Flight planning software
Old April 11th 06, 10:13 PM posted to rec.aviation.piloting
Default Flight planning software
Ross, sorry for the delay in responding.
No, I don't have a problem. However, you have to request the weather
information via the flight planner AND you have to have an account set up
with DUAT. Immediately upon receiving the weather, the NAV LOG should update
automatically. Hope that helps. I will be checking back again and if you
have any question please feel free to ask. If necessary, I do whatever
research I can to help you, but the AOPA flight planner should do everything
you want, with a few exceptions :-).
Harry
"Ross Richardson" wrote in message
Harry,
Do you have any problems with AOPA RTFP giving you a plan without winds.
I cannot make the program use the winds. I can go to the weather tab and
use all the features there. But in the plan flight mode, it just will
not go out and get the winds as necessary. I am working with AOPA on the
issue. Currently, they are stumped. Until then I continue to use Cirrus
5.0 in the internet mode.
Ross
KSWI
Harry Gordon wrote:
I don't know if this is the one you are talking about but you might take
a
look at the one on WWW.LANDINGS.COM . Also, if you are a member of AOPA
they
have one that is not too bad. I use the AOPA one all the time.
Harry
PP-ASEL
San Antonio, TX
"GE" wrote in message
Recently, I found a link to a very simple, yet useful flight planning
sight.
If I recall properly I was able to enter the departure and destination
airports, and it calculated initial heading, distance, etc. I believe
that
I
saw it here. Anybody know what I'm talking about? Thanks in advance for
your
help.
Old April 12th 06, 02:26 AM posted to rec.aviation.piloting
Default Flight planning software SOLVED!!!
I have found the magic decoder ring that makes the AOPA RTFP work
correctly. As folks have said, plan the flight, go to the weather tab
and get the weather, and the nav log and flight plans should update
correctly. Well, they do ONLY if when getting the weather you ask for
FAA weather. You cannot ask for only Plain Language. I clicked on FAA
weather along with the Plain language and it worked. I closed the
application and started all over again with asking for only the Plain
Language weather and the navlog and flight plan did NOT update. Double
clicking on the weather box again I checked the FAA weather and
connected again and the nav log and flight plan worked.
YOU MUST REQUEST THE FAA WEATHER.
Harry
Harry,
Ross
KSWI
a
they
Harry
PP-ASEL
San Antonio, TX
sight.
that
I
your
help.
Regards,
Ross
C-172F 180 hp
KSWI
Old April 12th 06, 02:54 AM posted to rec.aviation.piloting
I have also had problems with Golden Eagle program and have deleted it.
Cirrus continues to work fine. Hope they don't quit supporting it.
Jerry in NC
I have issues with Golden Eagle also that I have worked with CSC and they
turned me to Jepp. Still not resolved. Good ol' Cirrus works so good.
Chris Ehlbeck wrote:
Ross Richardson wrote:
I know I can do that, but according to AOPA this program should pick up
the winds aloft and calculate your flight plan. The "tech" that I have
talked to said it worked fine for him on the same route that I have been
experimenting with.
Ross
Harry,
winds. I cannot make the program use the winds. I can go to the
weather tab and use all the features there. But in the plan flight
mode, it just will not go out and get the winds as necessary. I am
working with AOPA on the issue. Currently, they are stumped. Until
then I continue to use Cirrus 5.0 in the internet mode.
Ross
KSWI
take a
AOPA they
Harry
PP-ASEL
San Antonio, TX
planning
sight.
destination
believe that
I
for
your
help.
Ross,
I saw this somewhere else. Click on the course "line" and then right
click on the course line. You can then pick properties and you can
input the wind data from the briefing. The drawback is that it uses
those winds for the whole flight.
Chris
It seems I've never been able to get it to import the winds automatically
either. Which is why most of the time, I'll use Golden Eagle.
Old April 12th 06, 05:01 AM posted to rec.aviation.piloting
Ross, thank you. After reading your note, I remembered someone a long time
ago had mentioned the same thing. I always request the FAA weather so I
guess I had forgotten about that little inconsistency.
Glad you found the answer.
Harry
"Ross" wrote in message
news:dHY_f.7605$Q92.1640@trnddc04...
up
update
everything
Harry
Harry,
Ross
KSWI
take
a
they
Harry
PP-ASEL
San Antonio, TX
sight.
that
I
for
your
help.
Regards,
Ross
C-172F 180 hp
KSWI
AirPlan Flight Planning Software Update Dean Wilkinson Products 0 October 25th 04 11:22 PM
