DG AD NOTE
Old February 15th 06, 08:14 PM posted to rec.aviation.soaring
Default DG AD NOTE
ok, maybe not automatic, but it shouldn't take couple of years to
approve a fix to prevent a rudder from falling off, and then only
notify owners of certified gliders, as if identical glider which was
not certified but is legal to fly can continue fly safely without the
fix...
Ramy
Old February 15th 06, 08:38 PM posted to rec.aviation.soaring
Default DG AD NOTE
fix...
Actually, the AD came out rather quickly (only a year!), given the time
frames the FAA normally operates with. In this case, there are 1000+
aircraft covered by the TN, ranging in age up to 30 years, but likely
only one or two actual instances of failure, none of which apparently
happened in flight. I think they got the trade-offs right.
With a potentially serious safety problem, the FAA will simply ground
all of the aircraft immediately (as they did with the Duos), then sort
out the paperwork and repair issues with the manufacturer at a
(slightly) accelerated pace. I wouldn't consider that a desirable
approach for this rudder mounting problem.
If one owns a glider with a special airworthiness certificate, one
assumes responsibility to check with the manufacturer for relevant
technical notes and service bulletins, as is clearly spelled out in the
operating limitations. If one wants the FAA to monitor these things,
one should buy a type certificated glider...
Marc
Old February 15th 06, 09:07 PM posted to rec.aviation.soaring
Default DG AD NOTE
As a 300 owner, I received a written notification from the FAA about a
year ago called a "Special Information Bulletin" that directed me to
the DG TN. So, although they did not issue an AD for 300's, they do
have a system in place to notify registered non type certificated
owners. I'm happy not to have the FAA any more involved in the
operation of my glider. Especially in the case of DG, it is very easy
to go online to check the current TN list for any model.
John
Marc
FAA Advice request: Plus a GlaStar note Tim Hickey Home Built 1 April 4th 05 02:38 PM
Why was the Fokker D VII A Good Plane? Matthew G. Saroff Military Aviation 111 May 4th 04 06:34 PM
Note from a Sick Puppy Veeduber Home Built 4 March 21st 04 11:43 PM
A note to Roger Halstead The Boz Simulators 1 January 9th 04 03:23 AM
Duo Discus Tech note Thomas Knauff Soaring 25 August 9th 03 11:10 PM
