#11
The MX-170 is newer technology than the KX-170, flip flop memories,
etc... I have upgraded the existing radios on Fat Albert with the slide in TKM series radios and been satisfied... denny |
Robert M. Gary wrote:
: Do you think there is any value in the MX-170? The display seems very : effected by moisture. For the last couple of years it would be dark : during run up and would slowly come back after the moisture was driven : out of the cabin. Today, it went to 100.00 on all 4 freqs in : mid-flight. The company that makes it (TKM) refuses to fix it because : they want me to buy their new model and they don't offer the manuals so : no shop can legally work on it. Its too bad too. I had the exact same : problem with my KX-155, the shop simply replaced the display for a very : reasonable amount of money. In my opinion, TKM are just being butts : about this. I had a friend that got screwed out of his radio in the same way. Bought an ebay-special MX-170 that worked, but had a little display problem and the volume was a little low. Sent it to Michel since they would supposedly fix it for a flat rate (something like $200 or something IIRC). Well, they sat on the radio giving bullsh*t stories of how it was ready, no there was more broken, now it was in final adjustment stage, and finally he was told he had to buy a new one. Couldn't even get the old one back unless he paid about 1/2 the cost of a new one in labor for diagnostics. He also had a MX-12. After getting screwed on the MX-170, I volunteered to look inside a bit. They are built much cheaper than King units.... regular COTS ICs, sockets, ribbon cables, LEDs, etc. That's cheap and easily fixable: as long as you can get them to fix it or give you the info to do so yourself. Ribbon cables aren't chafe-protected, non-gold-plated connectors, cheesy DIP sockets for many ICs, etc. If you look inside a King unit, they're built to avionics standards... not cheapo consumer VCR standards. My recommendation: Don't by Michel anything. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
I have an odd ball digital replacement 170B that is no longer servicable. Since I already have the 155 and and moving map GPS, I need a basic, inexpensive, nav/com hole filller for it as #3 radio. I really like having it there. What type of used equipment is out there that is a slide-in 170B replacement. Are there any of those digital MX170Bs still around ? Anyone recommend a seller of inexpensive, used TSO radios? A few years ago I found that Gulf Coast Avionics' prices and policies on used radios were resonable. Dave |
can get them to fix it or give you the info to do so yourself. Ribbon cables aren't chafe-protected, Chafe-protected against what? non-gold-plated connectors Tin on tin is every bit as good as gold on gold in the avionics environment. cheesy DIP sockets for many ICs, etc. What does a non-cheesy DIP socket look like? And why in the world would you ever socket an IC? If you look inside a King unit, they're built to avionics standards... not cheapo consumer VCR standards. How many devices have you built and marketed to avionics standards? And where are these standards posted or documented? -Cory You've been a grad student now for about four years as I count. Ever plan on finishing up? Jim -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Why not just get a real KX-170B?
I did considered that. Although I"d be giving up the digital flip/flop I'd be getting a much more reliable radio (according from our local avionics shop). However, they just told me that there are many KX-170B parts that are now also getting pretty hard to find. Since MAC1700 is no longe producing parts, it looks like MX is the only company currently producing parts for 170B replacements. ![]() convince them to service my old one. Its actually quite a funky radio. The buttonology is just different than anything else. The top of the radio is comm and the bottom is nav. However, the top knob works big numbers and the bottom works the decimals. There is a C/N button that flips between com/nav for the knobs. Not what you'd expect. Also, if you turn the nav off the display is still active. The display on the nav turns off when you turn the comm off. -Robert |
![]() "Robert M. Gary" wrote in message oups.com... Why not just get a real KX-170B? Its actually quite a funky radio. The buttonology is just different than anything else. The top of the radio is comm and the bottom is nav. However, the top knob works big numbers and the bottom works the decimals. There is a C/N button that flips between com/nav for the knobs. Not what you'd expect. Also, if you turn the nav off the display is still active. The display on the nav turns off when you turn the comm off. I'd be willing to bet one of two things. The user interface was either (a) designed by a good engineer that wasn't a pilot or (b) an engineer two days out of college. Nobody familiar with avionics would have made those blunders. Jim |
: Chafe-protected against what?
