Lycoming crankshafts
Old March 28th 06, 01:23 PM posted to rec.aviation.piloting
Default Lycoming crankshafts
Ya got to be kidding me... There are a couple of dozen flyers dead
already resulting from their " CERTIFIED", overpriced, traceable, FAA
approved cranks.
Do you have AD's for this statement? URL's? NTSB findings?
I see no crank AD's on Lycomings for the past 30 years...
denny - willing to learn
Old March 28th 06, 03:28 PM posted to rec.aviation.piloting
approved cranks.
This took all of 3 seconds to find. Don't you people know how to use the
internet ?
http://www.ntsb.gov/ntsb/brief.asp?e...08X01353&key=1
Old March 28th 06, 03:47 PM posted to rec.aviation.piloting
I made a factually correct statement about Lycoming crankshafts...
I suggest that you look up the engine make in a Malibu...
denny
Old March 28th 06, 04:18 PM posted to rec.aviation.piloting
Reference:
http://www.airweb.faa.gov/Regulatory...light=98-02-08
From the Preamble to AD 98-02-08:
SUPPLEMENTARY INFORMATION: On October 18, 1993, the Civil Aviation
Authority (CAA), which is the airworthiness authority of the United
Kingdom (UK), received a report that a Piper PA-28-161 aircraft, with a
Textron Lycoming O-320-D3G reciprocating engine installed, executed a
forced landing due to an engine crankshaft failure which caused the
propeller to separate from the aircraft. The cause of the crankshaft
failure was determined to be due to a high cycle fatigue mechanism that
had initiated from a number of corrosion pits in the crankshaft bore.
After the cracks had progressed through a substantial proportion of the
crankshaft section, the rate of advance had increased until the
remaining unseparated portion had failed as a result of overload. The
cracking occurred in high cycle fatigue and it had progressed over an
extended period of service. At the time of the accident the engine had
operated for 1,950 hours time in service (TIS) since overhaul and had
accumulated 4,429 hours total time since new over a period of 16 years.
In addition, the Federal Aviation Administration (FAA) has confirmed
that four other failures in the United States and 10 in foreign
countries were due to cracks initiating from corrosion pits in the
crankshaft bore on certain Textron Lycoming 320 and 360 reciprocating
engines with ratings of 160 horsepower or greater. Of the 10 failures
in foreign countries, four resulted in the propeller separating from
the aircraft inflight. Three of these four were from 1993 to 1996. The
FAA utilized metallurgical failure analysis reports and other
information to conclude that these failures were due to cracks
originating from corrosion pits. This condition, if not corrected,
could result in crankshaft failure, which can result in engine failure,
propeller separation, forced landing, and possible damage to the
aircraft.
Ref:
http://www.airweb.faa.gov/Regulatory...ght=2005-19-11
From the Preamble to AD 2005-19-11:
SUMMARY: The FAA is adopting a new airworthiness directive (AD) for
certain Lycoming Engines (formerly Textron Lycoming) AEIO-360, IO-360,
O-360, LIO-360, LO-360, AEIO-540, IO-540, O-540, and TIO-540 series
reciprocating engines rated at 300 horsepower (HP) or lower. This AD
requires replacing certain crankshafts. This AD results from reports of
12 crankshaft failures in Lycoming 360 and 540 series engines rated at
300 HP or lower. We are issuing this AD to prevent failure of the
crankshaft, which could result in total engine power loss, in-flight
engine failure, and possible loss of the aircraft.
Dan
Old March 28th 06, 04:40 PM posted to rec.aviation.piloting
"George" wrote in message news:UJbWf.17503
internet ?
These three people died because the pilot failed to follow procedures and
[apparently] stalled the airplane. The crankshaft was a factor, but an
eminently survivable one.
"The National Transportation Safety Board determines the probable cause(s)
of this accident as follows:
The pilot's failure to maintain airspeed above stall speed...... A factor to
the accident was ......the fatigue failure of the crankshaft.'
Old March 28th 06, 04:51 PM posted to rec.aviation.piloting
I stand corrected, I should have done the search before replying... A
couple-three years back when the Continental crankshaft failures were
the topic of discussion I had done an AD search on Lycoming crankshafts
(since a have a pair of them) and the FAA web site did not show any for
Lycoming since the early 70's... I hadn't repeated the search
recently... My bad...
