Fiberglass adhesion to aluminum?
Old January 6th 06, 08:50 PM posted to rec.aviation.homebuilt
Default Fiberglass adhesion to aluminum?
I did some testing on this a while back.
West systems epoxy /1 inch wide fiberglass tape on bare aluminum sheet
1 square inch of adhesion area
peel strength tested
No surface preparation --- less than 1 pound of force peeled it right off.
sanding --- not much better - maybe 2 pounds of pull
Sanding and etching --- At least 20# - broke the fiberglass tape, and
it never did come off.
If the surface is prepared properly, with etchant, it will work. Otherwise
forget it.
Ron Webb
wrote in message ...
I've got some slight cracking in my aluminum nosebowl and have stop
drilled them twice.
I'm considering backing the cracks with fiberglass in hopes to keep the
vibration down.
How well does fiberglass adhere to aluminum?
What system is better.
I have easy access to the West system chemicals.
Any hints? Alodine first?
Thanks
Dave
Old January 7th 06, 02:15 AM posted to rec.aviation.homebuilt
One thing to keep in mind is that long-term it is difficult to keep a bond.
This is largely due to aluminum expanding and contracting with temperature
more than Fiberglass does. If the part is kept temperature stable it will
last longer than, say, a part that is close to the engine or exposed to
daily solar cycles. Mechanically bonding the two with some sort of rivit or
screw might help.
D
"Ron Webb" wrote in message
pull
forget it.
Ron Webb
drilled them twice.
vibration down.
Thanks
Dave
Old January 7th 06, 02:20 AM posted to rec.aviation.homebuilt
According to the product specification sheet for Belzona 1111 (Super
Metal).
Tensile shear adheasion: When tested in accordance with ASTM D1002,
using degreased strips, grit blasted to a 3-4 mil profile, typical
values will be: aluminum 1,800 psi (126 kgs/cm2), mild steel 2,700 psi
(190 kgs/cm2), polyester/glass fiber 700 psi (49 kgs/cm2) [breakdown
in substrate], stainless steel 2,800 psi (197 kgs/cm2)
Another great thing Belzona has over other materials is the fact that
it does not rust, rot, corrode, or shrink. No solvents. 100% solids.
Chemical reaction cure.
Old January 7th 06, 04:13 AM posted to rec.aviation.homebuilt
I did it today.
sanded the area with 80 grit and alodined it to brighten it up.
mixed up some epoxy and put 3 layers of fiberglass.
Touched it up with a heat gun since it was 60 degrees in the hangar.
Didn't use any primer, just the epoxy.
If it lasts 10 years, I'll be happy.
Thanks all for the tips!!!!
Dave
Richard Riley wrote:
On 6 Jan 2006 18:20:44 -0800, "Clay"
:According to the product specification sheet for Belzona 1111 (Super
:Metal).
: Tensile shear adheasion: When tested in accordance with ASTM D1002,
:using degreased strips, grit blasted to a 3-4 mil profile, typical
:values will be: aluminum 1,800 psi (126 kgs/cm2), mild steel 2,700 psi
:in substrate], stainless steel 2,800 psi (197 kgs/cm2)
:Another great thing Belzona has over other materials is the fact that
:it does not rust, rot, corrode, or shrink. No solvents. 100% solids.
:Chemical reaction cure.
The problem is that like any adhesive bonding to aluminum, the bond
can fail over time if you don't use a corrosion inhibiting primer of
some kind. There are very long specifications to do a certifiable
bond to aluminum.
Now, for a cowl it would probably be fine.
Old January 7th 06, 04:15 AM posted to rec.aviation.homebuilt
I beg to differ. Belzona 1111 is not like the typical adheisives
available on the market.
With proper surface preperation, there will not be any bondline failure
with Belzona 1111. This has been documented by many independent and
government testing labs. Even the necular regulartor commission
approves Belzona 1111.
Belzona 1111 has been used by the USAF to rebuild areas around the
windows on KC-135 tankers.
