"Al" wrote in message
... I was tempted once, but the temptation went away with the altitude...quickly. I lost an engine on a C210 at about 300 ft, on departure. The thing quit like someone had pulled the throttle, which turned out to be very close to reality. In the shock of the moment, I thought about trying a turn, but decided to plant it off the end of my departure runway(I was 3000' down a 4000' runway), instead. The clearway at the end was level and had no large trees. I had already cleaned up the departure flaps, was climbing at 80kts, and the gear doors were just closing when the thing quit. I immediately selected the gear back down, and was flat amazed at the sink rate that developed, no power, windmilling, with the gear in transit. At about 20', still over the runway, I had to hold it off using flaps, to wait for the gear to finish extending. The main gear came over center in the saddles, just as I ran out of elevator, we touched down on the mains, and had to hold the nose gear off long enough for it to extend. I slid onto the numbers at the far end with the gear pump still running to close the doors, and got it stopped. The engine lit off, and we taxied back to the tiedown, and deplaned. It turns out that this aircraft had recently come out of 100hr., and for some reason they had the Airquipt(sp?) hose that runs from the air cleaner to the turbo-charger off. When the mechanic put it back on, he didn't know what to do with the ends of the metal wire that winds around the inside of the hose. He bent each wire end into a little "U" shape, and hooked them together in the middle of the hose. (They should have been placed under the hose clamp at each end) A couple of hours later, with vibration, the glue holding the wire failed, and hooked in the middle the wire collapsed like a slinky, allowing the hose to collapse, shutting off all air to the turbo. What really amazed me was how fast the altitude and airspeed went away. When the thing first quit, I would have sworn I could not get down to my departure runway before going off the end. I was wrong. Wrong by over a thousand feet. Al CFIAMI I never tried it "for real", but had the experience on one "simulation" about 25 years ago. I was a student pilot in a Cessna 150M, with an instructor. And, I suppose that I had always been visibly nervous regarding the "what if the engine quits" scenario. In any case, we took off into a head wind of around 12 knots (on the ground) from a 3000 foot paved runway on a little "training only" airport. The instructor said to climb until I believed that I could make it back to land on the reciprocal, then pull the power and try it. I really doubt that such a demonstration was approved, much less encouraged, even then; and it may have been my first attempt at a down wind landing as well! In any event, we climbed to a little more than 350 feet before I pulled the power to idle; and promptly began my turn back tothe runway. As I mentioned, I had heard all of those horror stories about how it was suicidal to attempt a turn greater than 90 degrees; and this required a turn or at least 225 degrees, a short straight glide, and then about 45 degrees back the other way--all before the final glide, flap extension, and flare. I did not simulate the customary 4 seconds of disbelief, nor did I simulate a reasonable period of indicision regarding what to do next--to turn or not to turn was never the question--I just applied the carburetor heat, pushed the nose over, and cranked it into the turn ... and the limitations of my chosen procedure only gradually became apparent. Now, I should mention that I am not really a fan of high winged aircraft. I admit that they have their practical side--lighter structure for a given strength, ease of undercarriage inspection, and the wing is well clear of most of the "stuff" on an narrow and unimproved runway. Still, as I said, I am not a fan. A wing is really a think that one should sit upon; it is not a thing that one should attempt to look through. So, I continued around the turn, still at a safe altitude and with the engine idling smoothly, and the runway eventually came into view. And I continued around, still at a safe, and saw that I was really not far from the runway at all. Therefore, I continued the turn to about the 270 degree point before making a roll reversal--and finally getting the flaps down. By then, I was just about over the runway and diving with full flaps. It then became intuitively obvious, to even the most casual observer, that I was much too high. As to the outcome? We flew away without lnading. One of these days I still plan to get back to flying, and to make the transition from former student to current pilot. Until then, there are memories of a time when flying was more innocent, a little crazier, and a lot more fun! Peter |
Al wrote:
