Jay Honeck wrote:
1) In any choice situation, take the crosswind from the right. Be especially wary of left crosswinds. (I have not seen this published anywhere) Can you expand on that a bit, please? I'm not sure I see where you're going with this. When the nose is high in the flare, if you have to add power for any reason, P-factor will tend to add to your problems with a wind from the left and help you with a wind from the right. In addition, I've always found that slipping into a wind from the right gives me better visibility in the high-wing aircraft I've owned. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
Jay Honeck wrote: 1) In any choice situation, take the crosswind from the right. Be especially wary of left crosswinds. (I have not seen this published anywhere) Can you expand on that a bit, please? I should have clarified the sentence & said for takeoffs only. It already takes right rudder in a zero wind to compensate for the rotating slipstream etc, but it takes still more right rudder for any left crosswind. The result for me (C172M) is that a 10 knot left crosswind is like a 20 knot right crosswind in terms of rudder-needs and pucker factor. Is this true in the Cherokees? It may not be so much so because of the fixed nosewheel steer connection, although when the nose is raised it has to be true. NRP |
nrp wrote: I should have clarified the sentence & said for takeoffs only. It already takes right rudder in a zero wind to compensate for the rotating slipstream etc, but it takes still more right rudder for any left crosswind. The result for me (C172M) is that a 10 knot left crosswind is like a 20 knot right crosswind in terms of rudder-needs and pucker factor. I'm still not sure I follow you. If your objective immediately after takeoff was to have the fuselage aligned with the runway, as it is immediately before landing, I'd agree that more rudder would be required against the rudder weathervaning. Takeoff is not the same as landing in this respect though. Upon liftoff you should make a _coordinated_ turn into the wind in order to add the appropriate amount of crab angle required to stay above the runway (left aileron and left rudder into a left crosswind). Asymmetric rudder usage shouldn't really apply, I think, aside from the usual net left-turning tendencies. If you're not flying in a coordinated manner on takeoff you're throwing away performance and operating at less than optimal efficiency - at a time when you can use all the performance you can get. Or maybe I'm misunderstanding. I'm still licensed to learn. ![]() -R |
As a Mooney owner and CFI I do a fair amount of Mooney transition
training. From talking to Mooney shops that fix the damage afterwards, I've discovered that you get 2 bounces for free in the Mooney. The third bounce costs about $20,000. I tell my students not to try to save a Mooney bounce, just add full power and go around. Also, the attitude the plane sit at while on the ground will result in a bounce (I guess teh nose hangs lower than the mains). The visual picture you want to see on landing should have the nose higher than you see while at rest on the ground. Weight also makes a pretty good difference. With two guys on board and less than 1/2 fuel you should reduce your normal approach speed by 5 knots vs. near gross. The nice thing about Mooneys is that there is no cross wind in the flare. The wings sit so low that they really don't feel cross wind. Its the bushes effect, below waist level the bushes disrupt the wind. I've landed in as much as 25 knots cross wind in my Mooney. Once in the flare you can pretty much take the cross wind correction out. Its very different than a C172. -Robert, CFI |
"Tony" wrote in message
oups.com... .... That's my story (and I'm sticking to that excuse!). What's your's, and what were the lessons learned? Flying with my brother in his T-18, Kinda rusty. And we went to to an airport with runways that were at least 100 if not 150 feet wide. Huge things. I'm coming down, thinking that I'm practically on the ground, flairing, holding it off, holding it off, wating for the gear to touch. Why haven't we touched yet? We GOTTA be there! This runway looks way too close. Then, drop, bang. I must have been 6 feet up. All that runway had "tricked" my eye. The runways I was used to claimed to be 30 or 40 feet, but only a little down the middle was still solid blacktop. A lot of the width had pretty much just faded away into the grass (kinda like my memory). I wasn't used to seeing much pavement out the side windows. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
On 2006-01-06, Tony wrote:
'Fess up' time. We were having a hanger session a while ago, talking about firm landings. Right after I got my Comanche I was up with my CFI doing practice landings. I did one short field landing that was just fine, so we were both a little complacent when I came around the second time and made a perfect short field landing about 3' in the air. I saw it coming and had full power on just as the bottom fell out, and we just smacked down for a split second and then we were going around. What I was totally unprepared for was how upsetting it was to do something like that to *my* *airplane*. I was a wreck on the next pattern. I tried to land softly, ended up forgetting to ever totally cut power, skating around on the runway with full flaps until my instructor pointed out the throttle. At that point my Comanche landings were (obviously) not up to the standard of my 172 landings, and that incident set me back another 100 hours or so while I regained confidence flying low and slow in the Comanche. It's a pig when slow (very little aileron authority) which gives you the feeling that it won't be able to round out and flare, but it actually has plenty of elevator authority. -- Ben Jackson http://www.ben.com/ |
On 6 Jan 2006 06:56:53 -0800, "Tony" wrote:
During my initial private pilot night training I had plenty of "black hole" landings where I just "knew" the runway had to be inches below when it was actually several feet. After one particularly hard night "drop in" I actually asked my instructor to inspect the landing gear area the next morning with me; he laughed, but looked at the 172 anyway. Since this ng dosen't seem to be limited strictly to winged aircraft (I haven't read the FAQs or charter if there is one) I'll mention my second hot air balloon landing. I wasn't able to arrest the descent in time to avoid slamming into the ground in no-wind conditions; My instructor and I were completely surrounded by the balloon skirt as the envelope kept descending after the basket hit the ground. Worse, we did it all over again twice seeing a little less skirt each time before the thing just ran out of bounce. Ricky |
Tony wrote:
'Fess up' time. We were having a hanger session a while ago, talking about firm landings. I bought my Maule back in '95. Took a CFI down to the factory, and we flew it back; he made all the takeoffs and landings. Then he set about the process of teaching me to land the aircraft. I had a vision problem in that plane, which I later cured by putting a 2" cushion in the pilot's seat, but I had no cushion back then. I came in for a landing at 47N, leveled off, and let the speed degrade a bit, planning to let it settle down to the runway. Sure, I was high, but I had plenty of runway ahead of me. Kenny later estimated our altitude at about 25' AGL. Well, I misjudged the airspeed and suddenly I realized that the controls were getting a bit sloppy. I hit the throttle just as the bottom fell out. That's probably all that kept the gear from going through the bottom of the plane. We climbed back to pattern altitude and took a brief detour while Kenny made sure the right gear was still there and I did the same on my side. Maule builds tough airplanes, but mine always had a tendency to turn left when taxiing. I'm not sure it did that right after we left the factory with it. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
| Thread Tools | |
| Display Modes | |
| A new direction for an old thread: Crosswind landings | [email protected] | Soaring | 96 | March 4th 05 02:22 AM |
| Rough Field Landings | [email protected] | Piloting | 38 | December 19th 04 02:42 PM |
| Precision Landings and practice | [email protected] | Piloting | 34 | December 17th 04 03:08 PM |
| Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 07:38 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
