Ray,
I know (hope) your statement was tongue-in-cheek, but it is worth a comment. Your "spare tire" (or even your six-pack abs) won't prevent you from submarining. Your lap belts must be and stay securely locked down on your pelvis. I have an article from one of the auto racing labs which shows that your pelvis can withstand 5,000 lbs of force whereas the soft organs of your gut will be severely compromised at less than 800. Assuming in a crash that the straps around your middle take 50% of the load (obviously, that will depend on many factors - crash angle, deceleration mode, etc. etc.), that still means that anything approaching an 8g deceleration (maybe less) will be serious trouble. Now, that's an otherwise survivable crash, so it would be a shame to have a problem. Especially in the older, flatter seat pans, it doesn't take an especially creative mind to visualize the submarining that happens without a properly secured lap belt. Erik Mann LS8-18 (P3) |
Erik,
It was, although "butt in sling" or something similar might better "fit" the situation. The whole point of that 5th strap is to keep the lap belts properly positioned on the pelvis and still allow the shoulder belts to be tight. This positioning gives the best control of both vertical and horizontal motion. In the case of a really high g impact in a glider I suspect restraint issues would be moot, however. There's been a lot of research on making high speed racecar crashes survivable; there's both interest and funding for it, very little on GA and only a bit in gliders. The key lessons from Nascar and Grand Prix racing are that a cockpit that maintains its integrety and a restraint system that keeps the driver within that container are good things. Nascar has now mandated a separate head restraint to prevent neck injuries. These measures have made at least some 200 mph crashes survivable. Bringing measures of this kind to gliders would require that we be willing to pay for them, something, according to the DG newsletter, we, as a group, are not willing to do. Ray Warshaw 1LK |
Shoulder straps are supposed to hold you back from moving *forward*. Belly
straps are supposed to hold you *down*. The crotch strap is suppposed to keep the belly straps in position. "Greg Arnold" . wrote in message news:lI83g.3806$_c1.175@fed1read05... wrote: An annoying property of my Ventus 2C is that the safety harness does not hold me into the seat. When encountering turbulance my upper torso leaves the seat and my head ocassionally hits the canopy. The position of the shoulder strap anchors aft of the cockpit is high enough that no downward force is exerted no matter how much the straps are tightened. The only thing this achieves is pulling the buckle up away from my abdomen. Are there any solutions or workarounds for this prollum? (Besides padding my hat?) ~ted/2NO Same problem in my Discus A. There is space between the shoulder straps and my shoulders. |
Properly positioned lap belts control both vertical and horizontal
motion. The shoulder belts keep the torso from pivoting forward and the crotch strap keeps the lap belts in place. Note that the crotch strap need not actually contact your crotch to properly perform this function. My recollection of the racecar research is that, in a reclined seating position, a substantial portion of the force on the shoulder belts is transfered downward and captured by the lap belts. Ray Warshaw |
At 19:18 24 April 2006, wrote:
I have a 4-point system. What's involved with getting a 6-point harness? Ray: how do you reconcile a crotch strap and a pilot relief system? I've never seen a six point for real but this is what's involved: http://www.lukeracing.co.uk/anat.php There's also this company: http://www.willansharness.com/ I think straps 5 & 6 are attached to the same hardpoints as the lapstraps and prevent the buckle from sliding up every time you tighten your shoulder straps. Edward |
I'm going to give this 5th point thing (crotch strap) a try but I'll
have to have the anchor point on the seat pan just below the stick boot around where the factory relief tub hole is drilled. (I made a new hole for that several inches farther aft.) Thanks to everyone who responded by e-mail, I appreciate it very much. ~ted/2NO |
Go to groups.google.com and do a search for the "Glider harnesses, 4
versus 5-point" thread back in 1998. There is some specific information about the pros/cons of various types of safety harnesses and how to modify existing gliders. Chip Bearden ASW 24 "JB" |
| Thread Tools | |
| Display Modes | |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
