#11
And btw, it was only recently that I learnt that an airplane could also
be landed by looking out the window. A good pilot friend told me that he routinely landed by purely visual references! Until then, I was under the belief that nobody sensible could afford to take his eyes off the instruments in a phase of flight as critical as the final. That's probably because I can't perceive airspeed ![]() Percieving airspeed in jets might be harder (never flown one) but it's generally not too hard in piston singles. Really, as long as you can see the runway, there's no need to use any instruments. Most people (or at least the ones I've flown with, myself included) don't look at anything except the airspeed when in the pattern (and even that is just checked every few seconds or so as a reference). Basically, do you need instruments to stay on the road or maneuver the car while driving? And do you need be constantly looking at the speedometer? Flying is like driving, in a way, just in three dimensions. You do it all on outside cues*. *Obviously, this doesn't include flight in instrument conditions (low visibility, basically). |
Ramapriya wrote:
A good pilot friend told me that he routinely landed by purely visual references! It sounds like you need to get this pilot friend to take you for a ride in a small plane. ![]() -- John T http://sage1solutions.com/TknoFlyer Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
Yes, you can tell when you are turning, etc to an extent. Part of
training requires that you close your eyes, get disoriented, and then recover the aircraft. Most of use rarely actually get disoriented in those tests. However, that is for a short period of time. If you closed your eyes for several minutes you would certainly lose you ability to tell if you were turning or not. -Robert |
"Ramapriya" wrote in message
oups.com... Thanks, Pete. I wasn't asking any specific questions as such, and only wanted to know whether you guys can generally tell these parameters without actually reading them off the instruments. Yup. If anything, obtaining the information from outside references can be easier than using the instruments. The human brain isn't really configured to process numbers, and even an analog gauge doesn't translate directly to human perception. "Airspeed is less difficult than altitude" gives me a definite complex, because that was the one thing I just couldn't estimate at all. As Bob and Bob have pointed out, estimating airspeed in the situation you described is different from estimating airspeed when it really matters. At cruise altitude, you mainly just set your power setting, stay on altitude, and let the airspeed be what it will be (though it should generally always be the same for a given weight and power setting). But during landing, you're close enough to the ground to get a good perception of airspeed, and of course there's all the other points of reference I mentioned. Actually though, movement relative to the ground is the least important reference; even in a jet, your groundspeed can be significantly different from airspeed (and airspeed is what matters, while groundspeed is what you can see), and in a light plane, winds can cause as much as a 50% or more difference in perceived groundspeed versus actual airspeed. But again, as far as airspeed goes, the visual reference is the least important. You can easily tell the actual airspeed from the air noise and from how the controls feel (again, may not apply in an Airbus, where the controls are not directly connected to the control surfaces). And btw, it was only recently that I learnt that an airplane could also be landed by looking out the window. A good pilot friend told me that he routinely landed by purely visual references! Until then, I was under the belief that nobody sensible could afford to take his eyes off the instruments in a phase of flight as critical as the final. That's probably because I can't perceive airspeed ![]() If you actually were flying, I think you'd be surprised at what you can perceive. But yes, visual references is *primary* for all pilots. The instruments are used mainly when the pilot cannot see outside the airplane. Pete |
![]() "Robert M. Gary" wrote in message ups.com... Yes, you can tell when you are turning, etc to an extent. Part of training requires that you close your eyes, get disoriented, and then recover the aircraft. Most of use rarely actually get disoriented in those tests. However, that is for a short period of time. If you closed your eyes for several minutes you would certainly lose you ability to tell if you were turning or not. -Robert Years ago, 26 to be exact, when I first got my PPL I went to an FAA safety seminar which are rarely held locally, I'm the youngest person there by at least 15 years. They have the spinning chair (with a joy stick) where they sit you down, blind fold you and spin you. Your job is to move the stick like it is controlling what you are feeling. The old guys laughed as I was the first and sure enough I steered left when I was either not spinning at all or was spinning the other way. One of the old guys who laughed especially hard was next in the chair and when it was stopped he moved the stick to the right and then the FAA guy said something to him and he turned his head and then he started pulling back on the stick like he was climbing. Being a pilot of many 1000 hours he new this could not be the case so he pushed the stick forward. Laughs were had by all except for the guy in the chair. |
"John T" wrote
Ramapriya wrote: A good pilot friend told me that he routinely landed by purely visual references! It sounds like you need to get this pilot friend to take you for a ride in a small plane. ![]() That's a real problem, He's in Dubai UAE, and I'm in Tampa, Florida. :-) I've been trying to get him to go for a short sightseeing flight for quite a while now. :-) Bob Moore |
Bob Moore wrote:
"John T" wrote Ramapriya wrote: A good pilot friend told me that he routinely landed by purely visual references! It sounds like you need to get this pilot friend to take you for a ride in a small plane. ![]() That's a real problem, He's in Dubai UAE, and I'm in Tampa, Florida. :-) I've been trying to get him to go for a short sightseeing flight for quite a while now. :-) Bob Moore I will, in a few weeks, in that Jet Fox. Watch this space ![]() Ramapriya |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
