell" wrote\
I wouldn't know for sure about the cost. It was my impression that it was
very expensive and time consuming to spin certify , and spin resistance
certify a new design.
procedure.
Granted about the spin resistance. I think the other thing that some people
are overlooking is the brother's goals in a new GA airplane, which was to
make it safer than all other GA craft, in giving an out in continued VFR
into IMC, departures, loss of engine and a dozen other problems that
sometimes come up. That was real important to them.
Chuckle How true!
Old December 20th 05, 09:46 PM posted to rec.aviation.student,rec.aviation.piloting
On Sun, 18 Dec 2005 at 22:05:05 in message
, Dave
But, alas, I am also having difficulty in understanding why Garmin
would install magnets in their remote GPS antenna that commonly is
placed on the cowl/glareshield of of what is usually an ALUMINUM or
COMPOSITE aircraft.
Perhaps because it is almost the same as the one I have had for some
time that goes on the roof of my car? There it fits snug and never
seems to move until I take it off. :-)
David CL Francis
Old January 7th 06, 12:33 AM posted to rec.aviation.student,rec.aviation.piloting
COMPOSITE aircraft.
It could be that those antennas are sometimes used on car roofs.....
David Johnson
Cirrus demo Dan Luke Piloting 12 December 4th 05 05:26 AM
New G-1000 182 & Cirrus SR-22 GTS Dan Luke Owning 22 June 27th 05 07:18 PM
Iced up Cirrus crashes Dan Luke Piloting 136 February 16th 05 07:39 PM
Cirrus SR22 Purchase advice needed. C J Campbell Piloting 122 May 10th 04 11:30 PM
