Flying Home Commericially Tonite...
Old December 28th 05, 09:32 PM posted to rec.aviation.piloting,rec.aviation.student
Default Flying Home Commericially Tonite...
What makes me think it was true was the fact that you continued to your
destination. If it was a malfunction, then it would be hard to justify
continuing (unless of course you're British Airways an have four
engines...). A double compression stall on takeoff would be the absolute
worst time for that to happen.
I had a roomate a while back that was a flight attendant on the Pan Am 747
that lost an engine (as in "fell off" the wing) on takeoff. Still landed
without further incident. And yes, she was quite attractive
Marco Leon
"Wiz" wrote in message
Marco:
Don't know if it's true or not -- just what the pilot said...
Cheers,
Wiz
Marco Leon (at) wrote:
If it's really true that the crosswind caused the compression stall, I
wonder why we don't hear about a double stall very often. Theoretically,
wind can be strong enough to affect both engines, no?
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old December 28th 05, 09:30 PM posted to rec.aviation.piloting,rec.aviation.student
wonder why we don't hear about a double stall very often. Theoretically, the
A gusty crosswind is probably the most common cause of compressor
stalls on commercial flights. Of course, that doesn't mean that
anytime there's a crosswind that turbofans will be belching fire left
and right. It's not that common. You have to get just the right
level of disruption in the airflow. With any given crosswind, the
airflow to each engine is going to be different, because of where they
are situated, so it's unlikely that you'd get conditions conducive to
simultaneous compressor stalls.
Old December 28th 05, 09:42 PM posted to rec.aviation.piloting,rec.aviation.student
"Marco Leon" mmleon(at)yahoo.com wrote in message
Because each engine is in a different place, perhaps masked from crosswind
by the fuselage, etc. Compressor stalls due to crosswind most often occur,
in my experience, at the start of the takeoff run, if you bring the power up
too quickly and one of the engines has a disrupted flow it will pop. Once
you've got speed crosswind compressor stalls are not too common. Another
place you're vulnerable with fans is top of descent. In the 747, if we were
at or over about 370 at start of descent it was real easy to stall them.
We'd have to bring the power back easy and not all the way. Once below 350
you can bring them back to idle.
Old December 29th 05, 03:41 AM posted to rec.aviation.piloting,rec.aviation.student
Wiz wrote:
A few years ago, before I started flying, I was on an American flight
out of Houston with a pretty good crosswind ripping across the runway.
I was seated near the back of the plane. A couple of seconds after
takeoff we heard a VERY loud bang, the left wing dipped momentarily,
and we continued on...
And the plane continued to climb out on one engine?
The Monk
Old December 29th 05, 02:23 PM posted to rec.aviation.piloting,rec.aviation.student
"Flyingmonk" wrote
flight out of Houston with a pretty good crosswind ripping
across the runway. I was seated near the back of the plane. A
couple of seconds after takeoff we heard a VERY loud bang, the
left wing dipped momentarily, and we continued on...
Of course...ALL jetliners are required to be able to complete the
takeoff roll after V1 and climb out with one engine inoperative.
However, I don't think that the premise in the preceding post was
valid....all of the conditions for a successful relight (if indeed
it had flamed-out) were still present without having to read a
checklist, fuel was ON, ignition was ON, and engine was TURNING.
I personally have never experienced a compressor stall that caused
an engine to flame-out.
Bob Moore
ATP B-707 B-727
PanAm (retired)
Old December 29th 05, 07:23 PM posted to rec.aviation.piloting,rec.aviation.student
I concede that the pilot's explanation of the 20-minute delay before
explaining what happened to the passengers, that they were "reading the
manual on how to restart it" may not be valid. I know exactly zip
about jet checklists and POHs :-) Just repeating what captain said...
Bob Moore
ATP B-707 B-727
PanAm (retired)
Old December 29th 05, 02:43 AM posted to rec.aviation.piloting,rec.aviation.student
Jay Beckman wrote:
Am I correct in thinking that disrupting the airflow into a turbofan engine
sets up a momentarilly over-rich mixture (hence the visible flame?)
The early jets (1940s) were prone to compressor stall. Several books I have
which discuss that period state that the mixture goes rich when this happens. In
something like the Me-262, it would get rich enough for the fire to go out.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Flying Truisms Matt Barrow Piloting 6 November 16th 05 04:27 PM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Little friend takes big brother home. ArtKramr Military Aviation 14 November 2nd 03 02:15 AM
'They want to ban recreational flying...' Thomas J. Paladino Jr. Piloting 28 July 22nd 03 07:20 PM
