Doodles...
Old January 10th 06, 06:03 PM posted to rec.aviation.homebuilt
Default Doodles...
"Richard Lamb" wrote in message
But then there is the gas load (!)
Wet wing between the spars (no clue how much gas that is, but that's
all you get).
If it will cruise at 80 shp and consumption is 1.3#/shp @ sea level, you get
17 gph. That's got to decrease a bunch at altitude, doesn't it? 50-60
gallons ought to do it.
And yes, it backs up real well.
At least on the ground.
Pick it up by the tailwheel and drag it around like a little red wagon.
You could paint "Beta mode" on the wagon, I guess. I was thinking of the
geometry of reverse thrust on a full-swivel tailwheel. Talk about a ground
loop!
Rich "I *hate* the smell of kerosene in the morning" S.
Old January 10th 06, 07:04 PM posted to rec.aviation.homebuilt
Default Doodles...
"Rich S." wrote:
snip\
I can't see any scale or measurements on your sketches. Maybe I need better
glasses.
Rich S.
http://home.earthlink.net/~cavelamb/!L-ONE-A4-A.JPG
there is a reference dimension under the fuselage = 48"
and a little lower just above the frames is a foot/inch scale.
that help?
Old January 10th 06, 07:14 PM
Jim Williams Jim Williams is offline
Junior Member
First recorded activity by AviationBanter: Sep 2005
It looks like a Midget Mustang. The MM-1 span is 18.5 ft 66 sq ft and 16.5 long and anywhere between 650-780 empty or more. If it can be built under 500lbs empty with a light engine VW or 912 it sould be bullet.
Jim Williams
Quote:
Originally Posted by Richard Lamb
Here are some (on topic - no less) doodles of a small low wing.
inspired by Bruce King's tiny little BK-1..
Richard...............
It looks vaguely familiar. . .
http://www.homebuilt.org/kits/littner/cp80.html
Rich S.
Does look darn close but the Zephyr is a bit larger
at 19+ span and 17' long.
This one is a bit smaller.
call it 16 foot span and 15 feet long.
and maybe a full foot shorter in height.
I think it was 6o to 66 sq ft for the wing area is
about the same for both.
I just uploaded a cross section sketch that shows the
size a little (intended as a pun) better.
http://home.earthlink.net/~cavelamb/l-one-2x.jpg
Guess/wish 500 pounds empty with a VW,
but
this is one place where a 912 and adjustable
prop would really rock.
Or spec the Rotax 914 (turbo!) and a higher
aspect ratio wing (longer span) for those
mini-U2 missions....
Old January 10th 06, 07:14 PM posted to rec.aviation.homebuilt
Default Doodles...
that help?
Got it!
Rich S.
Old January 10th 06, 09:56 PM posted to rec.aviation.homebuilt
Default Doodles...
that help?
Got it!
Rich S..
Great!
Now, your assignment, should you choose to accept it, is to draw up
a reeeeeaaaaaaly light weight retract system for it bg.
Gear mounts on front side of the main spar (sorry, no tricycles)
5x5 wheels with MacGreary rubber,
band brakes with cables? or hydraulic actuation.
If need be (and it will), we'll rework the root using that 15%
Ribblet
airfoil (get all the buzz-words in!) or a 23012/15 (nil CP travel -
important
in such a tiny package) and add a P-51 style planform to provide
room for
the wheels.
now we're too cool...
Some other minor wing concerns:
At stall speeds, the root chord still has an RN (Reynolds Number)
of at least 3 million.
But the tips, being shorter, show barely 2 million.
So what does that imply?
Well, for one, many of the fancy airfoils get pretty lame below
three meg.
Which might result in:
Sloppy aileron control at low speeds at best?
Or even a TIP stall - i,e: a nice fun wing drop at the break (or
before???)
Looking for an airfoil that performs well at these low RN led me to
old NACA 4 digit 2312. It is considered a turbulent airfoil, rather
than
a laminar type. But it ought to hold on a little better when slow.
Which means that the rib patterns would be a pure-D beast to loft,
were if not for a little CAD magic.
The more ribs (assuming they fit right) and the thicker the skin the
better
we can hold the desired airfoil shape - but both mean _heavier_.
The dreaded C word - (compromise),
Oh golly, well, that at least scratches the surface....
Old January 10th 06, 10:27 PM posted to rec.aviation.homebuilt
Default Doodles...
Moi? (In my best Miss Piggy voice). I'm a retarded firefighter - no engineer
fer sure.
The Emeraude uses the 23012 and I'll bet the Zephyr does as well. Add a bit
of washout to soften the stall.
I would 86 the idea of retracts and go with an RV-type gear off the engine
mount. No spar reinforcement needed, you can keep the fuselage on the wheels
when the wing(s) is/are removed, & other weight-saving advantages.
JMHO
Rich S.
Old January 11th 06, 12:30 PM posted to rec.aviation.homebuilt
Default Doodles...
fer sure.
JMHO
Rich S.
Damn! But it worked for Huckleberry Finn!
Oh well, the extended roots don't really fit anyway.
The wing on the Zephyr looked long and narrow (higher aspect ratio due to
a pretty short chord). I didn't download his plug-in to get a look at the
rest of the stuff. 3 meg on a land line? Not today. But it is an interesting
design.
