Mystery Vibration - 74 Cherokee 140
Old February 27th 06, 09:03 PM posted to rec.aviation.owning
Default Mystery Vibration - 74 Cherokee 140
Plugs might be clean but the resistor in them can fail or
conduct intermittently, weakening the spark. It won't usually show up
during a mag check, but in cruise, if the mags aren't timed exactly the
same, the plug that fires first causes a pressure rise in the cylinder
that the defective plug now has trouble sparking against. Plugs need to
be tested in a pressure-type spark tester, and even then they can act
up when hot.
Dan
Old February 28th 06, 12:32 PM posted to rec.aviation.owning
The Visitor wrote:
: I remember finding some play in the stab on my Seneca. So the shop
: replaced the bushings. I am going to look in the tech logs to see if the
: bolts were also done. If not, I'll have it done. It's a 83 model.
: 125,000 lp tensile strength on those bolts though I believe.
Yeah... when I was replacing the bolts/bearings on mine, I did a quick
calculation just to make sure. I don't remember the exact numbers, but each one is in
double-shear (both sides of the bearing). That's 4 cross-sections of 1/4" to split
the load over. Not super-special bolts, either... just regular AN stuff. Anyway,
from what I remember, my computation on the shear strength of the bolts concluded that
I could pick up the airplane loaded at gross weight by just the tail, and then shake
it with 4G's before the bolts would shear....
Now, that doesn't say anything about excess material for corrosion resistance,
stress risers due to corrosion, or other strength-reduction due to wear. As long as
it's in good shape however, nothing to worry about... just seemed too small.
-Cory
* Cory Papenfuss *
Old March 1st 06, 04:09 PM posted to rec.aviation.owning
Thank you for the comments. They are most reassuring.
I'll "second" that -- thanks for that data, Cory!
I've always looked at those stabilator attach points and quickly averted my
eyes, cringing. They look soooo small!
Of course, take a look at how a 172s wing attaches, and you'll never fly one
of those again. Yet they've never had a wing failure.
All I can say is: Thank goodness for engineers who can figure this safety
stuff out.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 01:51 AM
Cherokee Pilots Association Fly-In Just Gets Better and Better Jay Honeck Piloting 7 August 8th 05 08:18 PM
Wierd vibration -- Prop or engine, balance or not??? Chuck Owning 17 December 1st 04 03:12 PM
Vibration Testing Jim Weir Owning 21 October 10th 04 08:22 AM
Cherokee National Fly-In & Convention Don Piloting 1 March 20th 04 06:27 AM
