Supplemental O2 and children
Old April 15th 06, 04:40 AM posted to rec.aviation.piloting
Default Supplemental O2 and children
"Peter R." wrote
I realize that it may be hard to believe, but there are parents who
instill a strong sense of discipline and command a respect for authority,
*especially* when their children ride along in the aircraft.
Good for you. That is what it is all about, and it happens with the little
things in life.
Old April 15th 06, 05:06 AM posted to rec.aviation.piloting
"Peter R." wrote in message
I instill fear... It lasts longer...
Old April 15th 06, 05:49 AM posted to rec.aviation.piloting
I get a tight feeling between my eyes, same as having two
beers when at 25,000 feet without O2. This was same
reaction every time I've been in the chamber at OKC. A
person in good health can do OK at 15,000 for some time if
they are not required to think or do any tasks. Hypoxia is
a cheap drunk for me, but I am peaceful and polite.
The pilot must use O2 any time above 14,000 while it must
only be available for passengers at 15,000. Personally, I
use O2 at and above 10,000 if it is available. At night,
you can notice the difference as low as 5,000 feet.
If you start using O2, leave it on until you're back to a
lower altitude, blood saturation drops very quickly and a
quick shot will bring you UP but it doesn't last unless you
stay on the O2. You can set the O2 regulator to deliver the
required amount of oxygen to maintain the blood at close to
100%, but you must keep it at 95% to stay fully alert. If
you have the available supply, everybody should use O2 at
10-12,000 or above.
The rules for Part 91 are not as tight as Part 135. Make
sure that you explain how to use and why to your passengers
and do a check to be sure everybody is getting their O2
[hoses get kinked, masks not on or sealed, tank empty.]
BTW, an O2 tank should never be run below 100 PSI, keeps all
the gas inside dry and rust free.
James H. Macklin
ATP,CFI,A&P
some support
| Jim Macklin wrote:
| You can have them use O2 when above 15,000 feet, they'll
be
| quieter without it.
| My concern had to do with the other side effects of lower
O2 in their
| blood, as in dizziness, nausea, irritability, etc.
| Peter
Old April 16th 06, 12:20 AM posted to rec.aviation.piloting
"Grumman-581" wrote in
authority, *especially* when their children ride along in the
aircraft.
Nothing works better than Bribery.
Old April 16th 06, 12:43 AM posted to rec.aviation.piloting
"Judah" wrote in message
I would have to disagree... The problem with bribery is that sometimes the
individual won't stay bribed... Fear is a significantly better motivator...
Old April 16th 06, 02:44 AM posted to rec.aviation.piloting
Obviously, above a certain altitude, judgement would be impaired,
however what altitude and exposure time is required for permanent
damage to occur?
Dan
Old April 16th 06, 03:30 AM posted to rec.aviation.piloting
"Dan" wrote in message
damage to occur?
Dan
The answer appears to be "It depends"... Acclimation can make a big
difference. People climb Everest without O2, but they spend weeks
acclimating and I've read different opinions brain damage on them.
Smoking, the altititude you live at, etc. make a big difference when you
fly. Some examples:
http://www.smartcockpit.com/operatio...ompression.pdf
The effects of hypoxia may vary from one person to the next,
depending on the person's health, state of fatigue, state of
physical fitness and how much activity an individual must
perform. (Pilots and flight attendants require more oxygen
during an emergency than typical, healthy, seated passengers.)
Because the eyes and the brain have a high metabolism and
cannot store oxygen, they are most sensitive to oxygen
depletion; the first measurable decline in the body's functioning
occurs in sight, with some loss of night vision at altitudes as
low as 5,000 feet.22 After several hours at 10,000 feet, many
people experience a "measurable deterioration" of their mental
abilities and physical dexterity. At 18,000 feet, the mental
deterioration may be followed by unconsciousness; the TUC
at that altitude is about 15 minutes. At 25,000 feet, the TUC
may be as little as three minutes, and in some situations,
exposure to cabin altitudes of more than 25,000 feet without
supplemental oxygen for more than two minutes might result
in permanent brain damage. At higher altitudes, the TUC
decreases rapidly; at 40,000 feet, for example, the TUC may
be 15 seconds or less.
Other physical effects of decompression include the painful
expansion of gases in body cavities - the stomach and
intestines, the joints, diseased areas beneath the teeth and inside
decayed teeth - and pain in the middle ears and the sinuses
as the body adjusts to the pressure change.19 If the
decompression is slow, one of the early symptoms of hypoxia
is a blue tinge on the lips and under the fingernails; the color
change is a result of the reduction of oxygen in the hemoglobin
of red blood cells.23
see also:
http://ntsb.gov/ntsb/brief2.asp?ev_i...IA093& akey=1
http://www.mos.org/Everest/exhibit/physiology.htm
Geoff
Old April 16th 06, 07:20 PM posted to rec.aviation.piloting
Respect is far better than any of the above...
Old April 17th 06, 12:23 AM posted to rec.aviation.piloting
Respect won't necessarily get someone to do something which they're not
normally inclined to do... Fear will...
Old April 17th 06, 07:31 AM posted to rec.aviation.piloting
"Grumman-581" wrote in message
If your kids are not normally inclined to behave themselves, you've screwed
up.
Granted, lots of parents are screw-ups.
Children as Passengers Kyle Boatright Piloting 19 August 18th 05 06:17 PM
CHILDREN ABUSED AT ABU GHRAIB AS PARENTS FORCED TO WATCH MikeR Naval Aviation 2 March 12th 05 02:47 PM
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 10:46 PM
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 09:45 PM
On topic: A-Bomb necessary? A different approach? old hoodoo Military Aviation 24 December 24th 03 08:58 PM