I was tempted once, but the temptation went away with the altitude...quickly. I lost an engine on a C210 at about 300 ft, on departure. The thing quit like someone had pulled the throttle, which turned out to be very close to reality. In the shock of the moment, I thought about trying a turn, but decided to plant it off the end of my departure runway(I was 3000' down a 4000' runway), instead. The clearway at the end was level and had no large trees. I had already cleaned up the departure flaps, was climbing at 80kts, and the gear doors were just closing when the thing quit. I immediately selected the gear back down, and was flat amazed at the sink rate that developed, no power, windmilling, with the gear in transit. At about 20', still over the runway, I had to hold it off using flaps, to wait for the gear to finish extending. The main gear came over center in the saddles, just as I ran out of elevator, we touched down on the mains, and had to hold the nose gear off long enough for it to extend. I slid onto the numbers at the far end with the gear pump still running to close the doors, and got it stopped. The engine lit off, and we taxied back to the tiedown, and deplaned. It turns out that this aircraft had recently come out of 100hr., and for some reason they had the Airquipt(sp?) hose that runs from the air cleaner to the turbo-charger off. When the mechanic put it back on, he didn't know what to do with the ends of the metal wire that winds around the inside of the hose. He bent each wire end into a little "U" shape, and hooked them together in the middle of the hose. (They should have been placed under the hose clamp at each end) A couple of hours later, with vibration, the glue holding the wire failed, and hooked in the middle the wire collapsed like a slinky, allowing the hose to collapse, shutting off all air to the turbo. What really amazed me was how fast the altitude and airspeed went away. When the thing first quit, I would have sworn I could not get down to my departure runway before going off the end. I was wrong. Wrong by over a thousand feet. Al CFIAMI "kd5sak" wrote in message m... "Dave S" wrote in message link.net... JJS wrote: The SQ2000 guy was flying a rotary (mazda derivative) engine that had what the rotary community believes was an intermittent fuel supply program and was in flight test at the time. The aircraft had made one dead-stick due to what the community assumed was a vapor lock. This was a fairly low altitude turn back and landing on-field but off-runway. After some re-work on the fuel system he went up again, and on one of the subsequent flights weeks later lost power very low, and tried to make another low turn back to the runway. He ended up in trees. Same tactic killed Wiley Post and Will Rogers. Don't fly myself, but in a lifetime of reading I've seen several references to crashes occuring from pilots trying to turn back to a runway I I just read (somewhere fairly recently) that Will & Wileys floats were leaking,took on enough water that ran to the rear on take-off creating a BAD rear CG, that they couldn't recover from. (sounds reasonable to me, they could have been getting by with it, draining the floats after they were airborne each time) when they had a reasonably flat bit of terrain in front of them. It's been said that Post knew better, but had the family fortune tied up in the plane he and Will were traveling in and just let that drive his decision making. What do some of you actual pilots think? Harold KD5SAK |
![]() "kd5sak" wrote in message m... Same tactic killed Wiley Post and Will Rogers. Don't fly myself, but in a lifetime of reading I've seen several references to crashes occuring from pilots trying to turn back to a runway when they had a reasonably flat bit of terrain in front of them. It's been said that Post knew better, but had the family fortune tied up in the plane he and Will were traveling in and just let that drive his decision making. What do some of you actual pilots think? Harold KD5SAK It seems to me that when I learned to fly the normal landing was a "power off" landing. You always cut the power on the downwind leg heading away from the airport and from the end of the runway. Then, after a little while, you proceeded to make a 180 degree turn back to the airport and landed. This was done with the engine cut to idle. Sometimes, they cut even beyond idle and quit completely! :-) It was called a normal landing and you were supposed to do all of them that way. Clearly there is some altitude and distance from the end of the runway where a "turnback" type maneuver is no problem at all, and actually closely approximates the normal landing of my youth. Equally clearly there is also some altitude and distance from the end of the runway where such a "turnback" maneuver is clearly impossible. Obviously the trick is knowing exactly where in the range between A and B that you are at the moment the engine quits and behaving accordingly. Most flight instructors cop out totally and just say "Go straight ahead." Personally, I have had engine failures on "takeoff" where straight ahead was best. I have had engine failures on "takeoff" where "turnback" was best. And I even had ONE engine failure on "takeoff" where neither "turnback" nor "straight ahead" would work and I had to do something creative! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
