Columbia crash...opinions
Old March 30th 06, 04:39 AM posted to rec.aviation.owning,rec.aviation.piloting
Default Columbia crash...opinions
"xyzzy" wrote in message
Kobra wrote:
Check this clip out. What does everyone think happened here?
http://youtube.com/watch?v=ZWC2XJYgcJU
What kind of player does this video use? It doesn't play in my IE and
there is no link on the page to download the player.
You probably have your security set too high, and disallow the necessary
Control.
Old March 30th 06, 12:17 AM posted to rec.aviation.owning,rec.aviation.piloting
Maybe the passenger was interfering with the rudders? He was in quite
a slip as he went over the people on the ground. You could imagine
someone turning around to look into the back seat pressing or blocking
the rudder in an effort to twist around.
Ben Jackson
http://www.ben.com/
Old March 30th 06, 12:25 AM posted to rec.aviation.owning,rec.aviation.piloting
Hmmm, maybe. The person in the right seat was a small woman. I would think
the pilot would be able to come up with enough force to lift that woman with
his one leg.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old March 30th 06, 01:25 AM posted to rec.aviation.owning,rec.aviation.piloting
It looks like a 182, so it had *some* muscle.
I think it must have been hot, maybe a high elevation, loaded with fuel,
people and equipment. But one passenger was a small boy so he couldn't have
been very heavy.
It also looks like a soft-field technique that was poorly executed and he
lost directional control and didn't lower the nose to build airspeed first.
Very sad,
Kobra
Speed. Looks like a very short takeoff without adequate flying speed.
The pilot may have felt he was about to plow the people in front, and
tried to get it off before it was ready. He actually did get it off,
but low and out of control.
Old March 30th 06, 02:06 AM posted to rec.aviation.owning,rec.aviation.piloting
"Kobra" wrote in message
have been very heavy.
first.
Very sad,
Kobra
Looks like a loss of directional control on takeoff.
The pilot *might* have saved things by using left brake, rudder, and aileron
to avoid the pedestrians, but most of us (including myself) are not
practiced up on abrupt maneuvers at *almost* flying speed.
Once he lifted off, I think he was afraid to bank the aircraft and used
rudder to either bring the aircraft back to the runway centerline OR to make
a slight turn into the wind. That, or he completely forgot about the rudder
and P-factor put him into uncoordinated flight. He'd have done much better
keeping the airplane in coordinated flight - without the excess drag caused
by that slip, he might have reached a managable speed and flown away...
KB
Old March 30th 06, 02:50 AM posted to rec.aviation.owning,rec.aviation.piloting
Someone elsewhere suggested that the gust lock might have been in
place, as you don't see the ailerons moving. I don't know enough about
Cessnas to say if this is very likely, and I can't tell from the video
whether any aileron input is noticable.
Old March 30th 06, 03:01 AM posted to rec.aviation.owning,rec.aviation.piloting
"Mike Granby" wrote in message
Unlikely if it is OEM gust lock since it would block the key for starter and
magnetoes.
Howard
Old March 30th 06, 10:08 AM posted to rec.aviation.owning,rec.aviation.piloting
Unlikely. The standard Cessna gust lock locks the elevators in an almost
full nose-down position - it's improbable he'd have been able to raise
the nose at all. It just looks like a classic insufficient
airspeed/mush/stall accident.
Dylan Smith, Port St Mary, Isle of Man
Flying: http://www.dylansmith.net
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Frontier Elite Universe: http://www.alioth.net
Old March 30th 06, 06:08 PM posted to rec.aviation.owning,rec.aviation.piloting
Yep, "Behind the power curve".
Al
"Dylan Smith" wrote in message
Old March 31st 06, 04:39 AM posted to rec.aviation.owning,rec.aviation.piloting
The factory control lock puts the elevator down about 10° from horizontal,
just enough to keep the wind from flipping the tail up. But you are right,
with it in place there is no way to rotate.
I think he just panicked and pulled back on the yoke.
Q: How to find info about small plane crash in Columbia (South America)? bud Piloting 5 December 28th 05 04:09 PM
Doubts raised in jet crash Dave Butler Piloting 8 July 26th 05 01:25 AM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 05:58 PM
Cause of Columbia Shuttle Disaster. Mike Spera Owning 2 August 31st 03 03:11 PM
