Q about lost comms on weird clearance
Old January 30th 04, 09:52 PM
Paul Tomblin
Default Q about lost comms on weird clearance
I normally fly out of Rochester NY, which is towered and class C. And 99%
of the time my clearance route is "Vectors as filed". But yesterday I had
to stop off at Batavia to pick up something, and then continue on to
Goderich Ontario. Since it's just easier to be on an IFR flight plan when
crossing the border, I filed from Batavia (Genesee County). When I called
on the RCO to pick up my clearance, instead of what I expected, I got
"Cleared to Geneseo VOR, via direct, climb to 4,000 expect 6,000 one zero
minutes after departure". There was something in there about getting my
filed route later, but I didn't catch the exact wording. The controller
helpfully explained later that they do it that way to head you back
towards their airspace so they can get you radar identified before sending
you towards Buffalo, since Batavia is almost right on the border between
Rochester and Buffalo's airspace. And sure enough, as soon as I got to
pattern altitude and called Rochester, he asked me to ident, and when I
did he gave me the clearance to Goderich "As filed", so it's not like I
went well out of my way.
I think if I ever do that again, and it's good VFR conditions, I'll file
from Buffalo VOR and pick up my clearance in the air on the way there.
But I'm curious about what would have happened if I'd lost contact on the
way to GEE and it had been real IFR. Geneseo VOR was my clearance limit,
so what would I do if I couldn't go back to Rochester VFR? Assume I would
have got my further clearance at GEE, so after I got there squawk 7600 and
head off to Goderich? Hope that my transponder was still working and head
back to Rochester to do the ILS?
"I love the smell of burning components in the morning.
Smells like victory." (The ******* Operator From Hell)
Old January 30th 04, 10:31 PM
I teach to do what is expected if you can. Either do what they tell you to
expect, ie, leave your clearance fix at the expect further clearance time,
or do what you've told them to expect ( your flight plan route) If you'd
have lost radio com once reaching your clearence limit (the VOR), squawk
7600 and then begin the rest of your route. You mentioned that he said
something about getting your filed route later. That's what I'd do while
taking into account all of the altitude requirements.
Jim Burns III
Remove "nospam" to reply
Paul Tomblin
Old January 31st 04, 12:37 AM
Roy Smith
I'm guessing he said something to the effect of "expect filed route".
Another possibility is "expect further clearance at XXXX". Given the
information you supplied, it's a coin toss which :-)
You would have whipped out your laptop, fired up a web browser, and gone
to
http://www.access.gpo.gov/nara/cfr/c...4cfr91_00.html,
where you would have read:
91.185 *IFR operations: Two-way radio communications failure.
(c)(3) Leave clearance limit.
(ii) If the clearance limit is not a fix from which an approach begins, leave
the clearance limit at the expect-further-clearance time if one has been
received, or if none has been received, upon arrival over the clearance
limit, and proceed to a fix from which an approach begins and commence
descent or descent and approach as close as possible to the estimated time of
arrival as calculated from the filed or amended (with ATC) estimated time en
route.
Next, you would have slapped yourself for not paying more attention to
your original clearance and take a guess at whether you had a EFC time
or not, and if you did, what it was. For the moment, let's assume what
the controller said was "Expect filed route after GEE". If so, assuming
your filed route included GEE, you would have flown your cleared route,
climbing to 6000 10 minutes after you took off.
The interesting question is what you do when you get to your
destination. Do you hold until your ETA, or do you just go ahead and
fly the aporoach and land ASAP, as has been espoused so often on this
newsgroup.
What makes it interesting in my mind is twofold: 1) I have no idea if
Goderich is in an area of radar coverage, and 2) I have little
experience flying in Canada. I think I've got a good feel for how ATC
works in the US, and feel comfortable exercising my PIC authority to
play fast and loose with the last sentence of 91.185(c)(3)(ii). I can
only assume that 91.185 is basicly an echo of ICAO procedures and the
rules in Canada are the essentially the same, but I'd personally be more
inclined to play a literal interpretation in Canadian airspace.
Old January 31st 04, 12:49 AM
Paul Tomblin
No, I'm pretty sure there wasn't an EFC.
My filed route didn't include GEE, but I'd filed "Direct BUF v84 YXU ...",
so I guess I would have flown the airway that connects GEE to BUF.
It wasn't. As a matter of fact, the controller turned me loose about 20
minutes before I got to Goderich because his radio repeater near there
wasn't working. Which is about where I entered IMC - kind of strange to
be out of contact with radar, radio and the horizon all at once.
Heaven has all the lusers, a generous supply of larts -
and no PHBs anywhere in sight.
-- The BOFH Heaven, according to Suresh
Old January 31st 04, 01:14 AM
Roy Smith
Seems like a reasonable plan. Going direct BUF would be more in tune
with the letter of how the rule is written, though, since that's what
you filed and were told to expect. On the other hand, in a lost comm
situation, there's a good argument to be made for staying on airways,
since they guarantee nav signal reception and terrain clearance. On the
third hand, if you've got GPS, and are above the OROCA, going direct
seems like the right thing to do.
kind of strange to be out of contact with radar, radio and the
Why? Radar and radio contact with ATC are just conveniences. Neither
is necessary to fly the airplane.
Paul Tomblin
If I'm at GEE, "direct BUF" and "follow the airway between them" is the
same thing.
Hey, I said it was strange (as in "unfamiliar"), not stressful or scary.
Your mouse has moved. Windows NT must be restarted for the change to
take effect. Reboot now? [ OK ]
Old January 31st 04, 02:43 PM
Peter R.
So, in the future, would it be valuable to expect an EFC and ask for
one if you don't receive it? (A sincere question from a low-time IFR
pilot G)
Peter
Old January 31st 04, 04:40 PM
Steven P. McNicoll
"Peter R." wrote in message
pilot G)
An EFC does not have to be issued if no delay is expected.
Old January 31st 04, 05:05 PM
Ross
When given a clearance to a point enroute that is not your destination you
should also receive an EFC - just in case of lost comms - and ask for one if
not provided.
I doubt this would only be a Canadian procedure.
ink.net...
pilot G)
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
Lost comm altitude? Roy Smith Instrument Flight Rules 12 January 11th 04 12:29 AM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 12:40 AM
