Gene Whitt is back on line
Old February 20th 06, 01:03 PM posted to rec.aviation.ifr
Default Gene Whitt is back on line
"Robert Chambers" wrote in message
om...
seriously? banning leaning below 5000'? I guess they enjoy cleaning lead
fouled plugs then.
You have to remember, though, that many pilots and even mechanics think lead
fouling is caused by leaning TOO MUCH, not too LITTLE.
I can't fathom some blanket rule like that, they should be teaching proper
leaning techniques not banning the use of it.
Standard procedures in many (most?) places says 50 or so ROP...about the
worst place you can run your engine.
Old February 20th 06, 02:03 PM posted to rec.aviation.ifr
That's where I was taught to lean to. I think the reason was that it is
a safe place, whereas lean of peak has some advantages, but can get you
into trouble with detonation if you are not really careful.
Any suggestions?
Brad
Old February 20th 06, 02:18 PM posted to rec.aviation.ifr
Default Leaning (was Gene Whitt is back on line)
If it really =is= the worst place, how did the engine makers come to
reccomend it?
Jose
Money: what you need when you run out of brains.
Old February 20th 06, 02:35 PM posted to rec.aviation.ifr
At low cruise settings, lean to get roughness (miss-firing
of the leanest cylinder) and then richen to smooth. You
have to do it very gently, just pressure on the mixture or
you'll over-shoot the settings. That is with a carb. If
you have fuel injection, it will run smooth until it quits,
follow the tables for fuel flow from the manual or use the
EGT.
For take-off above 3,000-5,000 feet density, you should lean
to get the proper mixture and max power.
James H. Macklin
ATP,CFI,A&P
some support
"bsalai" wrote in message
ROP...about the
was that it is
but can get you
careful.
| Any suggestions?
| Brad
Old February 20th 06, 02:40 PM posted to rec.aviation.ifr
50 RPM drop on the rich side is too rich at cruise... 50
degrees rich of peak on the EGT is about right with a carb.
With fuel injection, just a little below peak or even at
peak if the cruise power is set below 70%. At low power
settings you can run at peak since the actual temperatures
will be low. If you have a calibrated EGT (TIT) follow the
limits.
James H. Macklin
ATP,CFI,A&P
some support
"Jose" wrote in message
. net...
ROP...about the
makers come to
| reccomend it?
| Jose
Old February 20th 06, 03:22 PM posted to rec.aviation.ifr
John,
Several of the operations I know here actually ban
leaning below 5000 feet.
Change operations! Run, don't walk!
Thomas Borchert (EDDH)
Jim,
limits.
Ok, kids, now lets count all the misunderstandings and factually wrong
statements in that post. Hint: There are at least 5.
Bsalai,
Any suggestions?
Uhm, get educated! For starters, read John Deakin's columns on engine
management at www.avweb.com
Old February 20th 06, 03:30 PM posted to rec.aviation.ifr
I've never heard of leaning to an RPM drop... just to an EGT drop.
Why is fuel injection different? More even mixtures across the cylinders?
Jose
Old February 20th 06, 03:41 PM posted to rec.aviation.ifr
Yes, engine roughness is caused by one cylinder misfiring.
Fuel injection is properly calibrated is the same on all
cylinders so the engine runs smooth and balanced.
om...
EGT drop.
| Jose
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Dawley Aviation PIREP, or: Atlas is BACK Jay Honeck Owning 33 January 4th 06 03:05 PM
1343 NM to the NASM Udvar-Hazy Center and back... Jay Honeck Piloting 25 June 18th 05 05:07 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 10:29 AM
