On Sun, 18 Jan 2004 11:24:40 -0500, Roy Smith wrote:
In article , Ron Rosenfeld wrote: On Sat, 17 Jan 2004 21:58:15 -0500, Roy Smith wrote: I'm learning the CNX-80 my club just installed. One of today's tasks was to load and fly a DP to make sure I knew how that worked. Do you have a syllabus for learning this box? I'm in the process of having one installed, too. Unfortunately, no. It's one of the things I hope to develop as I learn it myself. I would certainly start by ignoring the GPS functions and learn the basics: Comm: How to manually enter frequencies. How to adjust the volume (don't laugh, we got caught by this the first time out; had the volume set to zero and couldn't figure out why ground didn't seem to be hearing our taxi requests). Once you are sure you know how to manually enter a frequency (so you've got something to fall back on if all else fails), then you want to explore the database functions, so you can pull freqs out of the database (the keystroke series: Nearest-Airport-Info-Freqs will become your friend). Xponder: how to enter a squawk code and ident. After that, I'd move onto the GPS stuff. First make sure you know how to go direct to a random waypoint, then move onto entering flight plans. I wouldn't touch approaches until you were sure you had the flight plan stuff down pat. The last thing I would do is get into how the Nav radio works. The primary thing here is to make sure you know how to enter a localizer freq, ident it, and switch the CDI from GPS to NAV mode. I've got about 15 hours behind the box at this point. The first 6 were my own checkout (I was getting checked out in a new plane at the same time I was learning the CNX-80, so there was a double workload). Perhaps it's a indictment of flight instructing in general, but by the 10 hour point, I already had 2 hours teaching it. I'm getting pretty good with complex flight plans and flying stand-alone GPS approaches, but I'm still getting caught up on occasion by unexpected problems in unusual situations and I'm far from done exploring all the features. We've got a pretty nice setup. CNX-80, SL-30, HSI, and Century-2000 2-axis autopilot. I'm just getting into learning how to fly coupled ILS's (which has nothing to do with the CNX-80, per se). Now all we need to do is add a turbo, oxygen, de-ice, stormscope, and a relief tube, and we've have a really useful airplane! Those sound like good ideas, although I'd probably want to get the ordinary NAV down earlier. I've been using the CD that comes with the unit, but I'm still waiting to get my a/c back. I won't have the slaved transponder, so that'll be one level of complexity I can avoid g. I'm also doing some heavy reading about GPS approaches. Not all are intuitively obviously For example, according to the AIM, if you are in the right base or left base areas, you need to start the approach at the IAF associated with that side. That would seem to preclude a situation where, if you are over the airport when cleared, you could fly to the central IF/IAF (the straight-in sector IAF) and execute a charted procedure turn. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Sky Acres (44N), Kingston (20N),Poughkeepsie(POU) Stormville(N69)
All up in your area John |
ME-262 in New York? | Bob Kuykendall | Home Built | 2 | July 18th 03 05:04 AM |