Wire on metal inside the radio. They're not tied down to anything and are free to flap against other parts inside the radio. : Tin on tin is every bit as good as gold on gold in the avionics environment. OK. Sure.... and the crappy little consumer-grade EGT/CHT switches that came with my multi-cylinder aren't actually exhibiting poor contact resistance already after only 2.5 years either. I'm not buying it... There *IS* a reason for MIL-SPEC components. : What does a non-cheesy DIP socket look like? And why in the world would you : ever socket an IC? As you well know, there are high-quality sockets and low-quality sockets. One wouldn't think that socketing ICs are too necessary, yet the Michel radios had them. : How many devices have you built and marketed to avionics standards? And : where are these standards posted or documented? A personal attack? I would expect more. To answer the question though, absolutely zero devices have been marketed. I've designed a few ( 5 ) to go on experimental research rocket payloads. I have designed a number of circuits for use in an automotive environment for a hybrid electric research vehicle ( 10 ). I have repaired even more on the same project due to crappy construction quality of circuits designed by previous people similar to what I've seen in Michel units. I have been involved with designing and building electrical power electronic circuits switching over 50kW and have seen the ramification of ill-constructed circuitry. I have been inside a number of King, Narco, Dave Clark, and Michel avionics and the Michel units are sub-standard in construction quality by comparison. : You've been a grad student now for about four years as I count. Ever plan : on finishing up? No. I enjoy keeping an open mind and continually learning about as much as I possibly can. I will never finish being a "student." -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() "RST Engineering" wrote in message .. . non-gold-plated connectors Tin on tin is every bit as good as gold on gold in the avionics environment. I respect your background, and I am not an avionics engineer (and do not play one on TV) but this is directly opposite to my experience. I will never bother with a non-gold card edge connector again. cheesy DIP sockets for many ICs, etc. What does a non-cheesy DIP socket look like? I have had grief with cheap IC sockets. The difference can be pennies per unit. And why in the world would you ever socket an IC? Here, we agree. You've been a grad student now for about four years as I count. Ever plan on finishing up? I spent at least 4 years on my Master's, given that life continued to go on and I still needed a job to feed my family. The Ph.D (if I had continued) would have taken longer. Vaughn |
"Vaughn" writes:
And why in the world would you ever socket an IC? Here, we agree. You socket the IC where your evaluation tells you it's necessity for replacement overcomes the added issues with a socket. I designed my boards with the vulnerable IC's in GOOD, gold-plated sockets. I can't recall the brand now; but they were circular concentric pins held in a strip of plastic. Not cheap. The vulnerable ones to me were those that interfaced OFF the board, to the real world. They took the abuse & died for the cause every so often. YMMV. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Ya know, it's interesting all the opinions, heated and otherwise, that
you read here... Yup, I agree that the TKM knobs are not idiot proof.. It requires a good 60 seconds of reading the manual to figger em out... To repeat, I replaced my electromechanical radios with TKM slide ins from Eastern Avionics... Been perfectly happy... And, even at my advanced age I can remember from one flight to the next how to tune em... And it cost me 10% of hanging a new set of Garmins... Happy about that too... denny |
kx170b | Ernesto Sanchez | Home Built | 0 | July 1st 05 05:43 AM |
Options | [email protected] | Soaring | 32 | March 14th 05 05:33 PM |
Cobra Trailer Axel Replacement | Carter | Soaring | 7 | July 7th 04 02:06 PM |
New Army Aviation Options? | Thomas Schoene | Military Aviation | 22 | February 29th 04 09:51 PM |
TKM MX-11 Com true slide replacement ? | Rohit Fedane | Owning | 0 | September 21st 03 05:02 PM |
