Nav Lights using Luxeon LEDs
Old February 25th 06, 12:10 AM posted to rec.aviation.homebuilt
Default Nav Lights using Luxeon LEDs
Recently I designed and built a nav light system for my Europa aircraft
using the Luxeon LEDs with great results.
I also measured the radiation pattern (after fitting the LEDs to the
aircraft) and compared it to the FAR specs. It exceeds the requirements
by 3-5 times, and draw only 2 Amps total. It is bright enough to almost
use as a landing light.
Actually, I am surprised that most manufacturers do not provide a
measured radiation pattern. They just say that it complies with the
FAR. Well, meeting the specs is not the same as exceeding it. Since
LEDs lose power with age, this could be an important consideration.
Just in case someone might find this useful, I wrote it up as an
article:
http://www.sarangan.org/aviation/eur...tip-Lights.pdf
Let me know what you think.
More LED's Veeduber Home Built 19 June 9th 04 10:07 PM
Panel Lights - Need Help Barnyard BOb - Home Built 2 May 29th 04 07:51 PM
Building chasing airport lights -- Attn: Jim Weir? Jay Honeck Owning 79 February 29th 04 02:10 PM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
LEDs with Strobe lights pekka1510 Home Built 11 August 31st 03 11:36 PM
