In article , Marco Leon wrote:
I agree that many--if not most--of the IFR avionics are not necessary for VFR. I got that. Do you not check any of the non-essential avionics before a VFR flight? I usually fly a 1945 Aeronca Champ. The only instruments I have are airspeed, tach, altimeter, compass, oil temperature, oil pressure and fuel indicator. If I have a radio, it is a handheld comm and gps. The airplane has no electrical system nor starter. Because of battery life in the handhelds, they may be used for takeoff and/or landing and turned off for enroute. Depending on the terrain, a sectional will give me more information than the gps. GPS is good for distance, but at the altitudes I fly at, I usually have to fly around terrain. Maybe it's because I own the aircraft I fly and I would like to know what is and what is not working. I am also based at an airport under New York Mode C Veil. However, even on a rental I would want to know if anything is inop. Wouldn't you? Depends on what I am renting, terrain I will be flying over and forecast weather. As long as the fan out front keeps turning, I stay cool. It all depends on what type flying you are doing as to what equipment you need operational. |
"Marco Leon" mleon(at)optonline.net wrote:
I agree that many--if not most--of the IFR avionics are not necessary for VFR. I got that. Do you not check any of the non-essential avionics before a VFR flight? Maybe it's because I own the aircraft I fly and I would like to know what is and what is not working. I am also based at an airport under New York Mode C Veil. However, even on a rental I would want to know if anything is inop. Wouldn't you? I was thinking something similar as I read this thread. I check, for example, all the lights even if I've no plans to be flying at night. It permits me to avoid cancellation of a night flight if I can replace a dead bulb ahead of time. The same applies to avionics: I'd rather know about the failure with sufficient lead time that it can be fixed before I've a flight that requires it. Also, it makes no sense to have tools that might or might not be working. Even if the tool isn't expected to be required, it makes sense to know whether or not it is available. - Andrew |
EDR wrote in :
Does anyone use a separate Avionics Checklist prior to departing IFR? I am in the process of developing my own and would appreciate seeing what others are doing. Please cut and paste a posting to the group or email me directly. Thanks. I don't have a copy of our checklist here at home, but I'll try to do it from memory. 1. GPS - Go through whatever function checks you have for your GPS. They should be in the manual that came with the unit. 2. VORs a. Tune both nav radios (if you have more than one) to a VOR. b. Center both course needles with a TO indication and compare them. c. Change both CDIs (if you have two) more than 10 degrees and check for full-scale deflection of the needles. Then move the CDIs past 90 degrees and check for TO/FROM change. Center both needles with a FROM indication and compare them. If you only have one CDI, insure that the centered indications are more or less correct, depending on the distance from the station. d. Set the CDIs to the desired course. e. Identify the station with the audio, and if you have a VALID/INVALID light, tune the VOR off the station and check for an INVALID light with no signal. 3. ADF - check the bearing pointer, see that it points in the right direction for the station tuned, and moves with a new station. 4. DME - Check that it's operational, and giving correct information, if you can receive a signal. 5. Marker Beacon - test. 6. Radar Altimeter - test. -- Regards, Stan |
Vendor recomendation: Stark Avionics | Ron | Home Built | 2 | December 8th 04 05:25 PM |
Real World test bed for avionics - Megawatts at Delano | MikeremlaP | Home Built | 0 | June 2nd 04 04:24 AM |
Used Avionics | O. Sami Saydjari | Instrument Flight Rules | 40 | December 2nd 03 02:53 PM |
hardware to mount avionics trays | Matthew M. Jurotich | Home Built | 1 | November 17th 03 10:56 PM |
Avionics Swap Group | Jim Weir | Home Built | 3 | July 7th 03 02:27 PM |
