Hummel Aviation at Sun and Fun?
Old April 11th 06, 06:45 AM posted to rec.aviation.homebuilt
Default Hummel Aviation at Sun and Fun?
Did anyone see them? Specifically, did anyone see the Ultracruiser
Plus there? I have some detail questions I'm dying to ask.
Old April 11th 06, 08:27 AM posted to rec.aviation.homebuilt
Haven't heard yet.
What kind of questions?
Inquiring minds, and all that...
Richard
Old April 11th 06, 04:22 PM posted to rec.aviation.homebuilt
("cavelamb" wrote)
Did anyone see them? Specifically, did anyone see the Ultracruiser Plus
Haven't heard yet.
I like the Hummels!
Ok, the Hummel UltraCruiser ....PLUS.
(Headroom is always "one" of my concerns - in cars, too. 6-2 ...tall torso)
For those unfamiliar with Morry and his design:
http://www.thayne.us/uc/contact.asp
http://www.flyhummel.com/ucarticle.htm
http://www.hummelbird.com/index.htm
http://www.hummelbird.com/morry.htm
http://www.flyhummel.com/ultra_cruiser_plus.htm
Thought I'd better throw this one in vBg
http://www.ultralightnews.com/sunfun...tracruiser.htm
http://moonsdesigns.com/ultracruiser/
http://www.hummelengines.com/
http://www.flyhummel.com/catalog/index.html
http://www.barnstormers.com/listing.php?mode=usersearch&user=billydee&PHPSESSI D=10f9cfd7361072d8b8
Montblack
http://www.greenskyadventures.com/acforsale/forsale.htm
2005 New Hummell Ultracruiser - Never flown.
It has a Used globel 4 stroke engine, basic insterments, oil pressure, oil
temp, air spd and altimiter. Also has brakes. Would like to swap it for a
single place or 2 place highwing of equal value. I am asking $7.000 us
dollars or best offer. (207) 498-3297 Allen Northern Maine
02/15/06
Old April 11th 06, 08:16 PM posted to rec.aviation.homebuilt
Is this particular aircraft considered an Ultra Light? If so, I think
I might have just found my Colorado project...
Also, what is the max size in the cockpit? They indicate 6 foot and
over 200 pounds...I'm curious how the cockpit could be configured.
Looking through the websites above...thanks in advance, all!
Old April 11th 06, 09:10 PM posted to rec.aviation.homebuilt
It looks like the "UltraCruiser" was made to get by as an ultralight.
You MIGHT be able to call it an UL, but you'd have to grit your teeth.
It's right on the edge of being too fast and too heavy.
It's a 60-80 mph cruise, the UL limit is 55 kts MAX. The lightest
version's listed weight is *exactly* the maximum weight for an UL, the
stall speed is 25-28 MPH and the spec is 24 kts.
The other versions are clearly too heavy and fast.
Old April 11th 06, 09:40 PM posted to rec.aviation.homebuilt
Too bad you're not in Canada. Even the original Hummel
Bird can be registered as an ultralight here. See :
http://www.tc.gc.ca/civilaviation/ge...htm#Definition
An excerpt:
2.1 Definition
A basic ultra-light aeroplane shall be defined as either:
a single-seat ultra-light aeroplane pursuant to Subpart 101, Part 1 of
the Canadian Aviation Regulations;
A two seat instructional ultra-light aeroplanes pursuant to Subpart
101, Part 1 of the Canadian Aviation Regulations; or
an aeroplane having no more than two seats, designed and manufactured
to have a maximum take-off weight of 544 kilograms and a stall speed in
the landing configuration (Vso) of 39 knots (45 mph) or less indicated
airspeed at the maximum take-off weight.
544 Kg = 1198 lb.
Pretty good, huh?
Dan
Old April 11th 06, 08:38 PM posted to rec.aviation.homebuilt
Old April 11th 06, 11:39 PM posted to rec.aviation.homebuilt
You'd fit just fine.
But no, it's not likely going to qualify as a US UL.
Richard
