#11
I have dual transponders. Without a transponder you are restricted in the
altitudes you can fly and you have to make position reports. Both of these restrictions can really be a major pain when flying high for any distance. BTW, in case anyone is wondering, the transponders are wired such that only one transponder is active at any one time. You set both transponders to Mode C and your code into both. Another switch determines which transponder is active. In my installation, the non-active transponder is is standby mode. jerry "Scott Aron Bloom" wrote in message ... Ok, Im not talking about the commercial carriers. But why would a general aviation plane have dual transponders? Why waste the panel space? So they go tits up that often in flight where its necessary? Scott |
So one is not really doing anything ..is it just left off untill the first
quits? "Steven P. McNicoll" wrote: "Teacherjh" wrote in message ... How does a second transponder fit in to the datastream? Aren't they both transmitting the same data at the same time on the same frequencies? Wont that interefere with itself? The second would only be used if ATC reported a problem with the first one. |
A faulty transponder COULD effectively ground the airplane. ATC can
authorize operations without a transponder, but there's no guarantee they will. My bad, "unless otherwise authorized" (AIM 3-2-4 (d)(2)(b)) the plane is effectively grounded. I suppose the offending transponder would need to be placarded "inop" as well. |
"Jeff" wrote in message ... So one is not really doing anything ..is it just left off untill the first quits? Yup. |
Why put it in the panel. I'm sure you could mount it between the seats.
"Venus" wrote in message ... I dont know either, but when I was at the avionics shop picking up my plane recently, there was a pressureized C-210 they had just starteding working and let me peek inside. It had dual garmin 330 x-ponders, garmin 430,530 and an MX20, it also had some other nifty stuff like a flight navigator and so on. Scott Aron Bloom wrote: Ok, Im not talking about the commercial carriers. But why would a general aviation plane have dual transponders? Why waste the panel space? So they go tits up that often in flight where its necessary? Scott |
"Venus" wrote in message ... I dont know either, but when I was at the avionics shop picking up my plane recently, there was a pressureized C-210 they had just starteding working and let me peek inside. It had dual garmin 330 x-ponders, garmin 430,530 and an MX20, it also had some other nifty stuff like a flight navigator and so on. Scott Aron Bloom wrote: Ok, Im not talking about the commercial carriers. But why would a general aviation plane have dual transponders? Why waste the panel space? So they go tits up that often in flight where its necessary? Scott The Twin Otter I flew had dual X-ponders. But we were using it for skydiving ops and if the X-ponder goes down, we can't operate as a jump plane. SOOoo..we had two....even had to use the 2nd one on occasion. Also, we had the panel space to spare, so it was no biggie. -John *You are nothing until you have flown a Douglas, Lockheed, Grumman or North American* |
They make transponders that share one control panel. Some of our EMB-120's
have a dual transponder single control panel set up. Bill " |
I'm shure if you have dual Garmins the rest of your pannel space becomes
empty. Garmines pack a lot of boxes in one box. John Roncallo Peter wrote: Why put it in the panel. I'm sure you could mount it between the seats. "Venus" wrote in message ... I dont know either, but when I was at the avionics shop picking up my plane recently, there was a pressureized C-210 they had just starteding working and let me peek inside. It had dual garmin 330 x-ponders, garmin 430,530 and an MX20, it also had some other nifty stuff like a flight navigator and so on. Scott Aron Bloom wrote: Ok, Im not talking about the commercial carriers. But why would a general aviation plane have dual transponders? Why waste the panel space? So they go tits up that often in flight where its necessary? Scott |
| Thread Tools | |
| Display Modes | |
| Dual airspeed instruments questions | Louis Gallego | Home Built | 12 | January 9th 04 03:12 AM |
| dual vacuum-pump STC | Dave Butler | Instrument Flight Rules | 4 | September 15th 03 04:18 PM |
| Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 3rd 03 12:27 AM |