But, the topic of metallurgy failures is not limited to Lycoming and
Continental... Both Superior and ECI has massive recalls on cylinders
for early wear and cracking, including failures in flight...
Continental big bores are famous for the rocker arm bushings wearing
out every 900 hours (I've been through a couple of early top overhauls
over this)...
Lycoming parallel valve cylinders are famous for lack of cooling oil to
the valve stems leading to morning sickness (been there, done that,
got the tee shirt, now I use AVBLEND)...
The problem is more than just Lyconsaurus being dinosauers... Airplane
engines are highly stressed machinery... If they were engines pumping
water from the mines, or turning dynomotors for municipal electric
plants, or pushing 900 foot container ships, we would just make the
parts so heavy and thick they could never fail, but that is not an
option with airplanes.. It seems that every major player in the
aircraft engine market has been bitten by the metallurgy bug... Is it
the stress on the engine parts, or the FAA regs, or bad metallurgy? I
don't know the answers but there do not appear to be simple
solutions... Every company producing engines/parts has bright people
working for them, so if there were solutions they would have been
implemented and we would not be having this discussion...
denny
Old March 28th 06, 05:07 PM posted to rec.aviation.piloting
I don't know about anyone else, but Lycoming's latest dirty trick with the
crankshafts...
What "dirty trick"?
Jose
Nothing takes longer than a shortcut.
Old March 28th 06, 06:53 PM posted to rec.aviation.piloting
I remember reading about this some years ago. There was a picture of
the failed UK crank front journal bearing ID taken thru the front plug
hole. It was solid crud where the crud ID appeared to be about 1/4
inch diameter. That engine must have been filthy inside & operated in
some very abusive and corrosive conditions. It is interesting that it
had been overhauled once & was near TBO again. Who did the magnaflux
at the first overhaul?
Old March 28th 06, 08:17 PM posted to rec.aviation.piloting
Isn't this the one that run's on JP and therefore won't need a lot of
new infrastructure to support?
Read someplace that both L & C were looking at developing a new
generation engine. Could the DeltaHawk have them worried?
Big John
On Mon, 27 Mar 2006 23:45:10 -0600, "Montblack"
("Dan Luke" wrote)
If another company were to step up with a new technology engine, with
replacement STC's for most all of the popular spam cans, they would clean
house.
We can only hope. The obstacles are enormous.
Let's see if we can't squeeze three threads out of today's AvWeb. :-)
http://www.deltahawkengines.com/
Delta Hawk diesel engines
http://www.avweb.com/eletter/archives/avflash/602-full.html#191852
The American Diesel, Still Struggling For Air
"DeltaHawk, a small company based in Racine, Wis., has been working for
about a decade to develop a diesel engine for GA aircraft -- the only such
engines being built in the U.S., the company says. The engine first flew
back in May 2003 in a Velocity RG, and since then has been making the rounds
of trade shows as R&D continues. A few of the 200-hp engines have been built
for experimental aircraft, but the company says it is still at least 18
months away from having an FAA-certified engine, and money problems are
slowing down the process. With a little luck, the company hopes to sell more
than 3,600 of the engines in 2010. The company will be exhibiting its
technology at Sun 'n Fun, coming up in Lakeland, Fla., April 4-10."
Montblack
Kurt Manufacturing will be machining the components for DeltaHawk. KM is
down the road from me, maybe five miles.
Old March 28th 06, 09:06 PM posted to rec.aviation.piloting
"Big John" wrote in message
At this point in time DeltaHawk poses a threat to no one. They have been in
development since before there was dirt and don't seem to ever get close to
having a viable product.
Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? Roy Page Owning 7 February 2nd 06 02:19 AM
Book Review:Maintenance/overhaul guide to Lycoming aircraft engines, Christy Paul Home Built 11 December 26th 04 03:24 AM
Book Review:Maintenance/overhaul guide to Lycoming aircraft engines, Christy Paul Owning 11 December 26th 04 03:24 AM
Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? Mike Spera Owning 6 December 13th 04 01:13 AM
Lycoming 320 and EAA Light Sport Aircraft ? Dave Jackson Home Built 29 October 20th 03 01:20 AM
