![]() mikem wrote: Jonathan, read this http://tinyurl.com/l4rkk Mike M is right. The ripple on the alternator output will be higher rather than lower. Did you measure that you indeed had intercom isolation with the ground disconnected? |
In article . com,
"mikem" wrote: Jonathan, read this http://tinyurl.com/l4rkk Mike, That's very helpful, but unless I'm missing something, I'm not sure that it explains why I'm only having the whine problem on the right side of the cabin (in both front and rear jacks). All jacks are isolated from the airframe, and I'm running a common ground back to the intercom ground. The braided shield is floating at the jack ends and grounded at the intercom ground point. The whine on one side of the cabin would make more sense to me if the jacks were grounded locally to the airframe, but not sure how noise would enter (or exit) the system on one side of the cabin with the intercom system on a single-point ground. Outside of the stuff I've posted to the newsgroup, one other oddity: when I activate the marker beacon output on the audio panel, the whine is more noticeable. Obviously, it sounds like there's a ground problem somewhere, but I don't know where to start. I'm baffled as to why I'm only hearing the problem on one side of the intercom system and not the other, with none of the jacks or PTT switches grounded directly to the airframe. The noise must be alternator-induced, because it is only present when the alternator field is activated. If something was looping through the audio panel or somewhere else, why would it only affect the jacks on one side of the aircraft? JKG |
Jonathan Goodish wrote:
That's very helpful, but unless I'm missing something, I'm not sure that it explains why I'm only having the whine problem on the right side of the cabin (in both front and rear jacks). All jacks are isolated from the airframe, and I'm running a common ground back to the intercom ground. The braided shield is floating at the jack ends and grounded at the intercom ground point. The whine on one side of the cabin would make more sense to me if the jacks were grounded locally to the airframe, but not sure how noise would enter (or exit) the system on one side of the cabin with the intercom system on a single-point ground. I concur. I dont think it is a ground loop issue. I'm thinking a wiring error, or short which occurs only when headphone plugs are pushed in, or an internal fault inside the SPA400. Too bad you dont live close, I would lend you mine to see if it made a difference. Outside of the stuff I've posted to the newsgroup, one other oddity: when I activate the marker beacon output on the audio panel, the whine is more noticeable. Obviously, it sounds like there's a ground problem somewhere, but I don't know where to start. I'm baffled as to why I'm only hearing the problem on one side of the intercom system and not the other, with none of the jacks or PTT switches grounded directly to the airframe. The noise must be alternator-induced, because it is only present when the alternator field is activated. If something was looping through the audio panel or somewhere else, why would it only affect the jacks on one side of the aircraft? The SPA400 drives the pilot headphone jack differently than the other three jacks. Is the problem only on the copilot's jack, or also on the back-seat jacks? I'm puzzled by the "crackle". The alternator whine caused by a ground loop is usually musical, pitch varies with engine speed. Crackles are usually vibration induced intermittent contacts such as an improperly seated audio panel, or nav-com. These usually behave with the engine off, but can be induced by bashing the panel with your hand. Crackle could also mean loose electrical connections to the bus, unshielded P-leads, noisy electric-powered gyro instruments, bad fuel senders, vibrating point mechanical alternator regulator (hopefully yours is solid-state) or a vibration-sensitive Over Voltage Protection Relay. If you have a good DVM, connect it to main bus, and read the voltage prior to engine start, during runup and flight to see if there are any fluctuations which correlate with the crackle you are hearing... |
In article .com,
"mikem" wrote: I concur. I dont think it is a ground loop issue. I'm thinking a wiring error, or short which occurs only when headphone plugs are pushed in, or an internal fault inside the SPA400. Too bad you dont live close, I would lend you mine to see if it made a difference. Well, I rewired the intercom with shielded cable and was pretty darn careful to follow the wiring schematic, and the system does function, so I'm fairly confident that it is wired correctly. However, I do understand that just about anything is possible. Believe it or not, I actually sent the SPA-400 back to Sigtronics a few months ago for them to bench test, and it came back fine. That's not to say that they didn't miss something, as I'm not sure what testing procedure is used. The SPA400 drives the pilot headphone jack differently than the other three jacks. Is the problem only on the copilot's jack, or also on the back-seat jacks? The problem exists ONLY in the right side of the cabin (copilot and right rear passenger.) The pilot side is fine (both front and rear.) You can hear a very, very faint whine on the pilot's side if there is radio silence, but it's almost unnoticeable even with the headset volume set at max. Despite the whine on the copilot side of the cabin, voice quality is still very good throughout the system. I'm puzzled by the "crackle". The alternator whine caused by a ground loop is usually musical, pitch varies with engine speed. Crackles are usually vibration induced intermittent contacts such as an improperly seated audio panel, or nav-com. These usually behave with the engine off, but can be induced by bashing the panel with your hand. Crackle could also mean loose electrical connections to the bus, unshielded P-leads, noisy electric-powered gyro instruments, bad fuel senders, I think I have two incidents of "crackle." One is only present when the landing light is turned on, and I suspect that one of the landing light leads in the cowl is occasionally contacting the muffler shroud. The other one, however, sounds like a "chop chop chop" which increases in speed with engine RPM and is often (but not always) present when the throttle is advanced when positioning onto the runway. It is only heard when the copilot PTT is keyed. It is never heard when the pilot's PTT is keyed. As for the regulator, I'm not sure when solid-state regulators became standard equipment on airplanes, but as far as I know, mine hasn't been changed since the airplane was manufactured in 1977. JKG |
