CFI practical test - aircraft required
Old January 9th 06, 02:19 AM posted to rec.aviation.piloting
Default CFI practical test - aircraft required
Well, yes and no. The task (section XI, task G) notes that an
endorsement may be substituted for that task, but the task is
required. In the event of no endorsement (or the examiner not
substituting it), a spin-capable aircraft would be required.
On Mon, 09 Jan 2006 01:32:40 GMT, Bill Zaleski
Not true.
On Sun, 8 Jan 2006 19:28:26 -0600, "Jim Macklin"
You also need an airplane available that can be legally
spun.
James H. Macklin
ATP,CFI,A&P
Old January 9th 06, 02:27 AM posted to rec.aviation.piloting
If a complex aircraft is required for takeoffs and landings, how would
one manage that? I can't imagine bringing two aircraft to FSDO (if a
FSDO visit was required). Are any complex aircraft ok to spin? The one
I did my CFI in wasn't.
Old January 9th 06, 02:43 AM posted to rec.aviation.piloting
I don't know about the complex aircraft question, but I'm sure there's
some way around it if you had to demonstrate them. How about go to
the FSDO, pick up the examiner, bring them back to your home field for
the spin portion of the exam? Or have your CFI ferry the spin capable
aircraft over to the airport the checkride was going to take place in
with you then disappear for a while you get the checkride over with?
Once the examiner is assigned, I presume it would be fair game to ask
them if they'd accept the endorsement so you can arrange appropriate
aircraft for all the pieces of the checkride?
Old January 9th 06, 02:46 AM posted to rec.aviation.piloting
Two aircraft may be required. The Beech F33C was acrobatic,
T34 are now subject to an AD. If the examiner knows and
respects the school and or recommending CFI, they will
usually accept the "spin endorsement" but an examiner always
has the option to require everything, that means more than
one plane is always a possibility. You note that I said
"available" in my original post. It is a good idea to know
what to expect and to have a suitable plane reserved if the
examiner wants to spin. [Some really like to spin and some
will anything to avoid it.]
James H. Macklin
ATP,CFI,A&P
some support
"Rachel" wrote in message
that an
task is
examiner not
required.
landings, how would
FSDO (if a
spin? The one
Old January 9th 06, 02:49 AM posted to rec.aviation.piloting
But you won't know until you're practical test has begun, if
the examiner verifies the logbook entry, but find you weak
on the oral portion, they may require you to demonstrate a
real spin. Thus you need an airplane certified for spins
AVAILABLE. If that takes two planes and even two days, so
be it.
James H. Macklin
ATP,CFI,A&P
some support
| spun.
| Only if you're required to do spins on the checkride.
Old January 9th 06, 02:53 AM posted to rec.aviation.piloting
Show up with a Complex Aircraft and the Spin Endorsement completed..
If the Examiner REQUIRES the SPIN as part of the test.. then get a
continuance letter specifying what is complete and what is not complete and
what needs to be accomplished to complete.
It always boggles my mind.. it's the same as showing up for a Commercial
check ride in a non complex aircraft.. and swapping aircraft for a couple of
landings in complex aircraft... just do the whole check ride in complex.
BT
"Peter Clark" wrote in message
Old January 9th 06, 02:56 AM posted to rec.aviation.piloting
be it.
Makes me glad my DE took my endorsement.
Old January 9th 06, 03:07 AM posted to rec.aviation.piloting
R u paying for my training in a complex for all the other required stuff ?
easy with my money pal..
"BTIZ" wrote in message
newsdkwf.8776$V.3820@fed1read04...
and what needs to be accomplished to complete.
of landings in complex aircraft... just do the whole check ride in
complex.
BT
Old January 9th 06, 03:25 AM posted to rec.aviation.piloting
Yes, DE and Feds don't want to waste your money and their
time. But you never know for sure until after the test is
over. They can even call you back for a re-test anytime
they have reason to do so.
I instructed at an FBO located within walking distance of
the FSDO. We always gave spin training and the endorsement
and on the day of a CFI test, the applicant would reserve a
Skipper and a Sierra.
I once had a former Naval aviator as a CFI student. He
needed very little training except for civil regs and
procedures, he was a great stick, I learned a lot from him.
His former jobs in the Navy included instructor in T28s and
flying the C130 to the South Pole for a couple of years. He
had two great war stories about exciting take-offs. One was
in white-out conditions using the radar to avoid the
buildings at the end of the runway and to stay aligned with
the take-off path [aim for the buildings but liftoff in time
to miss them.] The other was the one he thought was the
most interesting...picking up some scientists off a glacier.
The slope was such that they could not get up to rotation
speed, the side load on the skis because of the slope was
just too much. When the scientist described the glacier and
the valley beyond, he decide to fly off the end below stall
speed and not land there again.
begun, if
weak
a
spins
so
| be it.
Old January 9th 06, 03:31 AM posted to rec.aviation.piloting
Use a Skipper, C150/152/Tomahawk etc for most of the CFI or
commercial test and just use the complex as required is the
least expensive way to do it. But people's egos get in the
way and they want the size and power of the complex
airplane.
James H. Macklin
ATP,CFI,A&P
some support
"Capt. Mike" wrote in message
required stuff ?
completed..
then get a
is not complete
for a Commercial
check ride in
| complex.
| BT
| "Peter Clark"
notes that an
task is
examiner not
required.
landings, how would
to FSDO (if a
to spin? The one
I'm sure there's
about go to
home field for
the spin capable
take place in
fair game to ask
arrange appropriate
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
