Nasa Icing courses
Old January 7th 06, 02:58 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Nasa Icing courses
Not everyone receives or subscribes to *every* newsgroup.
That's because we want to choose what we download. Icing is mostly
relevant to IFR flight.
If everyone did what you did, there'd be no point to having multiple
groups.
Old January 7th 06, 03:18 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
I didn't post to rec.aviation or rec.aviation.homebuilts, or
alt.binaries.pictures.aviation, or probably a half dozen others.
If you don't think my post was relevant to each group that I posted to,
you're wrong. Not everyone receives or subscribes to *every* newsgroup.
"Scott Draper" wrote in message
Please don't crosspost to *every* aviation newsgroup.
Old January 7th 06, 09:28 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Nasa Icing courses and complacency
Well you chose to download it.
Icing is mostly
Not true. Unless you want to bend thoughts one way only. And I see your
need to do so. I would not advocate vfr pilots follow your lead of
practicing non-enlightenment. Around the great lakes here we get
moisture, higher up icing, farther away icing, and higher and farther it
is snow. VFR pilots here contend with this, lots. The IFR planes are
known icing approved. So would you advocate the ifr pilots not learn
about icing as they can just push a button to shed it?
And if you would bother to look and read before you bash, you would see
that there is also a course on ground icing also.
Both are very applicable to vfr flying.
Somehow I just know you are 'really good' at Microsoft flightsimulator.
I have not looked at the courses yet but I see no harm in them. Take
your electrons to the recycle bin.
It was a good post and I am glad to have run accross it.
Old January 7th 06, 09:59 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
groups.
While I agree with you that the original post was over-cross-posted, it
seems to me that the only newsgroup that was blatantly off-topic for the
post was r.a.owning.
It seems to me that airframe icing is primarily an IFR issue, possibly of
interest to people reading r.a.piloting, and hardly applicable to people
involved in their primary training (the main audience in r.a.student). But
a person who lacks a conservative bent, a person who doesn't understand why
it's a good thing to be VERY minimal about cross-posting, they aren't going
to see it that way.
They are going to think "well, this *might* be of interest to someone who
*might* be reading that newsgroup", and they (or similar-minded folks) are
going to get all bent out of shape if you try to suggest otherwise.
Which is, in fact, what happened so far.
Of course, your original reply was somewhat exaggerated as well (there
*were* plenty of rec.aviation.* newsgroups that didn't get the post). I'm
sure that didn't help the mood.
Pete
Old January 8th 06, 12:41 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Thank you Jim for this wonderfull posting.
Paul
"Jim Burns" a écrit dans le message de
news: ...
As many of you probably know, recent midwest weather has been a steady
stream of low overcast, misty, and foggy days prohibiting most VFR flight
and making IFR flights a spin of the icing roulette wheel. I thought it
may
be a good opportunity for us to review NASA's icing online courses.
http://aircrafticing.grc.nasa.gov/courses.html
Old January 8th 06, 02:11 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Jay Honeck wrote:
Other than that, we haven't flown diddly squat in weeks. Our last fly-in
guest was sometime around Thanksgiving. Worst flying weather I've ever
seen.
So between the weather and my work backing up, at least my engine picked
a good time to make metal. It is off the airplane waiting for the crate
to arrive from Penn Yan. I last flew on a return trip over Thanksgiving
weekend. Pulled the filter right after that trip (11 hours after
finding metal in the filter during the october annual) and found as much
metal as the previous 30+ hour filter had in it, so I grounded it.
The engine is 26 months and 178 hours out of a new limits Penn Yan
overhaul with new ECI titan stud assemblies, new cam, new accessory
gears, new oil pump, all new accessories, etc. About all that wasn't new
was the crank and case, and those were reworked during the overhaul.
The intake cam lobe for the #3 and #4 cylinders failed and is worn down
considerably, hence the engine coming off and waiting for the crate.
Old January 8th 06, 02:39 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
it seems to me that the only newsgroup that was blatantly off-topic
for the post was r.a.owning.
I agree that it's arguably on topic for most of the groups, but so is
almost *every* topic. After all, what doesn't apply to the "piloting"
group? And aren't we all "students" of some sort?
The overlap of readership among the groups makes cross-posting
redundant. My observation is that it's mostly newbies that do it.
Artistic license? ;-)
Old January 8th 06, 02:42 AM posted to rec.aviation.owning
So, is Penn Yan providing the new engine at no cost, or pro-rated? Are they
picking up any of the removal/reinstallation and shipping expenses?
-Elliott Drucker
Old January 8th 06, 02:46 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
That's a ridiculous mischaracterization of what I said.
I did say that icing applies *mostly* to IFR pilots and that remains
true. That isn't the same as saying that VFR pilots *never* have to
worry about icing.
Your post was a mixture of ad hominem and straw man arguments.
Old January 8th 06, 03:18 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Say what you want, the OP was just fine in what he did.
worry about icing.
Nasa Icing courses Jim Burns Piloting 96 February 1st 06 04:16 AM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
NASA Icing Course [email protected] Piloting 3 December 28th 04 05:18 PM
About Acellerated Courses for Private Dudley Henriques Piloting 137 July 22nd 04 04:21 AM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
