#11
Man, you have problems or something.
Scott Draper wrote: Please don't crosspost to *every* aviation newsgroup. |
Not everyone receives or subscribes to *every* newsgroup.
That's because we want to choose what we download. Icing is mostly relevant to IFR flight. If everyone did what you did, there'd be no point to having multiple groups. |
You mean, Like you just did?
My reply went to every group, because his did (my newsreader did that.). Another problem with cross-posting. It's stupid to have every thread replicated across all the aviation groups. |
I didn't post to rec.aviation or rec.aviation.homebuilts, or
alt.binaries.pictures.aviation, or probably a half dozen others. If you don't think my post was relevant to each group that I posted to, you're wrong. Not everyone receives or subscribes to *every* newsgroup. Jim "Scott Draper" wrote in message ... Please don't crosspost to *every* aviation newsgroup. |
![]() Scott Draper wrote: Not everyone receives or subscribes to *every* newsgroup. That's because we want to choose what we download. Well you chose to download it. Icing is mostly relevant to IFR flight. Not true. Unless you want to bend thoughts one way only. And I see your need to do so. I would not advocate vfr pilots follow your lead of practicing non-enlightenment. Around the great lakes here we get moisture, higher up icing, farther away icing, and higher and farther it is snow. VFR pilots here contend with this, lots. The IFR planes are known icing approved. So would you advocate the ifr pilots not learn about icing as they can just push a button to shed it? And if you would bother to look and read before you bash, you would see that there is also a course on ground icing also. Both are very applicable to vfr flying. Somehow I just know you are 'really good' at Microsoft flightsimulator. I have not looked at the courses yet but I see no harm in them. Take your electrons to the recycle bin. It was a good post and I am glad to have run accross it. |
... That's because we want to choose what we download. Icing is mostly relevant to IFR flight. If everyone did what you did, there'd be no point to having multiple groups. While I agree with you that the original post was over-cross-posted, it seems to me that the only newsgroup that was blatantly off-topic for the post was r.a.owning. It seems to me that airframe icing is primarily an IFR issue, possibly of interest to people reading r.a.piloting, and hardly applicable to people involved in their primary training (the main audience in r.a.student). But a person who lacks a conservative bent, a person who doesn't understand why it's a good thing to be VERY minimal about cross-posting, they aren't going to see it that way. They are going to think "well, this *might* be of interest to someone who *might* be reading that newsgroup", and they (or similar-minded folks) are going to get all bent out of shape if you try to suggest otherwise. Which is, in fact, what happened so far. ![]() Of course, your original reply was somewhat exaggerated as well (there *were* plenty of rec.aviation.* newsgroups that didn't get the post). I'm sure that didn't help the mood. Pete |
You mean, Like you just did? My reply went to every group, because his did (my newsreader did that.). Is it true that Forte Agent won't let you adjust the groups you reply to? I knew it wasn't perfect, but I didn't know it was *that* defective. |
You can turn the feature off that replies to every newsgroup that the original poster, but I haven't done so. It normally isn't necessary. The problem is that when a person cross posts, if you want to reply, which group do you reply to? He's only going to read one, probably. On Sat, 07 Jan 2006 22:55:41 GMT, "John R. Copeland" wrote: "Scott Draper" wrote in message ... You mean, Like you just did? My reply went to every group, because his did (my newsreader did that.). Is it true that Forte Agent won't let you adjust the groups you reply to? I knew it wasn't perfect, but I didn't know it was *that* defective. |
Thank you Jim for this wonderfull posting.
Paul "Jim Burns" a écrit dans le message de news: ... As many of you probably know, recent midwest weather has been a steady stream of low overcast, misty, and foggy days prohibiting most VFR flight and making IFR flights a spin of the icing roulette wheel. I thought it may be a good opportunity for us to review NASA's icing online courses. http://aircrafticing.grc.nasa.gov/courses.html Jim |
Jay Honeck wrote:
Other than that, we haven't flown diddly squat in weeks. Our last fly-in guest was sometime around Thanksgiving. Worst flying weather I've ever seen. So between the weather and my work backing up, at least my engine picked a good time to make metal. It is off the airplane waiting for the crate to arrive from Penn Yan. I last flew on a return trip over Thanksgiving weekend. Pulled the filter right after that trip (11 hours after finding metal in the filter during the october annual) and found as much metal as the previous 30+ hour filter had in it, so I grounded it. The engine is 26 months and 178 hours out of a new limits Penn Yan overhaul with new ECI titan stud assemblies, new cam, new accessory gears, new oil pump, all new accessories, etc. About all that wasn't new was the crank and case, and those were reworked during the overhaul. The intake cam lobe for the #3 and #4 cylinders failed and is worn down considerably, hence the engine coming off and waiting for the crate. |
Nasa Icing courses | Jim Burns | Piloting | 96 | February 1st 06 04:16 AM |
Nasa Icing courses | Jim Burns | Owning | 108 | February 1st 06 04:16 AM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 05:18 PM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
