Battery health tesing
Old January 23rd 06, 02:57 PM posted to rec.aviation.soaring
Default Battery health tesing
I'm wondering if there's a simple or straightforward way to test an SLA
battery for general condition. Or a device I can buy that sucks a
charge out of a battery over a few hours and reports its actual
amp-hour capacity?
I've built Peter Nyffelers amperehour tester:
http://www.ppc.ethz.ch/~peny/sf/ah_test.html
The simple circuit is easy to build out of standard components.
It discharges the batteries with a fixed constant current until the voltage
is down to 10.5 V then it switches the battery back to the charger.
With a discharge current of 1 A the timer shows the capacity in ampere
hours.(at 1/2 A multiply by two).
This tester is convenient when you take care of a lot of batteries:
- Charge battery (I do this with a second charger)
- Connect the battery
- Reset the hour meter
- press the discharge button
- The next day the battery is fully charged and the hour meter shows you its
capacity.
Sometimes it is possible to revive tired batteries with a few cycles of
discharge and recarge (use a smart 3 phase charger).
If 5 cycles don't help you can give up.
George
Old January 23rd 06, 04:10 PM posted to rec.aviation.soaring
Georg, what is the "M1 Elapsed Time Meter"? This looks like a simple
enough project but I'm not sure I can identify enough of those
components (ask me about software!). I do know how to handle a
soldering iron though...
Old January 23rd 06, 11:38 PM posted to rec.aviation.soaring
It sounds like you are effectively doing an internal resistance measurement.
Exactly. I find that internal resistance is a great measure of the health
of a battery.
Do you have chart of volt drop, load, and good/ok/bad decision for various size
batteries?
No, but I usually consider any drop over a volt or so to be suspect
(assuming an appropriate load for the size of battery). In my work, I often
have the advantage of having identical batteries to compare against each other.
I've not seen that sort of thing in battery data sheets, so I assume you have
to develop the numbers empirically.
True, but for auto-sized batteries the tester I mention (a very common
type) comes with markings that make a great starting point.
Vaughn
Battery Question [email protected] Soaring 19 September 15th 05 01:38 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
