Prop position
Old March 20th 06, 07:57 PM posted to rec.aviation.owning,rec.aviation.piloting
Default Prop position
In rec.aviation.owning nrp wrote:
: Your prop just might be indexed correctly but differently than the ones
: I'm recalling. That seems to be a snake oil thing with different
: aircraft.
There was a thread on this awhile back. I'd concluded that at least on the PA28
like mine, the discrepancy is in the service manual itself. It calls for 10-2 IIRC, but
doesn't say if it's as viewed from the front or the rear. So, 50% of them out there are on
one way, and the others are 60 degrees off. I *still* don't know which is right.
-Cory
* Cory Papenfuss *
Old March 20th 06, 08:01 PM posted to rec.aviation.owning,rec.aviation.piloting
"Doug" wrote in message
The only other answer is some airplane elf came and reindexed your prop
in the middle of the night :-)
May not be as strange as it sounds.
Maybe someone needed a prop. They stole one, put it on your plane and stole
yours. That way the one reported as stolen is on your plane, which you may
never find out about. Mr prop theif winds up with yours, which never gets
reported.
Old March 20th 06, 08:07 PM posted to rec.aviation.owning,rec.aviation.piloting
I'm pretty sure where the prop stops doesn't measure anything.
How do you know it stopped in the same place "horizontally"
each time? There are at least two possibilities.
Why would the prop stop in a preferential position anyway?
Seems like it would be on any one of the 4 compression strokes.
I'm also convinced that even the differential compression
check doesn't show what you really want to know.
The rings are AC coupled, tho less so in the Lycomings.
So I'd guess one would need something worse to worry
about. Maybe price of gas or user fees!
Bill Hale
Old March 20th 06, 10:04 PM posted to rec.aviation.owning,rec.aviation.piloting
Did your propposition involve 10 o'clock and 4 o'clock?
.... or was it something about being horizontal?
Old March 21st 06, 04:02 AM posted to rec.aviation.owning,rec.aviation.piloting
LOL. The usual "approach" has something to do with picking her up at 10
and dropping her off at 4 G
Old March 21st 06, 05:39 AM posted to rec.aviation.owning,rec.aviation.piloting
wrote)
"I'm not that kind of girl - SLAP!"
"Contact."
Montblack :-)
Old March 21st 06, 11:20 AM posted to rec.aviation.owning,rec.aviation.piloting
"Steve Foley" wrote in message
news:BSDTf.6447$092.3203@trndny04...
stole
reported.
Nope; nice try, though. I'd already made 3 stops that day in which
everything appeared normal.
Old March 21st 06, 11:26 AM posted to rec.aviation.owning,rec.aviation.piloting
each time?
Because I've been watching it carefully for 3 years.
A prop that stops in an unusual position can indicate a cylinder with poor
compression, as I discovered when I had cylinder trouble 3 years ago.
Becaues of the crankshaft geometry of the horizonally-opposed Lyc. O-360,
the prop will stop in the same compass position every time as it bounces
back from the last TDC.
No. Something has changed, and that's something to worry about.
Dan
C172RG at BFM
Prop position Dan Luke Piloting 28 March 22nd 06 06:46 PM
3 blade prop position on 6cyl engine. Paul Lee Home Built 3 February 26th 04 12:47 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
