![]() Chris Wells wrote: I've got a radio-controlled helicopter that could snatch that prize easily, with those specifications. -- Chris Wells Yeah, Those rules need to tightened up considerably. Any Heli could do it. I suspect he means "in an airless environment". But let's not tell him. He leaves it that way, somone will be instantly rich as soon as the rules are published. Harry K |
Chris Wells wrote:
I've got a radio-controlled helicopter that could snatch that prize easily, with those specifications. Did any of you guys claiming that this is so trivial actually read the rules? It explicitly states: "3.2.18.1 Take-off vertically under only rocket power from Point A. No aerodynamic or air-breathing methods of hovering, propulsion, or landing are permitted except in the case of abort." "3.2.18.7 Take-off vertically under only rocket power from Point B. No aerodynamic or air-breathing methods of hovering, propulsion, or landing are permitted except in the case of abort." Unless you've got a rocket powered helicopter that doesn't use aerodynamics for lift, you could snatch nothing easily. -- Marc J. Zeitlin http://www.cozybuilders.org/ Copyright (c) 2006 |
McCain Condemns Anti-Kerry Ad | WalterM140 | Military Aviation | 2 | August 11th 04 05:25 AM |
OT (sorta): Bush Will Announce New Space Missions | Dav1936531 | Military Aviation | 0 | January 9th 04 10:34 AM |
Bush to return NASA to moon | Aerophotos | Military Aviation | 51 | December 9th 03 07:43 AM |
Russia & India to send joint manned mission to Moon | Michael Petukhov | Military Aviation | 84 | November 20th 03 11:04 PM |
Burt Rutan "pissed off" | Tarver Engineering | Military Aviation | 22 | September 3rd 03 04:10 AM |