: That's very helpful, but unless I'm missing something, I'm not sure that : it explains why I'm only having the whine problem on the right side of : the cabin (in both front and rear jacks). All jacks are isolated from : the airframe, and I'm running a common ground back to the intercom : ground. The braided shield is floating at the jack ends and grounded at : the intercom ground point. The whine on one side of the cabin would : make more sense to me if the jacks were grounded locally to the : airframe, but not sure how noise would enter (or exit) the system on one : side of the cabin with the intercom system on a single-point ground. The jacks may be a red herring. If they truly are isolated from the structure and grounded only to the intercom, you're right... they *cannot* be causing a ground loop problem. The shield could still be allowing some noise coupling, but I doubt it. As far as the right side/left side stuff, remember that there's a *BIG* current flowing out of the alternator (well, *into* the alternator's ground). That current is just meandering through the structure somehow. It could certainly be more preferential to one side or the other when you're talking a few miliohms total through the structure. : Outside of the stuff I've posted to the newsgroup, one other oddity: : when I activate the marker beacon output on the audio panel, the whine : is more noticeable. Does the *audio panel* run to the same single-point ground as the intercom? If they're spatially separated (especially if one is on port the other's on starboard), it could do what you are describing. Of course *any* chunk of avionics grounded elsewhere could be inducing the ground loop as well. : Obviously, it sounds like there's a ground problem somewhere, but I : don't know where to start. I'm baffled as to why I'm only hearing the : problem on one side of the intercom system and not the other, with none : of the jacks or PTT switches grounded directly to the airframe. Do you have the schematics available for the intercom? I managed to find a set for both of the intercoms I've had in my plane. They generally have different circuitry for the pilot vs. copilot. That might allow for different coupling of the noise. The : noise must be alternator-induced, because it is only present when the : alternator field is activated. If something was looping through the : audio panel or somewhere else, why would it only affect the jacks on one : side of the aircraft? Again, different inputs. It *does* seem a bit odd, but I haven a hard time believing that it's the shield. Again, you're *SURE* that the jacks are floating, right? ... and they don't accidentally contact any chunk of airframe when a jack is plugged in? For the longest time we didn't have side panels in our plane and I just had the rear seat intercom jacks zip-tied to the side. Once in awhile they'd move and rattle against the airframe and make a serious crackle racket in the intercom system. Just a thought. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Have you checked to see that the mike wires are shielded. Ideally the mike
wires should be run in one shielded cable and the speaker wires run in another shielded cable. the shields should be grounded only at the intercom. The pilot and co-pilot wiring run in different areas so an unshielded pilot headset wiring may be OK were as the co-pilot may require better shielding. "Jonathan Goodish" wrote in message ... I have a Sigtronics SPA-400 intercom in my Cherokee. Everything works fine, except that the right seat position has an annoying amount of electrical noise in the headset. It is a high-pitch whine (alternator noise), and the pitch seems to follow RPM. This is not noticable in the pilot's headset, even with the headset volume at full. It is much less noticable in the right seat headset with the headset volume turned all the way down, but obviously this makes things harder to hear for the right seat occupant (often another pilot). In an attempt to rectify the problem, I replaced the intercom wiring with shielded Tefzel cable, replaced all of the jacks, and isolated all of the jacks from the panel with fiber shoulder washers and brought everything back to a single point ground. That helped, but only slightly. I'm trying to figure out what's causing it or, at least, how to stop it on that particular jack. Obviously, the intercom wiring runs adjacent to the electrical buses on that side of the panel, so I'm not sure what role the buses may play, especially since I'm using shielded cable. Does anyone have any ideas? Thanks, JKG |
airplane noise can impair young students | [email protected] | Piloting | 28 | November 7th 05 04:11 AM |
Cherokee Strobe Noise | Jonathan Goodish | Owning | 20 | November 2nd 04 02:42 AM |
Panther C.A.T. headset. | Ross Taylor | Products | 0 | October 22nd 04 11:59 PM |
Funny noise update | Peter Duniho | Piloting | 1 | July 1st 04 02:58 PM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
