Sloshing compound is failing
Old January 16th 06, 03:19 AM posted to rec.aviation.homebuilt
Default Sloshing compound is failing
Jim: I don't believe it is the MEK that is so toxic. I was an organic
chemist for many years. MEK evaporates very quickly and doesn't get
past your skin surface. MEK which may have toluene in it is a different
story. Yes aromatic benzene/toluene is quite toxic.
Larry
Old January 16th 06, 04:12 AM posted to rec.aviation.homebuilt
"Larry" wrote in message
Well, if you are to believe the three websites I googled about the chemical
properties, it its.
Man, anything that dissolves stuff so quickly and completely as MEK, has GOT
to be nasty, bad for you stuff! G
Do a little googling, and report back, as to whether they are full of sh*t,
and if so, why, with some backup references as to why, of course! ;-)
Old January 16th 06, 09:54 PM posted to rec.aviation.homebuilt
Don't use Randolph again. Ever. Use PRC 1005L Buna-N, available from Spruce.
The sealant is diluted in MEK, you pour, slosh, drain excess, let dry
and
you're done, and its impervious to any fuel additives.
I seem to remember the Randolph site says that 912 is no longer
available. I also can't find on the 'Spruce site where PRC 1005L Buna-N
is at all alcohol resistant.
That said, has anyone tried that POR-15 stuff? Or the 'alcohol
resistant' sealer on Hirsch Auto's site? I'm looking since my RV tanks
are over 16 years old and starting to seep.
Old January 17th 06, 05:02 AM posted to rec.aviation.homebuilt
Larry, MEK is very nasty stuff, does get through the skin.
http://www.ilo.org/public/english/pr...1/icsc0179.htm
Larry
Old January 17th 06, 11:06 PM posted to rec.aviation.homebuilt
Uh, it gets past you rskin if it gets inhaled, right?
There are lots of places where the MSDS is posted, usually in .pdf
format:
http://www.palomar.edu/ehs/Chemistry...L%20KETONE.pdf
FF
Peel plying and compound curvature [email protected] Home Built 3 August 10th 05 01:32 AM
compound curves in plywood BA-100 Home Built 58 April 13th 05 05:29 AM
Nut/thread securing compound nauga Home Built 7 April 22nd 04 07:56 AM
Cirrus' "Failing Instruments In Rapid Succession" Marco Leon Piloting 21 April 17th 04 07:47 PM
Randolph Wing Walk Compound Larryskydives Owning 7 March 7th 04 09:44 PM
