#11
Another great one is Met-All. It's a little coarser than Nuvite or
Rolite, but works quicker to take of the "barnacles" that develop over the winter months. A great way to take off the black residue from polishing aluminum is to use a terri cloth towel or one of the car washing mits with corn starch on it. The corn starch REALLY soaks the stuff up. Be liberal with it! Scott wrote: For a GREAT polish on aircraft aluminum try Nuvite. Go to their website for info-- www.perfectpolish.com. You will need a good electric buffer and some tome--but the results are unbelieveable. Skip Guimond |
On 2006-04-20, Papa3 wrote:
The thread on aluminum trailer painting prompted this question. I've seen a number of Blanik L-13s in the "original" factory finish of bare aluminum with blue trim stripes. Be careful what you're letting yourself in for! I used to have a half share in a half polished, half painted Cessna 140. We used Nuvite on ours (it comes in several grades - you start off with a coarse grade and finish with a very very fine grade that also supposedly protects for a while). It was very, very shiny. However, to keep it that way it needed doing once every month to 6 weeks. The aircraft only was polished from halfway down the fuselage, the vertical stabilizer and the flaps. It took 8 hours to get it nice and shiny each time (but I think the result was worth it - it looked beautiful - the finish was like a mirror). I suspect just doing the wings of an L-13 would take at least this long. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
![]() JC wrote: On 20 Apr 2006 07:44:24 -0700, "Papa3" wrote: The thread on aluminum trailer painting prompted this question. I've seen a number of Blanik L-13s in the "original" factory finish of bare aluminum with blue trim stripes. The aluminum is always dull and mottled. Closer inspection suggests that the material is not the typical 2024 surface finish and/or is not Alclad. Has anyone been able to polish one successfully (successful meaning bright and shiny and stayed that way for some time)? Erik Mann LS8-18 (P3) I used 3M Brand Super Duty Rubbing Compound Part # 05954 on my L-13 and L-23. I used an inexpensive electric buffer. After buffing the residue needs to be wiped off with a damp cloth. Worked well and shined up nicely. I did not try to remove scratches with it, just took out the dullness of the finish. Our soaring club has (3) Blanik L-13's and I have found that eagle one wax seems to last the best. I would not recommend using an aluminum polish because the Blanik's are not made with aluminum. The metal used on the Blanik's is DURUAL (Sp?) which has a lot of magnesium in it. There is a clear coat painted over the metal and it is meant to prevent exposing the metal to the elements. Once this coat is jeopardized, the metal will tarnish to the elements in the air. This is not like trying to polish a Cherokee 150 or something similar. You should never rub through this. Of the three Balnik's we have one is painted white and the other two are the original metal. The painted white one seems to always look like it's clean. Tim Adirondack Soaring Saratoga Springs, NY BTW, there is no silicone in the product, so no problems if you choose to paint it later. It is available at any good auto paint supply store. |
Blanik tire problem | Greg Arnold | Soaring | 5 | September 30th 05 06:02 PM |
Blanik L-13 for sale. | JC Cunningham | Soaring | 0 | May 25th 04 01:03 PM |
Is a Blanik L-33 rugged enough for a club? | Val | Soaring | 0 | May 14th 04 02:23 AM |
Is a Blanik L-33 rugged enough for a club? | jeff rothman | Soaring | 19 | May 13th 04 06:17 AM |
Blanik L-23 | Duane Eisenbeiss | Soaring | 8 | April 27th 04 05:53 AM |
