![]() "Bruce" wrote in message ... wrote: Thanks Bill, I just happen to have some 1/8" plexiglass in my shop from when I built my router table, so I have that tool too! I might try and get hold of a carbon fiber blank and use that for a svelt looking panel! Carbon is not a good idea for an instrument panel. In a crash it will be strong enough to break legs before it breaks, and when it does break it will be sharp enough to lacerate efficiently. There are good safety reasons for the BGA recommendation of building a nice, not too strong instrument panel in glass fibre. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. I understand the crash protection concerns but changing materials in an older glider worries me. It's quite possible that the instrument panel is itself a structural member - even if in hindsight that was a bad idea. Replace the solid original with a frangible one and you may have compromised cockpit strength perhaps gaining nothing or even losing a little safety in the process. Old glider are, well, old gliders and there are risks associated with flying them. You get what you pay for. If you really want the latest in crash protection, dust off the checkbook and buy a new one. Bill Daniels |
Bill Daniels wrote:
"Bruce" wrote in message ... wrote: Thanks Bill, I just happen to have some 1/8" plexiglass in my shop from when I built my router table, so I have that tool too! I might try and get hold of a carbon fiber blank and use that for a svelt looking panel! Carbon is not a good idea for an instrument panel. In a crash it will be strong enough to break legs before it breaks, and when it does break it will be sharp enough to lacerate efficiently. There are good safety reasons for the BGA recommendation of building a nice, not too strong instrument panel in glass fibre. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. I understand the crash protection concerns but changing materials in an older glider worries me. It's quite possible that the instrument panel is itself a structural member - even if in hindsight that was a bad idea. Replace the solid original with a frangible one and you may have compromised cockpit strength perhaps gaining nothing or even losing a little safety in the process. Old glider are, well, old gliders and there are risks associated with flying them. You get what you pay for. If you really want the latest in crash protection, dust off the checkbook and buy a new one. Bill Daniels Hi Bill My Cirrus still has the original aluminium panel, partly for this reason. However, if you have decided to play aero engineer and replace it, the current view is that a frangible design is preferable. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. |
Hi Bill - As I understand it, the DG in question currently
has a fiberglass panel. Changing to aluminum would thus be a step backwards in safety. Lets be safe out there, Best Regards, Dave "YO" |
E-Machine is a great service. I have used it to produce
some fairly complicated CNC aluminum parts. They are not cheap, fast (typically 4 weeks) nor will their software handle much in compound curves but then again you don't have to take a course to understand it. At 20:42 28 January 2006, Eric Greenwell wrote: Bill Daniels wrote: Loop this process until you run out of patience or have the exact layout you like. Then, use the final template and the router to cut the actual panel out of your material of choice. If this strikes you as way too much work, use a PC CAD program to lay out the panel and e-mail a .DXF file to a laser cutting shop who will cut the new panel for you. Some will even cut plexi test panels for you to play with. Hint: to get the panel outline right, trace the old panel on a large sheet of graph paper and then transfer the grid points to the CAD program. You take a look at try http://emachineshop.com/, which provides an easy to use CAD program that will provide immediate quotes from the drawing you make. A large choice of materials and finishes is available, including fiberglass sheet. -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 02:41 AM |
Instrument panel labelling options | John Galban | Home Built | 12 | November 18th 04 10:42 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
