The engine is finally back!
Old December 22nd 05, 04:41 AM posted to rec.aviation.owning
Default The engine is finally back!
Before starting the last engine I put together, I borrowed a oil pressure
pot to fill the galleys.
Attached at the oil pressure takeoff and pushed oil in by air pressure
before the first start.
Used a quart or so. It not only fills the galleys but also pumps up the
lifters.
Engine fired on the 2 blade and ran smooth!
Kent Felkins
Tulsa
"Viperdoc" wrote in message
After sending my Lycoming AEIO-540 to the factory for a mandatory repair
it
has finally returned. At Oshkosh this year the people at the Lycoming
booth
swore it would take only two weeks, but when the actual paperwork arrived
everything said one month in the shop. It ended up taking a little over a
month, from the day it was crated by my mechanic to the day it was
returned.
Lycoming says they will pay for the costs of removing and remounting the
engine, along with the shipping as well as the repairs. Mine only had a
little over 300TT. I guess they figure the costs of the new crankshafts as
well as the repairs for all of the engines would be a lot cheaper than
series of very expensive product liability lawsuits!
Anyway, it looks like it'll need mineral oil for a while, and then there's
also the risk of something else working loose or breaking after the
removal
and install- we'll have to wait and see in this regard. I may take it and
run it hard for a few hours, and then take it back to the mechanic to pull
the cowling and make sure everything stayed tight.
I've heard a lot of different advice on breaking in a new engine- run at
full power, don't run at any power for a long period of time, vary the
power
settings (MP and prop), etc. Any advice? When do you switch back to
regular
detergent oil?
Old December 22nd 05, 05:38 AM posted to rec.aviation.owning
I did something similar when I replaced the engine in a van I owned long ago. I
scavenged an empty freon tank, removed the valve, and poured four quarts of oil
into it with a funnel (seemed to take forever). Then I put the valve back in and
hooked it up to an air compressor. Once I got it pressurized, I turned it upside
down, hooked it up to the hole for the oil pressure sending unit, and opened the
valve.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old December 22nd 05, 06:05 PM posted to rec.aviation.owning
valve.
Probably think you're clever don't you asshole?
Old December 22nd 05, 06:01 PM posted to rec.aviation.owning
At Oshkosh this year the people at the Lycoming booth swore it would take only two weeks, but when the actual paperwork arrived everything said one month in the shop. It ended up taking a little over a month, from the day it was crated by my mechanic to the day it was returned.
You've never been lied to before? You dumbass MoFo.
Old December 22nd 05, 06:23 PM posted to rec.aviation.owning
I don't know that he was lied to. You got to figure it took a week to get
from him to them and then a week from them to him. That means the work took
2 weeks.
Old December 23rd 05, 12:41 AM posted to rec.aviation.owning
They actually told me two weeks total- from the day it was shipped to the
Old December 23rd 05, 06:41 PM posted to rec.aviation.owning
news
Well they were idiots for saying that and you have every right to be ****ed.
I assume you or they didn't ship the engine one or two day air. They really
should quote "time in the shop". It's not like they can control how long it
takes to ship.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Chevy LS2 and Trans??? any real issues besides weight MrV Home Built 82 November 18th 05 04:11 AM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 02:09 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
