Cracked ribs
Old March 30th 06, 05:16 PM posted to rec.aviation.piloting,rec.aviation.owning
Default Cracked ribs
Bummer on the rib.
Glad you did the inspection though.
After the repair is done you'll sleep better.
"Jack Allison" wrote in message
Jack Allison wrote:
Oops...meant to post in r.a.o...bah, stupid fingers!
Piper has a new service bulletin, SB1161 that calls for inspection of
the rib just inboard of the landing gear and aft of the main spar.
http://www.newpiper.com/company/Publ...20Insp-Mod.pdf
The SB requires putting the plane on jacks and removing the gear side
brace and bracket.
As 04T is in for the annual, we figured it was a good time to have the
SB performed. It turns out we have cracks on both sides of the rib and
they're bad enough that the repair kit announced in the SB can't be
used. Solution: two new ribs. Cost for parts: 1.1 AMU. Labor is
unknown at the moment but the shop is putting together an estimate.
At least I can split the repair bill three ways...but it's still gonna
put a dent in the flying funds.
Jack Allison
PP-ASEL-Instrument Airplane
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old April 1st 06, 09:14 AM posted to rec.aviation.piloting,rec.aviation.owning
On Wed, 29 Mar 2006 20:06:32 -0800, Jack Allison
That really should be for the pilots who do full stall landings from
10 feet up.
www.rogerhalstead.com
brace and bracket.
Old March 30th 06, 05:30 PM posted to rec.aviation.piloting
On Wed, 29 Mar 2006 20:05:00 -0800, Jack Allison
wrote in
Have you researched the cost of used ribs?
Old March 30th 06, 09:29 PM posted to rec.aviation.piloting
wrote in
Wouldn't metal fatigue be an issue?
__________________________________________________ _______________
Too much time on your hands? Waste it here!
www.crazydatingstories.com
www.crazykidstories.com
www.crazywarstories.com
Old March 31st 06, 07:07 AM posted to rec.aviation.piloting
A potential problem with used ribs is how old they are. Newer ribs with
the proper date code don't require the inspection. Replacing the ribs
does the same as applying the repair kit...no more inspection necessary.
IMHO, used parts are ok for some things...but not for this job on our
plane. I'd rather put brand new ribs in despite the higher cost.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old April 1st 06, 01:06 AM posted to rec.aviation.piloting
Unless the new ribs are of a new/better design, won't they also crack
with time?
Old April 1st 06, 04:54 AM posted to rec.aviation.piloting
with time?
There is a date code on the newer ribs that exempts them from
inspection. Whether that means they're designed differently, thicker,
or what, I'm not sure.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old March 31st 06, 04:00 AM posted to rec.aviation.piloting
Man, that is just painful.
Cracked cylinder: Typical cause? Peter R. Owning 19 October 9th 04 04:24 AM
Testing Stick Ribs Bob Hoover Home Built 3 October 3rd 04 02:30 AM
How much to replace cracked crankshaft in 1972 skyhawk O-320-E2D engine Dave Gribble Owning 2 February 4th 04 08:30 AM
Heat treating wing ribs Holger Stephan Home Built 13 February 3rd 04 11:59 PM
Is a cracked vent SCAT tube an urgent problem? Ben Jackson Owning 18 September 20th 03 03:31 AM