I've always rigged my parasol wings flat - no washout. The thing is so
lightly loaded it doesn't really stall anyway. But I agree that this wing,
with the tiny tip chords should probably have a bit of twist in it.
Even if it does cost some top end speed.
And you touched on one of the issues I still have with this one.
Landing gear attached to the wings can be very inconvenient if a wing
needs to be removed. So we start looking at a 3 piece wing.
Center section and removable outer wing panels with the gear mounted
on the center section. Sounds like a better idea. But consider how much
that complicates the wing structure! (damned C word anyway!)
We would need about a foot of center section sticking out from the
fuselage for the gear mounts. (I don't want any of that in the cockpit
area - in case of a gear failure. Don't want any failed structure
coming into the cockpit (i.e.: pilot). )
So, while I agree that it would be a lot more convenient to have the
plane on the gear when the wings are removed, I'm not sure that the
extra weight and complication would be worth it on such a small
ship.
BTW, this is the one place where Bruce had problems too.
His first try failed rather early (just widened the stance some).
I know he fixed it, but haven't heard how well it's standing up
(no pun intended).
Lastly, unfortunately, RV style off the engine mount (which olde
timers still call Wittman-style gear) won't work here because
we don't have 1) room behind the engine, or 2) an engine mount!
Yes, I have one sketched in. But more likely, for a VW engine,
the engine mount is nothing more that 4 aluminum spacers just
long enough to keep the flywheel and rear exhaust stacks to get
clear of the firewall.
Something I hear a long time ago, and have come to believe -
"Better is the mortal enemy of good".
Richard
are we having fun yet?
Old January 11th 06, 12:36 PM posted to rec.aviation.homebuilt
Default Doodles...
bullet.
Jim Williams
Long was a true artist!
And the MM-1 is his masterpiece.
BTW, have you ever seen the original MM-1 gear arrangement?
The legs are flat aluminum leaf type but the bolt to a weldiment
that has a torque tube running thru the front spar back to the rear spar.
The torque tube has two concentric tubes, welded together at the rear
end - thus doubling the effective length. An interesting solution to
a thorny problem...
Richard
Old January 11th 06, 10:14 PM
Junior Member
Richard,
What software did you use to design the aircraft? The aircraft looks pretty damn good.
Jim Williams
UOTE=Richard Lamb]Well, since you asked...
this one is a 76 sq. ft wing which is not the exact right wing
for this plane, but the worksheet was already done-so...what.
No idea how the columns will hold up on the net, but .....
it's worth a try...
The spar caps are 1-1/5" X 1/8" 6061 with 1-1/2" x 1/8"
6061 straps layered to the indicated (interpreted) thickness.
Bruce bolted his spar, which produced a very straight spar
assembly.
Hammering big rivets into small structures will invariably
induce some distortion.
We are doing is a beam spar rather than a proper box, so the
sheer web dimension should be doubled.
And?
No promise that any of this is close to correct...
X-Wing SPAR Build .58 R.Lamb 2001
Project Name L-One V
Run time: 01-10-2006 at 10:43:10
Wing Span [ft] 17.00 Root Chord
[ft] 5.00
Wing Area [sqft] 76.50 Tip Chord
[ft] 4.00
Chord thickness [%] 12.00 Mean Chord
[ft] 4.50
Gross Wgt [lb] 888.00 Aspect Ratio
[#] 3.78
Lift (Vs) [lb] 888.00 Wing Loading
[lb/sqft] 11.61
V(min) [mph] 59.04 Max
CL [#] 1.30
Load Factor [G's] 4.00 Spar Width
[inches] 1.50
Cap Compression [psi] 66,000 Shear Web [psi]
10,000
Thickness [% of Chord] 12
Sta W.STA. AIR LOAD SHEAR MOM FTLB
num FT PPF LB FT.LB
1 0.000 232.000 1776.000 7268.000
2 0.850 236.000 1580.000 5842.000
3 1.700 241.000 1389.000 4580.000
4 2.550 246.000 1201.000 3479.000
5 3.400 250.000 1018.000 2536.000
6 4.250 255.000 838.000 1747.000
7 5.100 260.000 663.000 1109.000
8 5.950 264.000 491.000 618.000
9 6.800 269.000 323.000 272.000
10 7.650 273.000 159.000 67.000
11 8.500 278.000 0.000 -1.000
Spar weight parameters:
Sta W.Sta. SPAR HGT CAP THK WEB THK
num FT IN IN IN
1 0.000 5.760 0.306 0.031
2 0.850 5.645 0.251 0.028
3 1.700 5.530 0.201 0.025
4 2.550 5.414 0.156 0.022
5 3.400 5.299 0.116 0.019
6 4.250 5.184 0.082 0.016
7 5.100 5.069 0.053 0.013
8 5.950 4.954 0.030 0.010
9 6.800 4.838 0.014 0.007
10 7.650 4.723 0.003 0.003
11 8.500 4.608 -0.000 0.000
Shear web thickness is for a box type spar. For single web, double
it.
================================================== ======================[/quote]
Old January 15th 06, 03:29 PM
Junior Member
Richard,
Jim Williams
it's worth a try...
assembly.
And?
[ft] 5.00
[ft] 4.00
[ft] 4.50
[#] 3.78
[lb/sqft] 11.61
CL [#] 1.30
[inches] 1.50
10,000
num FT PPF LB FT.LB
num FT IN IN IN
it.
================================================== ======================[/quote][/quote]
