Newbie holding questions
Old January 5th 06, 03:18 AM posted to rec.aviation.ifr
Default Newbie holding questions
"JohnK" wrote in message
I am getting ready to start IFR training next week, and there are a
couple of questions regarding holding that I have been pondering.
(Searched through here already, but couldn't find the answers...at
least spelled out for me
When being assigned a hold, will ATC usually assign an altitude as
well?
No, an altitude is not specifically part of a holding instruction. There'd
be no need to issue an altitude if you're to hold at the currently assigned
altitude.
None of the samples I've seen in the FAA text or the AIM mention
an altitude in a clearance, and it made me wonder what happens when a
large volume of aircraft are holding at a busy airport waiting to land.
Do they "stack 'em and rack 'em" (like it looked the two times I've
flown into LHR), or do they have them hold all over the place (which I
observed on the BOS Airport Monitor a few weeks ago when that snowstorm
rolled through.)
They may do both and also employ other floe control measures.
Secondly, what happens there is a holding pattern used to enter an
approach to landing, and there are multiple aircraft landing? For
example, if there were several planes flying into Charlottesville (CHO)
from the east (GVE VOR, 17 nm), wouldn't everyone be entering the
holding pattern at 3300', thus creating a collision hazard? Or would
ATC only clear one aircraft at a time for the approach? Which doesn't
seem to do much for volume, but normally isn't an issue at a place like
CHO unless there is a football game....
At CHO they will be radar sequenced for the approach, football game or not.
Old January 5th 06, 03:21 AM posted to rec.aviation.ifr
An EFC should always be part of a hold clearance, if they
forget, ask.
James H. Macklin
ATP,CFI,A&P
"Steven P. McNicoll" wrote in
message
ink.net...
there are a
pondering.
answers...at
altitude as
| well?
currently assigned
| altitude.
mention
happens when a
waiting to land.
times I've
place (which I
that snowstorm
| rolled through.)
measures.
to enter an
landing? For
entering the
hazard? Or would
Which doesn't
at a place like
Old January 5th 06, 03:35 AM posted to rec.aviation.ifr
"Jim Macklin" wrote in message
news:Xk0vf.40491$QW2.2848@dukeread08...
forget, ask.
An EFC is not issued when no delay is expected.
Old January 5th 06, 03:45 AM posted to rec.aviation.ifr
But if no delay is expected and you have a radio failure
without an EFC, just how long are you expected to hold?
If you are given a clearance to hold w/o an EFC there is
still some delay expected, otherwise ATC would not issue a
hold. Make them say how much delay or give an EFC/EAC time
or you'll be holding until the fuel runs out. Maybe the
book does not require ATC to issue a time, but my sense of
self-preservation wants to know.
If I'm told to expect a hold, perhaps there are weather
delays or even a traffic situation [maybe a NORDO ahead]
I'll ask for a reduced speed, perhaps I filed 260 KTAS and
can slow to 200-220 KTAS and avoid holding and still give
them time.
If I have requested a hold for training, I'll tell them I
want 3 or four turns and I'll try to do it away from the FAF
to ease the load on the system.
James H. Macklin
ATP,CFI,A&P
some support
message
ink.net...
| "Jim Macklin" wrote
in message
they
| forget, ask.
Old January 5th 06, 03:57 AM posted to rec.aviation.ifr
news:%D0vf.40496$QW2.15228@dukeread08...
You're not expected to hold.
hold.
If a delay was expected an EFC would have been issued.
How much delay? The answer is "None." The book says do not specify an EFC
if no delay is expected. If your sense of self-preservation can't live with
that don't fly IFR.
Old January 5th 06, 04:02 AM posted to rec.aviation.ifr
forget, ask.
If no delay is expected, then why be put in the hold in the first place?
If no EFC and radios go belly up while in IMC, when would you know to leave
the hold?
Allen
Old January 5th 06, 04:22 AM posted to rec.aviation.ifr
"A Lieberman" wrote in message
It's a tool of nonradar separation, it's called a "paper stop". Let's say
two aircraft are estimated to cross at a fix eight minutes apart. Minimum
separation is ten minutes, so some action must be taken. The later aircraft
is issued a hold prior to the common fix. Since the first aircraft is
expected to pass the common fix before the second aircraft reaches the
holding fix no delay is expected and no EFC is issued.
leave
the hold?
Without an EFC I wouldn't enter the hold. It's a moot point anyway,
whatever caused my comm radios to go belly up will affect my nav radios the
same way and I won't be able to identify the holding fix.
Questions from a newbie. Andrew Tubbiolo Home Built 9 September 14th 04 01:40 AM
Newbie with questions... Mike \(Remove X's to reply\) Piloting 10 February 14th 04 01:16 AM
Newbie questions Rail / Ejector launchers AL Military Aviation 19 November 14th 03 07:47 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 05:23 PM
