I need help interpreting the 2006 rules regarding the above subject. The rules do not discuss a back up flight recorder. What options exist for a backup flight recorder that would be excepted across the board in US contests for none team use. Udo PS. If you have a used GPS Nav 20 or 25 let me know. |
Hi Udo
Is a backup needed? My GPS Nav has worked flawlessly for the last 10 years {:)) I need help interpreting the 2006 rules regarding the above subject. The rules do not discuss a back up flight recorder. What options exist for a backup flight recorder that would be excepted across the board in US contests for none team use. Udo PS. If you have a used GPS Nav 20 or 25 let me know. -- |
Hello Charles,
mine has worked flawlessly for many years as well. I would like to have a second Nav / PDA system. It should generates a flight log that is acceptable as a back up for contests in the US. If you like to know, I had a bit of a hick up in Florida with my PDA I got it resolved in time but I wish, at that moment, I had a second set-up. Having invested time and money for a contest it could ruin an otherwise pleasant outing. Udo Hi Udo Is a backup needed? My GPS Nav has worked flawlessly for the last 10 years {:)) I need help interpreting the 2006 rules regarding the above subject. The rules do not discuss a back up flight recorder. What options exist for a backup flight recorder that would be excepted across the board in US contests for none team use. Udo PS. If you have a used GPS Nav 20 or 25 let me know. -- |
Udo,
I had the same issue as you and couldn't justify spending another $800-$1000 for a "backup" (equal to one family vacation). So, I went and bought a Garmin GPSMap76 for $130 on eBay. Best investment I ever made! Advantages: - Self-contained logger and display. So, no interface issues, cables, software conflicts, etc. - If you spend the time to get familiar with it, you can input a task, set arrival radius, etc. It's easy to zoom in our out, and you can add various maps to the background if you want to get fancy. - Compact, so easy to mount. I molded a small cradle from plexiglas and used the camera mounting holes provided in my LS8. RAM makes all sorts of very slick mounts if you want something more elegant. - It has been 100% reliable over the last year. In fact, it has been so much easier to use when submitting OLC claims (given the recent VALI issues) that it has been my primary logger for that purpose. - As Marc cautions below, you need to be aware of the altitude differences between barometric altitude and GPS altitude on anything other than an ISA day. I have mine set up to show GPS Altitude on the pointer screen itself; that way you have access to it in case you find your Cambridge has gone down. - You will need to have SeeYou, G72Win, or an equivalent program to download and create an IGC format file. - I use 2 rechargable 2500mAh rechargeable AA batteries which are good for at least 6 hours each. I just swap 2 pairs each day during the contest and I'm all set. I keep a spare pair of alkalines in the side pouch just in case. Hope this works for you. Erik Mann (P3) |
Papa3 wrote:
I had the same issue as you and couldn't justify spending another $800-$1000 for a "backup" (equal to one family vacation). So, I went and bought a Garmin GPSMap76 for $130 on eBay. Best investment I ever made! That works very well for me, too. Get the GPSMAP 76-S, with the barometric sensor and compass. A few bucks more but better altitude readings. Advantages: - Self-contained logger and display. So, no interface issues, cables, software conflicts, etc. - If you spend the time to get familiar with it, you can input a task, set arrival radius, etc. It's easy to zoom in our out, and you can add various maps to the background if you want to get fancy. - Compact, so easy to mount. I molded a small cradle from plexiglas and used the camera mounting holes provided in my LS8. RAM makes all sorts of very slick mounts if you want something more elegant. - It has been 100% reliable over the last year. In fact, it has been so much easier to use when submitting OLC claims (given the recent VALI issues) that it has been my primary logger for that purpose. - As Marc cautions below, you need to be aware of the altitude differences between barometric altitude and GPS altitude on anything other than an ISA day. I have mine set up to show GPS Altitude on the pointer screen itself; that way you have access to it in case you find your Cambridge has gone down. - You will need to have SeeYou, G72Win, or an equivalent program to download and create an IGC format file. - I use 2 rechargable 2500mAh rechargeable AA batteries which are good for at least 6 hours each. I just swap 2 pairs each day during the contest and I'm all set. I keep a spare pair of alkalines in the side pouch just in case. Hope this works for you. Erik Mann (P3) |
Jack wrote:
That works very well for me, too. Get the GPSMAP 76-S, with the barometric sensor and compass. A few bucks more but better altitude readings. Careful, the pressure sensor equipped Garmins don't necessarily provide "better" or "more accurate" altitude, at best, they provide "smoother" altitude readings. Plus, if you get the calibration mode wrong, they can give very poor results... Marc |
Udo Rumpf wrote:
I need help interpreting the 2006 rules regarding the above subject. The rules do not discuss a back up flight recorder. What options exist for a backup flight recorder that would be excepted across the board in US contests for none team use. Udo PS. If you have a used GPS Nav 20 or 25 let me know. You can use an off-the-shelf GPS unit (handheld, or track log capable Bluetooth device) that records GPS altitude as a primary or backup recorder, at any SSA sanctioned contest. You'll need to avoid cutting the start altitude too close, to allow for the fact that GPS altitude may be as much as 500 feet higher than indicated pressure altitude, due to normal pressure altimetry errors. Marc |
You might check with Tom Stowers...he had one at High
Country Soaring for several years. |
Please look at my website "used" pages
http://www.wingsandwheels.com/page8.htm and http://www.wingsandwheels.com/page20.htm I typically have a used CAI loggers and sometimes other types taken on trade. tim Wings & Wheels www.wingsandwheels.com "Udo Rumpf" wrote in message .. . I need help interpreting the 2006 rules regarding the above subject. The rules do not discuss a back up flight recorder. What options exist for a backup flight recorder that would be excepted across the board in US contests for none team use. Udo PS. If you have a used GPS Nav 20 or 25 let me know. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Student Drop-Out Rates...why? | Jay Honeck | Piloting | 254 | September 1st 05 01:00 AM |
| ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 28th 04 12:49 AM |