![]() "Highflyer" wrote in message ... "kd5sak" wrote in message m... Personally, I have had engine failures on "takeoff" where straight ahead was best. I have had engine failures on "takeoff" where "turnback" was best. And I even had ONE engine failure on "takeoff" where neither "turnback" nor "straight ahead" would work and I had to do something creative! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) Hmmm, I imagine one could add a bank left or right and center the bubble, what was the right choice when neither turn back or go straight was correct? You have my curiosity itching something fierce. Harold KD5SAK |
Highflyer wrote:
snipped Personally, I have had engine failures on "takeoff" where straight ahead was best. I have had engine failures on "takeoff" where "turnback" was best. And I even had ONE engine failure on "takeoff" where neither "turnback" nor "straight ahead" would work and I had to do something creative! :-) Hi, my name is HF, and I'm an airplane adict... Come on, Confess! It's "I learned about flying from that" time. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) BTW, where ya been? Richard |
![]() "Highflyer" wrote in message ... "kd5sak" wrote in message m... Personally, I have had engine failures on "takeoff" where straight ahead was best. I have had engine failures on "takeoff" where "turnback" was best. And I even had ONE engine failure on "takeoff" where neither "turnback" nor "straight ahead" would work and I had to do something creative! :-) ok, now fess up! add my name to the list of those who want to know. I guess you did something that violates have a dozen rules, otherwise you'd say so. forced spin? a outside loop? immelman? stall-drop? |
The informal group also found that he was significantly aft CG.
![]() "Dave S" wrote in message nk.net... The SQ2000 guy was flying a rotary (mazda derivative) engine that had what the rotary community believes was an intermittent fuel supply program and was in flight test at the time. The aircraft had made one dead-stick due to what the community assumed was a vapor lock. This was a fairly low altitude turn back and landing on-field but off-runway. After some re-work on the fuel system he went up again, and on one of the subsequent flights weeks later lost power very low, and tried to make another low turn back to the runway. He ended up in trees. The rotary powered aircraft community participated in both the NTSB investigation and afterwards several purchased the airframe from the widow and did additional information gathering. Nothing definitive was determined from a cause standpoint, but one of the fuel injectors (which was used, not new) was found to be faulty from a flow standpoint. Dave S It makes me feel bad that I can't recall his name. I tried a Google search of the newsgroup archives and didn't find it. Joe Schneider 8437R ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Joe Schneider
It makes me feel bad that I can't recall his name. I tried a Google search of the newsgroup archives and didn't find it. Google "N2992". Dave S. wrote: The SQ2000 guy was flying a rotary (mazda derivative) engine ...... Nothing definitive was determined from a cause standpoint, but one of the fuel injectors (which was used, not new) was found to be faulty from a flow standpoint. That is slightly misleading. If you're talking about what caused the engine to stop producing power, there were a few likely possibilities. If you're talking about why the aircraft crashed the way it did, the answer was pretty clear. For those interested, see: http://www.cozybuilders.org/N2992_Ac...val/index.html for an alternative (and IMNSHO, a far more accurate) evaluation. -- Marc J. Zeitlin http://www.cozybuilders.org/ Copyright (c) 2006 |
Thanks for the link, Marc..
For the record I will state that my post regarding this was unresearched, and from memory alone. I am actually thankful for the time and work that the rotary community put into investigating his accident. Dave |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
1 Fatal ...r.a.h or r.a.p? | Montblack | Piloting | 38 | February 9th 06 02:00 PM |
Fatal Injury: hit by the prop | [email protected] | Piloting | 43 | January 27th 05 04:26 PM |
Pilot's 2nd Fatal Accident | Aardvark | Piloting | 44 | May 21st 04 02:34 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
