![]() "Flyingmonk" wrote in message oups.com... ...does it take to change a nav light? 1 to change the nav light and to post that the nav light has been changed 14 to share similar.... Ya missed one.... 26 hodgepodge of liberals and conservatives to argue the political merit, or lack of, of the FARs that require NavLights in the first place |
Flyingmonk wrote:
...does it take to change a nav light? 13 to remind the rest that only in aircraft with electrical systems is this even an issue. - Andrew |
Andrew wrote:
13 to remind the rest that only in aircraft with electrical systems is this even an issue. A cub driver are you? :^) The Monk |
![]() "Andrew Gideon" wrote in message gonline.com... Flyingmonk wrote: ...does it take to change a nav light? 13 to remind the rest that only in aircraft with electrical systems is this even an issue. - Andrew Add some discussion about the logbook entries and qualifications required to do said act. |
The most important part of going out to the plane to change the nav
light is that it MUST be flight tested. It requires at least an hour to test and grabbing a hamburger in the process seems to help quite a bit as well. There is nothing more sad than going out to the plane to do some minor maintenance and not being able to fly. -Robert |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Light Sport Aircraft for Private Pilots (Long) | Jimbob | Owning | 17 | March 1st 05 03:01 AM |
Delta Pilots End Era of Luxurious Pay | Peter MacPherson | Piloting | 42 | November 18th 04 05:46 AM |
Older Pilots and Safety | Bob Johnson | Soaring | 5 | May 21st 04 01:08 AM |
