A hypothetical situation, and a doubt
Old April 8th 06, 01:37 AM posted to rec.aviation.piloting
Default A hypothetical situation, and a doubt
says...
- which in normal circumstances would've warranted a go-around. Since
you can't do that now with one engine,
Of course you can go-around on one engine. Transport category a/c
are required by regulation to be able to do that.
Correct - Since the OP said "turbine" and "ingestion" we can assume we
are referring to a transport category aircraft, which is indeed capable
of doing the go-aound on one engine (or two, or three - depends on what
an engine-out condition indicates for a given type).
Nevertheless, such situations have given rise to many incidents and some
accidents. Examples : What seemed to be an engine-out condition, due to a
bird strike, turned out to be a both-engines-out condition (due to bird
strike) and the plane did not complete the go-around procedure. OR : In
haste and confusion, flight crew raised gear but not flaps, and the plane
was not able to initiate go around, settled to runway with too little
runway remaining, but was able to stop in available runway due to gear-up
landing - OR : Go-around was initiated, but fuel selection was
inappropriate and plane made forced landing, believing they had a total
power loss.....
In a smaller plane (light twin) the available power is not adequate to
perform a go-around on one engine with adequate safety margins, and you
must get it down, even if you break it. In a transport plane with two
engines, it is perfectly possible, but you must weigh the risk to benefit
ratio, and maximize crew resource management to make sure everything is
done by the book. In a 747 you should hardly notice any performance loss.
GF
Old April 8th 06, 07:22 AM posted to rec.aviation.piloting
GF
I know it isn't what you're saying but if you lose one engine in a
4-engine craft, you don't return but carry on, surely?!
Ramapriya
Old April 8th 06, 03:04 PM posted to rec.aviation.piloting
("Marty Shapiro" wrote)
Only if you are British Airways.
I give them thumbs up for their decision to continue that flight, from
California to England, on 3 engines.
Montblack
Safe does not = risk free.
Old April 8th 06, 03:27 PM posted to rec.aviation.piloting
Regulations require that any failure requires a landing as
soon as reasonably possible. If over the open ocean with no
place close, you still divert and land at the nearest
suitable airport. This may be your departure point, the
destination or some airport along the way.
James H. Macklin
ATP,CFI,A&P
some support
performance loss.
| GF
engine in a
| Ramapriya
Old April 13th 06, 10:52 PM posted to rec.aviation.piloting
Better quote a cite on that one Jim, and surely not ANY failure.
By the way, the 747 is CERTIFIED to fly on 3 and the British Airways ops
manual allows it. In this case, it was an oil pressure problem, and they
did a precautionary shut down.
Even the Minimum Equipt List says "Thou shalt not launch with (device of
choice here)... inoperative"
Al
"Jim Macklin" wrote in message
news:_PPZf.159$8q.140@dukeread08...
James H. Macklin
ATP,CFI,A&P
some support
performance loss.
| GF
engine in a
| Ramapriya
Old April 9th 06, 06:38 AM posted to rec.aviation.piloting
GF
Scuse me.. I'm not a multi driver... let alone a 747 pilot...
but if I lost 25 percent of my power I think that I would notice some
performance loss...
Dave
Strange lost-comm situation Roy Smith Instrument Flight Rules 6 May 4th 04 03:11 AM
Best dogfight gun? Bjørnar Bolsøy Military Aviation 317 January 24th 04 06:24 PM
Japan, U.S. aircraft share 'win-win' situation at Misawa Otis Willie Military Aviation 0 October 11th 03 09:30 PM
Cambridge Aero: Repair Situation Update Chip Bearden Soaring 2 October 2nd 03 06:56 PM