Old January 7th 06, 04:56 AM posted to rec.aviation.homebuilt
On Fri, 06 Jan 2006 18:00:32 GMT, Richard Lamb
Roger wrote:
On Fri, 06 Jan 2006 05:59:37 GMT, Richard Lamb
If a fiberglass patch on an aluminum backplate stays on for one entire
trip around the pattern, I'd be flat out amazed...
Properly preped it'll stay on as well as the paint, better in some
cases. Without a good degrease and prep I doubt it'd stay on past the
run up. :-)) Many of our "plastic" planes have Aluminum to
glass/resin bonds.
www.rogerhalstead.com
I know, Roger, but....
Someone who is actually building a plastic plane should step up to the
microphone and tell how those metal plates are installed.
As for the three methods described below you will find photos at
http://www.rogerhalstead.com/G3_file.../glasair11.htm along
with some description. As you'll note, these are not just "slapped"
in. :-))
It depends on which part and where.
Typically, you'll find captive nuts like the K2000-4 (If I remember
the number correctly) both pop riveted in place and then have the
"ears" glassed in with two layers of cloth and resin. The "glass
serves as much to keep from losing the captive nuts as it does
structurally. Lose one of those suckers and it means cutting a hole
in the horizontal stab, glassing in a new K2000-4, and then patching
the stab so it looks like you never had to bore a hole in it.
The backing plates for the engine mount attach bolts (which are held
under considerable compression) are of 0.10" SS. The face and edges
are thoroughly sanded and these are bonded on the face and sides to
the engine mount attach point reinforcements using a resin and mill
fiber mix. For six attach points there are a total of 96 individual
lay-ups just for the reinforcements, plus six more two layer lay-ups
used for forms.
The third method which is *similar* to what he's asking about is the
fuel tank filler neck. There the outer ring is set into a tight
fitting opening just a tad forward of the windshield. This pieces is
held entirely by a resin and mill fiber mix. which is built up around
the neck. This is in an area which would receive pretty much the same
kind of stresses as the cowl crack and receives a lot of stress from
expansion and contraction of the machined Aluminum filler neck and
cap.
*However* how I've seen a cowl patched, and the only way I've seen it
done was to first, "stop drill" the crack. Then a small "doubler" was
made out of Aluminum about the same thickness as the cowl. As the
crack included the leading edge of the cowl where the edge is rolled
back and extended back about 2 inches. ( Of course the thing would
never crack where it's easy to fix)
(Yah ever try to type with a lap full of a 16# cat? At least he
didn't have his claws out when he jumped up.)
Slight distraction there.
At any rate, The entire area was thoroughly cleaned, sanded, cleaned
again, the doubler fitted, then flush riveted in, and finally the
whole thing was glassed over on the inside with two layers of glass
and resin. The glass was a last resort as the doublers were refusing
to hold.
Hmmmm... Good thing I'm not writing and this has a back space key.
He just knocked over the waste basket. I think I have a cat who wants
some attention.:-))
I know of no structural design that has aluminum plates "glued" on to
glass.
Nor do I, but didn't he ask about patching a cowl crack? It is
structural, but only for vibration and a slight wind load. Of course
it does depend on where in the cowl as well and I'd still want to use
a doubler..
My best guess is that they get "bonded in" by covering them with more
layers of glass. - in effect, the metal is burried inside the glass.
That's not he case here.
Richard (the skeptical cave) Lamb
Old January 7th 06, 07:46 AM posted to rec.aviation.homebuilt
used for forms.
Oops...Make that 12 more two layer lay-ups, not six. There are two
for each side of each of the six reinforcements.
And some wonder why a G-III takes longer than some scratch built
planes. :-))
Old January 7th 06, 03:17 PM posted to rec.aviation.homebuilt
I did it today.
Dave
The alodine will give a pretty good bonding surface...
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Fiberglass Tip Tanks Question Jay Honeck Owning 7 September 26th 03 04:23 AM
