differences in loc/dme and loc with dme appch at KRUT?
Old January 24th 04, 03:19 PM
Dave S
Roy.. After reading yours and Stephen's reply.. I concede I am mistaken
and you are correct. Dang.. and to think I was trying to be extra
careful on this one too and figure out why the plate differences existed.
I am getting pretty frustrated with myself lately, since I appear to be
proven inaccurate more often than not with some of my replies on here,
even though my intent was to be helpful. I think I am going to sit back
and be a spectator for a while.. I dont want to be a resource if it ends
up being a BAD resource.
Dave
Roy Smith wrote:
In article .net,
Dave S wrote:
RUT LOC/DME 19
The DME is required.. and in this approach the DME is co-located with
the localizer for 19.
RUT LOC 19 (with DME)
DME optional, but the DME for use in THIS approach is co-located with
the VOR which is on-field, but sited differently from the Localizer.
It looks to me like other than the step-downs at FISER and MAUVE on the
feeder routes, all the DME callouts on both approaches reference I-RUT.
Are you seeing something I'm not?
Old January 24th 04, 03:27 PM
Roy Smith
In article .net,
Don't get discouraged. If I had a nickle for every time I was wrong in
public, I'd be a rich man. I've learned more about aviation being an
instructor than I did as a student, and a lot of the best learning came
when I was proven wrong.
Correlary: just because somebody with lots of letters after their name
says something, don't think it must be true!
PS, I'm still stumped by these approaches. I really have no clue why
the LOC-DME version exists. For all the arguing back and forth about
details, I still don't see the big picture.
Old January 25th 04, 07:49 PM
Dave S
Someone said something about the missed approach portion having
something to do with it, particularly with all the terrain surrounding
the airport.
Dave
Roy Smith wrote:
In article .net,
Old January 24th 04, 05:17 AM
Steven P. McNicoll
"Dave S" wrote in message
link.net...
RUT LOC/DME 19
No, the DME used in this approach is the same as the LOC/DME approach, if it
was from the VOR/DME the identifier by the DME fixes would show RUT instead
of I-RUT.
Old January 24th 04, 05:05 AM
Steven P. McNicoll
"Richard Hertz" wrote in message
t...
Can anyone point out why the following approaches have minor differences
(specifically the minimums and the MAP):
RUT LOC/DME 19
It looks like the missed approach procedure is the culprit. The procedure
for the LOC RWY 19 uses the RUT VOR/DME while the procedure for the LOC/DME
RWY 19 does not. Apparently not using the VOR/DME for the procedure pushes
the MAP 1.5 miles further out and bumps up the MDA and minima a bit. The
LOC RWY 19 is a better approach, but would be NOTAMed NA if the RUT VOR/DME
is out of service.
Old January 24th 04, 05:46 AM
Richard Hertz
Right, but why should that force the odd differences in the final segments
of the approaches?
e.g. - the "Fly visual 2.5 nm" on the LOC/DME 19 and the 1600 and 2 (loc/dme
19) vs the 1580 and 1 1/4 minima (loc 19 with dme)?
I suppose there is no good reason for the differences (the different minima
and MAPs)
ink.net...
t...
RUT LOC/DME 19
LOC/DME
pushes
VOR/DME
is out of service.
Old January 24th 04, 01:24 PM
Steven P. McNicoll
et...
of the approaches?
(loc/dme
minima
and MAPs)
I'm not a TERPS expert, I'm pretty much just guessing. There is higher
terrain to the south, southwest, and west of KRUT. Climbing to 2600 via the
RUT VOR/DME 221 radial allows you to avoid these rocks until you're above
them. Without the positive course guidance provided by RUT VOR/DME you're
left with climb gradient requirements that can't be met with the MAP at
I-RUT 1.9 DME so the MAP must be pushed back to 3.4 DME.
Old January 24th 04, 01:32 PM
Steven P. McNicoll
ink.net...
A portion of the New York sectional showing the area can be viewed he
http://makeashorterlink.com/?Z2A616C27
Old January 24th 04, 03:42 PM
Richard Hertz
Thanks - I will have to look into that later - it is the best answer I have
seen yet.
ink.net...
et...
segments
of the approaches?
(loc/dme
minima
and MAPs)
