video card
Old March 27th 06, 12:08 AM posted to rec.aviation.simulators
Default video card
"Kevin" wrote in message
I appreciate all of the help thanks a lot. I have downloaded an A-319
that i have been playing around with. I am having soe trouble
maintaining the correct glide slope and speed. I am not sure what air
speeds the passenger jets approach at.
Good point.
If you know the stall speed for the aircraft, you can calculate a
"reasonable" approach speed. 1.3 times the stall speed makes for a good,
general purpose approach speed. For smaller aircraft and shorter runways,
this can be reduced to 1.2, or even 1.1.
There are aids to help reference the correct glide slope. For visual
flight, most runways have some kind of lighting (VASI being very common)
next to the touchdown zone. The visual lights usually involve two or more
lights, which are red when you are below a prescribed angle and white when
above. By adjusting your glideslope so that half the lights are red and
half are white, you ensure that you are on a standard glideslope (usually 3
degrees). For instrument flight, the ILS of course provides glideslope
information.
You can, of course, fly the approach and land at any glideslope, but the
standard glideslope works well with standard approach speeds to make a
relatively easy approach and landing.
My preference is to use pitch attitude to maintain a constant airspeed
(increase pitch to reduce airspeed, decrease pitch to increase airspeed),
and the throttle to adjust the glideslope (increase throttle to flatten the
glide, decrease throttle to steepen it). However, that works best in
smaller airplanes, because they have less intertia.
For larger, heavier ones the pitch attitude gives good and relatively
immediate glideslope control. The airspeed will change as well, but for
small adjustments, 5 knots one way or the other isn't a problem. If
airspeed changes more than that, you'll want to adjust the throttle to
compensate.
If i am too fast and flare, I obviously regain altitude.
As you come over the runway end before landing, the first thing you need to
do is level out during the flare and reduce power to idle. As long as you
flare properly, you won't regain altitude. You'll simply halt your descent
just above the runway and gradually reduce your airspeed as you raise the
pitch attitude to stay off the runway.
Flare too much, and yes you will start to ascend again (but without enough
power to maintain the ascent, which will eventually result in the airplane
dropping onto the runway). Flare too little, and you simply land, possibly
going too fast, and possibly with too great a descent rate. But there's a
pretty fair amount of wiggle room. You can have a pretty firm touchdown
without breaking anything (and of course, if you turn realism off, you can
land VERY hard without breaking anything ).
The landing flare is a matter of matching the change in pitch attitude with
the change in airspeed. The pitch attitude should be gradually increasing
throughout the flare, as the airspeed decreases.
Once you touchdown, you then need to gradually reduce the pitch attitude
again. If you just let go of the yoke and let the nose drop abruptly, that
is hard on the nose gear, and again -- if realism is on -- may break the
airplane.
But, if i am coming in too slow and flare i
lose the runway view and hit the landing hard.
Frankly, it's much harder in a simulator than in the real thing. In the
sim, you do lose your outside reference. In a real airplane, you can easily
look out the side. However, as long as you don't make a turn during
landing, you should be able to count on the airplane staying over the runway
as you maintain your altitude.
Also, as you've seen if you land a little faster you can touchdown while
still having a view of the runway.
Any pointers wsith this?
See above.
Also, Robert's comment about fuel load is worth looking at as well. For
smaller airplanes, it doesn't matter that much. But for transport category
airplanes, the fuel load is a significant component of aircraft weight, and
does play an important part in the landing process.
Also, how do i engage the ILS?
The ILS is simply a radio. It is active if it's turned on and tuned to the
correct frequency (each airport with an ILS will have a frequency assigned
to that ILS).
Some airplanes allow you to connect the ILS to the autopilot, but that's a
function of the autopilot. You'll have to look at the autopilot to figure
out what setting tracks the ILS receiver.
Pete
Old March 27th 06, 07:22 PM posted to rec.aviation.simulators
Default video card
Since I am a stickler for perfection, at what point does the FAA begin
to have a problem with people with botched landings. i.e. besides a
firey crash what is considered "illegal" when landing. Also, what is
the best way to learn communications and the language needed to
communicate with the control towers such that I can begin my virtual
career?
Old March 27th 06, 08:36 PM posted to rec.aviation.simulators
Default video card
If you don't violate any regulations, the FAA does not care. They may
investigate an accident in which you break something, to see if you did
violate any regulations. But that's all.
It is easy to land perfectly while still violating one or more regulations,
and it is possible to destroy the airplane without violating a single
regulation.
The NTSB, on the other hand, has a specific list of criteria to determine
whether you are required to report an accident to them. But they don't deal
with pilot sanctions...all they want is the information for their ability to
track accidents.
For the sim pilot, the bottom line is this: if you aren't told you crashed
the airplane, you did fine.
Also, what is
career?
For many of your questions, especially in terms of procedural and regulatory
aspects, you may want to pick up a copy of the FARs and the "AIM" (used to
be "Airman's Information Manual", but it's been changed to some
gender-neutral name that I've since forgotten). You can find a consolidated
copy known as the "FAR/AIM", published by a variety of sources (ASA is a
well-known one).
In the AIM is a "Pilot/Controller Glossary", as well as a variety of
sections of specific pilot-controller procedures.
Of course, using the built-in ATC features of MSFS would help. But I guess
that's not useful advice for someone using X-Plane.
Pete
Old November 11th 06, 12:18 AM posted to rec.aviation.simulators
Kobra
Default video card
career?
Well, at least start with: Who you are calling: eg. North East Philly
Tower; Who you a eg. Cessna 123X; Where you a eg. over XXX VOR 5,000
feet; What you want: eg. In bound for a full stop landing with Bravo
There's the most basic...
Kobra
MSFS 2004 Video frame rate very slow Greg Brown Simulators 1 November 11th 05 07:24 PM
Video card Fred Mahone Simulators 0 March 10th 04 03:17 PM
Video and Memory Card upgrade? Dave Schwartz Simulators 3 January 3rd 04 12:14 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
