OLC participation and "red marks"
Old March 29th 06, 07:31 PM posted to rec.aviation.soaring
Default OLC participation and
Don't worry, the OLC people have been contacted directly on this issue.
Old March 29th 06, 08:04 PM posted to rec.aviation.soaring
Default OLC participation and OLC problems
Having a really kick-ass OLC interface would serve the soaring
community much better than having yet another PDA gizmo or 3d flight
viewer. Too bad there isn't some sort of national organization for
soaring pilots that could channel money towards that end.
Old March 30th 06, 06:45 AM posted to rec.aviation.soaring
The cambridge logs that are not passing the OLC security check all have
a line at the top of the L record section of the file like
LCAMN CAI Utility DLL Vers: 1, 0, 1, 4
or
LCAMN CAI SeeYou conversion
The ones that pass straight away have the line
LCAMNCONV-CAM Version 2.0.2 IGC File Creation
SeeYou currently, and last years version, put an L record like the first
one in the .igc file. The old DOS utility puts the L record in there
that the OLC likes.
It looks like the OLC security check for 2006 expanded the portion of
the .igc file they are comparing to the binary .cai file (actually to
the binary file reconverted to an .igc file on the server using the
CONV-CAM utility) and are now kicking out files submitted with the wrong
L record describing how the .igc file was generated from the .cai file.
They appear to have been manually accepting files they notice have been
incorrectly kicked.
An easy fix until the OLC automated processing is corrected, that I
haven't tried yet, would be to use SeeYou to generate your .igc file
which will append the .cai binary file on the end, then go in with a
text editor and replace the
line with
I'm sure someone could script this making it much simpler, but its still
easier than using the DOS command line.
Its genrally a no-no to edit your .igc file, but I think this will work.
Any other tampering with the .igc file will probably cause the file not
to pass the security check.
Ron's flight also appears to have the wrong end of flight time which
made the optimizer not work correctly. That can usually be edited
through the OLC web interface.
-Dave Leonard
Papa3 wrote:
Greg Arnold wrote:
Stewart Kissel wrote:
Link to thread with one pilots directions for submitting
with the older Cambridge loggers....if you poke around
the OLC site, they have their version of these directions
as well.
http://www.abqsoaring.org/viewThread.php?threadID=68
Good directions, but I think he is wrong that you have to change the
file name if you need to do the process a second time. It is true that
OLC wants to use the old uploaded file the second time, but you can
force it to use the new file by clicking on the button that allows you
to upload a new file.
I don't presently have a flight on OLC that I can open, so I can't say
just how you do this, but I have done it several times without any problem.
To Greg's point, the failure rate is still unacceptably high, even when
following the directions. I know - I've tried to help out several
people in my club with Cambridge loggers, and the success rate is only
about 50%. The folks in my club (currently in first place in the US
right now, I might add) , have actually begun to revolt. They've
basically decided that the OLC is "unstable" and are not willing to
invest more computer time trying to get scored. Though that might not
be a fair statement, it is an understandable perception. Given that,
we can expect participation to drop off.
Whether or not we want to blame Cambridge, the OLC, SeeYou, or anyone
else, the problem with the validation of G Records for Cambridge
loggers is a real issue that isn't going away right now. I think we
ought to reconsider whether this Validation is worth the price (ie.
turning off prospective participants). My suggestion is that we ask
OLC to disable Validation until someone comes up with a script that
successfully handles all of the steps required to create an acceptable
output from a Cambridge Logger using a user-friendly interface.
Asking the average glider pilot to manipulate files using a DOS command
prompt is a recipe for failure (or at least good for a laugh or two).
Erik Mann (P3)
p.s. If anyone want an example of the situation, take a look at the
file from Ron Schwartz on 3/27 in the US. The source .CAI file
passes Vali-Cam just fine. Ran CAI2IGC just fine. Output .IGC file
shows the binary .CAI file appended to the IGC file. File still shows
up on OLC as invalid, not to mention that the scoring distance is also
wrong. Would appreciate anyone who can download the file and see if
anything jumps out at you.
Old March 30th 06, 04:11 PM posted to rec.aviation.soaring
Dave,
Looks like you're on to something. Couple of points:
- I started with a "raw" .CAI file and tested two conversion cycles;
one using Conv-cam and one using he utility that comes from Cambridge.
- The files produced are different over and above just the LRecord you
describe. The CAI utility produces a record that's about 1kb larger
and it's clear that the L-Record format is different.
- When you run the CAI2IGC conversion the output is different as well.
- Just modifying the LRecord (comment record) probably isn't the
answer, even though it shouldn't corrupt the hashed GRecord validation
step.
Looking back at the instructions from the OLC, it seems pretty clear
that it's critical to follow the conversion sequence exactly as
described; ie. start with the raw CAI file only - run the Conv-cam
utility - then use the .IGC file output from that step as the input to
the CAI2IGC step. Where I think people are getting tripped up is that
they get both the .CAI file and the .IGC file when downloading using
GlideNavigtor/PocketNav. They use the .IGC file from this step as the
input to the CAI2IGC conversion.
There are now dozens of files out there on the OLC that are red
flagged, and I haven't yet heard back from the OLC guys after emailing
them; I'm sure they're reasonably busy right now!
Old March 30th 06, 04:20 PM posted to rec.aviation.soaring
Out of curiosity, I sampled the daily scores from Germany
for February and March, and no flight had this problem.
So do the Germans not use Cambridge loggers ? Or
are they all meticulous in following an acceptable
procedure ? Or is there something different between
the US and German OLC validation processes ?
Ian
At 15:12 30 March 2006, Papa3 wrote:
Dave,
- I started with a 'raw' .CAI file and tested two
conversion cycles;
from Cambridge.
about 1kb larger
different as well.
isn't the
GRecord validation
step.
pretty clear
exactly as
the Conv-cam
as the input to
tripped up is that
downloading using
this step as the
that are red
guys after emailing
Old March 31st 06, 08:30 PM posted to rec.aviation.soaring
Apparently SeeYou has the same workaround implemented. You need to
download a xip file with the patches and replace the files in your
SeeYou directory:
http://www.naviter.si/dload/seeyou-cai-dos.zip
1. Extract both files from the ZIP to your SeeYou folder
2. Replace your existing SeeYou.exe
You should be able to claim flights normally once the patches are
applied.
Hopefully this will clear up the problems with the Cambridge 10/20/25
loggers and OLC. Please post your experiences with either program and
SeeYou directory:
applied.
Old April 3rd 06, 08:30 PM posted to rec.aviation.soaring
Well, I don't see any postings from this weekend. Is no news good news?
As info, the SeeYou patch above had problems with long file names (it's
a DOS thing). They have a new patch up on their web site:
http://www.seeyou.si/news/2006/04/gps-nav-patch.html
Old April 3rd 06, 08:40 PM posted to rec.aviation.soaring
I see 63 postings with over 50 points, and 20 of them have the red mark.
If you use this patch, do you still get the OLC message "Sorry,
Validation Service is current not running.
OLC Team is working on that issue," or has SeeYou figured a way around
that message?
"red oxide primer is a plus" mhorowit Home Built 6 November 27th 05 05:23 PM
