Cherokee 180 soft brake - causes?
Old February 26th 06, 01:50 AM posted to rec.aviation.owning
Default Cherokee 180 soft brake - causes?
Jay Honeck wrote:
Our A&P hates bleeding Cherokee brakes, but it's more of a repetitive
pain than a really difficult procedure. He just climbs under the wing,
holds the line (or brake assembly?), and has me pump the brakes until
nothing but fluid comes out. It can take several pumps, and uses a bit
of brake fluid, but it works well. (I've not seen what he's doing under
there, since I'm inside the plane, but he's catching the fluid in a
container of some sort.)
They can't be bled from the bottom up?
They can, but this is my A&P's method of preventing the OP's problem of
eternally soft brakes. It apparently ensures that no air is left hiding
anywhere in the system.
I know, that's why you do it from the bottom up, no pumping the brakes
required. My mechaninic rebuilt my left main strut this week and since
that requires disassembly of the brake system on that side I helped him
today bleed the brakes. Reason #6458 why Beech has the reputation they
do for quality and good engineering and design. The reservoir is on the
firewall, no having to wiggle over the front seats to wait for the fluid
to come squirting out onto your carpet.
Old February 26th 06, 02:55 PM posted to rec.aviation.owning
Newps wrote:
: I know, that's why you do it from the bottom up, no pumping the brakes
: required. My mechaninic rebuilt my left main strut this week and since
: that requires disassembly of the brake system on that side I helped him
: today bleed the brakes. Reason #6458 why Beech has the reputation they
: do for quality and good engineering and design. The reservoir is on the
: firewall, no having to wiggle over the front seats to wait for the fluid
: to come squirting out onto your carpet.
Not to argue since all I know is heresay at this point, but my mechanic had
problems bleeding a guy's cherokee *even though* they were bleeding bottom-up.
Top-down, bottom-up, it didn't seem to matter.... they couldn't get all the air out.
Ended up having to replace some weird seal/gasket/valve thingy (don't know the
specifics). Apparently it's a common thing to have to replace... maybe why all the
FUD about bleeding Cherokee brakes. Perhaps it's only a PITA if this other thing is
broken. Sounds like Jay doesn't have any trouble.
-Cory
* Cory Papenfuss *
Old February 27th 06, 01:51 AM posted to rec.aviation.owning
On Sun, 26 Feb 2006 14:55:26 +0000 (UTC),
snip
really depends where the air is trapped in the system. the primary
problem with the Cherokee's is the fluid inlet to the toe cylinders is
on the bottom of the near-vertically mounted cylinder (and goes "up"
to the handbrake and reservoir). the outlet is on the top, and goes
"down" to the calipers.
pressure bleeding from the reservoir or from the caliper is
problematic due to this routing. a little air here or there can
usually be worked out, but if there is a lot of air trapped, the
quickest solution is to remove the toe cylinders (mechanically, not
hydraulically) and invert them. a pressure pot from the bottom will
then clear the lines fairly rapidly.
the nastiest one I ever worked was on a Cheyenne that wouldn't leak
fluid out static or under applied brake pressure, but would leak air
in when the cabin was pressurized. if I hadn't had seen it, I never
would have believed it.
TC
Old February 27th 06, 04:32 PM posted to rec.aviation.owning
Mike Noel wrote:
: I think
: the problem can develop because of corrosion caused by water absorbed by the
: brake fluid over time.
Aircraft brake fluid is hydraulic OIL, and does not absorb water in the
same manner that automotive brake fluids do.
Aaron C.
Old February 28th 06, 02:54 AM posted to rec.aviation.owning
Aaron Coolidge writes:
Wow; I'm surprised.... I'd think oil would absorb air far too easily.
That's SURE to cause spongy brakes...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old February 28th 06, 04:41 AM posted to rec.aviation.owning
"David Lesher" wrote in message
I've never seen or heard of oil absorbing air.
Old February 28th 06, 04:28 PM posted to rec.aviation.owning
"Dave Stadt" writes:
Well, overfill a crankcase and watch the oil get whipped into a
froth, and rapidly lose its lubrication qualities...
Automotive brake fluid was, ISTM, the very first federal
automotive safety standard. It must have:
High boiling point
low air absorbation
compatability with rubber lines and seals
There were a few cars, but VERY few, that needed non-standard brake
fluid. One was a friend's Hillman Minx (Mynx?) that Goodyear or
Firestone or such had put DOT-3 in; every seal was gone. The other
was the Citroen DS with master hydraulic pump that ran brakes,
steering, suspension and transmission. It used exotic "green blood"
and every owner carried a spare 10 litres or so...just in case...
Old February 28th 06, 05:05 PM posted to rec.aviation.owning
That's not exactly what could happen in a brake circuit. We are talking
brake circuits not crankcase. Leave oil exposed to the atmosphere and it
does not absorb air.
Traditional automotive brake fluid is alcohol based and is hydroscopic. A
can will become useless in a matter of hours if not tightly capped. It is
not oil based.
High boiling point
low air absorbation
Anybody that drove or drives a Citroen needs more than 10 litres of green
blood. A Priest, a tow truck and a credit card with no limit is a good
place to start.
Old March 1st 06, 03:04 AM posted to rec.aviation.owning
Nope, just water..... but in any case the key issue is having a
fluid that has very low compressibility even at high temperatures.
(Look at the NOVA series on the 777; the rejected-takeoff test has
the solid carbon rotors glowiing bright orange as the rims melt...now
THAT'S hot....). Even a small amount of suspended air makes it
compressable. And oil, unlike brake fluid, does not err ?stratify?
well.
not oil based.
Ahem.. it's not alcohol-based; it's glycol based. (Except DOT-5 which is silicon..)
High boiling point
low air absorbation
place to start.
Not at all; you merely need 2 tools: a cell phone and a pickup
w/trailer. Just like any MG/Jag owner...
Cherokee Pilots Association Fly-In Just Gets Better and Better Jay Honeck Piloting 7 August 8th 05 07:18 PM
Cherokee National Fly-In & Convention Don General Aviation 0 May 5th 04 08:12 PM
Cherokee National Fly-In & Convention Don Piloting 1 March 20th 04 05:27 AM
Cherokee National Fly-In & Convention Don General Aviation 0 March 20th 04 02:15 AM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 06:15 PM
