#11
Matt Whiting wrote:
Kyle Boatright wrote: "Nik" wrote in message ups.com... Ok thank you... How would you say the intentions though? -Nik "Your Location Traffic, NXYZ is going around due to departing traffic on Runway **, will fly an upwind on the Right side of Runway **." I'd probably say I was going around due to a fool on the runway, but otherwise I concur with what you suggest. :-) I normally unkey the mic and THEN say what I really want... :-) |
In article . com,
"Nik" wrote: What would you do in the following situtation: You are approaching a non towered field, communicate right and all that stuff, your on final, suddenly a cessna pulls up and starts it's take off roll. Also lets bring the same situation to a towered airport where the controller tells you to go around while you are on final. I am asking this because I am just wondering that at some point the aircraft could collide (one climbing out, the other at pattern altitude), and what the pilot going around should do... Power up, pitch up, flaps up. If you are in a retract, leave the gear down, your Vx and Vy speeds will be lower and you won't have to worry about forgetting in on the next circuit. Fly to the right of the departing aircraft. Allow the departing aircraft to accelerate ahead of you. Turn left, enter the pattern and land normally. Why follow the departing aircraft? You are ready to land. |
Rachel wrote:
Matt Whiting wrote: Kyle Boatright wrote: "Nik" wrote in message ups.com... Ok thank you... How would you say the intentions though? -Nik "Your Location Traffic, NXYZ is going around due to departing traffic on Runway **, will fly an upwind on the Right side of Runway **." I'd probably say I was going around due to a fool on the runway, but otherwise I concur with what you suggest. :-) I normally unkey the mic and THEN say what I really want... :-) Why unkey the mic? Matt |
Nik wrote:
What would you do in the following situtation: You are approaching a non towered field, communicate right and all that stuff, your on final, suddenly a cessna pulls up and starts it's take off roll. You go around. I make a standard procedure of keeping to the right of the runway during all go-arounds, sometimes informally called a "sidestep." At a towered field you may be asked to go around and not told why. Keeping right lets you keep the runway in view out your left window and gets you out of the way of any other aircraft that may be landing/taking off until you can maintain visual contact to avoid them. You don't have to go far to the right, just enough to allow you to see the runway and be out of the way for any fast climbers. It's normal to stay to the RIGHT of the runway. This is especially useful when you find yourself on a nice final approach and then notice that some clown decided to land downwind on the opposing runway. Both aircraft can go around and be out of each other's way and be safe. Obviously if there are parallel runways in use or other special circumstances (obstacles) the procedure may differ. Practice go-arounds often at different phases of landing. Know what your airplane requires (flaps set x degrees? Carb heat off? Mixture is already rich? Prop is already forward? Gear up? Full power? Spoilers retracted?) by heart. |
"Nik" wrote in message Ok thank you... How would you say the intentions though? -Nik "Your Location Traffic, NXYZ is going around due to departing traffic on Runway **, will fly an upwind on the Right side of Runway **." I'd bet that you'd want less words and sooner! Something on the order of... "location, NXYZ, going around, right of XXX" (this assumes that runway XXX is not on the left side of a parallel runway...) Get out of the way. If at a towered airport, and they tell you to go around, don't bother with all the details, just agree, something like "NXYZ going around" because they'll probably tell you which side to offset, or even more detailed instructions, such as "go around IMMEDIATELY, turn (left or right) as soon as possible, wait for further instructions" yes, I've had this happen to me when an aircraft broke down on the runway. They sent us all out to the SE or SW with instructions to go away for a while. |
Matt Whiting wrote:
Rachel wrote: Matt Whiting wrote: Kyle Boatright wrote: "Nik" wrote in message ups.com... Ok thank you... How would you say the intentions though? -Nik "Your Location Traffic, NXYZ is going around due to departing traffic on Runway **, will fly an upwind on the Right side of Runway **." I'd probably say I was going around due to a fool on the runway, but otherwise I concur with what you suggest. :-) I normally unkey the mic and THEN say what I really want... :-) Why unkey the mic? Matt Controllers tend to get angry when you swear on the radio. |
![]() "Nik" wrote in message ups.com... What would you do in the following situtation: You are approaching a non towered field, communicate right and all that stuff, your on final, suddenly a cessna pulls up and starts it's take off roll. I'd either land or go around, it depends on how much room I'll have behind the Cessna. Also lets bring the same situation to a towered airport where the controller tells you to go around while you are on final. If I'm VFR or on a visual approach I'll overfly the runway while climbing to traffic pattern altitude and enter the traffic pattern via the crosswind leg, unless given other instructions by the controller. If I'm on an instrument approach I'll execute the published missed approach procedure or proceed as instructed by the controller. I am asking this because I am just wondering that at some point the aircraft could collide (one climbing out, the other at pattern altitude), and what the pilot going around should do... I'd avoid colliding. |
![]() "Kyle Boatright" wrote in message . .. In both cases, announce your intentions, offset your approach and fly an upwind leg (typically to the right of the runway centerline). You should adjust your upwind leg to keep the rogue aircraft/pilot in view until it is no longer a collision threat. At a controlled field, unless told otherwise, you should overfly the runway while climbing to traffic pattern altitude. |
![]() "Matt Whiting" wrote in message ... I'd probably say I was going around due to a fool on the runway, but otherwise I concur with what you suggest. :-) What did you see in the OP that suggested the departing pilot was a fool? |
Nik wrote:
What would you do in the following situtation: You are approaching a non towered field, communicate right and all that stuff, your on final, suddenly a cessna pulls up and starts it's take off roll. Depends on other factors, especially WHERE on final I am. Other than that, most of these types of questions are pointless. G |
