An amphibian that sank?
Old April 23rd 06, 11:25 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Default An amphibian that sank?
"Flyingmonk" wrote in message
http://www.divingservices.net/aircraft.jpg
http://www.divingservices.net/9bcess2.jpg
Anyone have the story behind this? Strange that a plane designed to
float, sank!
You might be surprised how many recreational boats sink. There are dozens
of thing that can happen. Most common are drain plug left out/loose, seals
or hoses leaking and slowly filling the boat.
Old April 24th 06, 12:29 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
The only unsinkable boat I know about is the Boston Whaler
www.whaler.com which is made of two fiberglass shells bonded
together with the inside filled 100% with foamed in-place
resin that makes it one solid boat. They even can be cut
into sections and the still get you to shore with dry feet.
But aluminum floats don't work well with foam inside because
of corrosion between the foam and metal. A better solution
is to fill the compartments with ping-pong balls. They
displace water, don't weigh too much and can be removed for
inspection and corrosion control.
James H. Macklin
ATP,CFI,A&P
some support
"Morgans" wrote in message
designed to
| float, sank!
There are dozens
out/loose, seals
| Jim in NC
Old April 24th 06, 01:19 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
James H. Macklin
ATP,CFI,A&P
Some of the small sail boats also have foam filled compartments with the
same effect. The name MacGreggor comes to mind from years ago, and there
are probably others by now.
Peter
Old April 24th 06, 02:00 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Barf. Never use "MacGregor" and "sailboat" in the same sentence. They are
the most butt-ugly things in the universe.
Old April 24th 06, 02:36 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Roy Smith" wrote in message
there
are
They actually did have a replica of a 19th century pilot boat that I thought
was sort of neat, if less than practical, and commercially it was a dismal
failure. But I really don't like most of their competitors boats very much
either.
Peter
Old April 24th 06, 01:36 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
They are the most butt-ugly things in the universe.
But were not always so. I owned a 1976 MacGregor "Venture 25" that
was a very attractive small boat very similiar in appearance to the
O'Days and Catalinas of the same size.
Bob Moore
Old April 24th 06, 04:56 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jim Macklin wrote:
A better solution
Didn't the "Myth Busters" sink a boat and try to float it again by
filling it with ping-pong balls? If I remember right something on the
boat broke, and all the ping-pong balls spilled out.
Chris W
KE5GIX
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Old April 24th 06, 04:58 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Chris W wrote:
Jim Macklin wrote:
A better solution is to fill the compartments with ping-pong balls.
They displace water, don't weigh too much and can be removed for
They did that experiment on a sailboat they had sunk and it did in fact
bring the sailboat back to the surface.
Old April 24th 06, 05:40 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Newps" wrote in message
Chris W wrote:
Jim Macklin wrote:
A better solution is to fill the compartments with ping-pong balls. They
displace water, don't weigh too much and can be removed for inspection
Well I remember from my younger days when canoe swamps not to worry about
it. We did a test of our own back then. We swamped it so the canoe was
completely filled with water, but upright. Then we started sending people
out there to hang on the side rail and use the canoe to keep their heads out
of the water. We wanted to know how many people it would take to send it to
the bottom, but we never found out. We ran out of space on the side rails
for more people to grab.
Now I strongly suspect that it would difficult if not impossible to do the
same thing with an anphib. They are designed to fly not swamp.
Old April 24th 06, 11:24 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Chris W" wrote
Didn't the "Myth Busters" sink a boat and try to float it again by filling
it with ping-pong balls? If I remember right something on the boat broke,
Yep, a hatch gave way, but they screwed a piece of plywood on it, and then
brought to the surface.
Amphibian VTOL? Flyingmonk Piloting 6 January 6th 06 12:18 AM
Amphibian Aviat Husky Doug Aviation Marketplace 0 November 22nd 04 06:03 AM
Adventure Air Amphibian accident Ed Baker Home Built 3 November 12th 04 01:46 PM
New amphibian aircraft Sten-Anders Fellman Products 0 August 28th 04 11:47 PM
Amphibian down on Mt Kearsarge [email protected] Piloting 2 July 7th 04 11:32 AM
