PROBLEM down below.
http://www.ainonline.com/Issues/12_0...spectrum_1.htm Story about the Spectrum 33 http://www.spectrum.aero/downloads/m...elim_specs.pdf Specs for the Spectrum 33 Single piece wing .............305 lbs Fuselage ............................309 lbs Engine ................................290 lbs Engine ................................290 lbs Total so far ......................1,194 lbs Everything else [S-33].....2,426 lbs Empty Weight ................3,620 lbs Single place, single engine MontJet: [Based on the Spectrum 33 numbers] Wing .........................45 lbs Fuselage ..................45 lbs Jet engine ..............200 lbs? Everything else ........60 lbs MontJet Empty Wt .350 lbs (Double the Empty Weight of the Cri-Cri) PROBLEM: I only allowed 60 lbs for "Everything else". Granted the S-33 is a 10 place jet vs the single seater MontJet. Still, their "everything else" is DOUBLE the weight of their wings+fuselage+engine(s). The MontJet "everything else" is only 1/5 (21%) the weight of the wings+fuselage+engine. Hmm.....? Montblack (Fire in my ...belly!) Here comes the rich man in his big long limousine Here comes the poor man all you got to have is green Here comes the banker and the lawyer and the cop One thing for certain it ain't never gonna stop When it all gets too heavy That's when they come and go With only one thing in common They got the fire down below" "Fire Down Below" Bob Seger - Night Moves (1976) |
![]() "Montblack" wrote in message ... PROBLEM down below. Single place, single engine MontJet: [Based on the Spectrum 33 numbers] Wing .........................45 lbs Fuselage ..................45 lbs Jet engine ..............200 lbs? Everything else ........60 lbs MontJet Empty Wt .350 lbs (Double the Empty Weight of the Cri-Cri) I see ur problem, and I'm shocked you didn't catch it! That 200 pounds for engines is way too high! You should have substituted a couple of Rotax engines, for those. g What comes around, goes around. ;-)) -- Jim in NC |
("Morgans" wrote)
That 200 pounds for engines is way too high! You should have substituted a couple of Rotax engines, for those. VL"J" ...Hello. They're not talking about "Jets" in the carb! g What comes around, goes around. ;-)) I thought that was your issue with the Rotax all along - that it doesn't always come back around. chuckle Anyone out there with a PROVEN jet engine, with a fuel burn under (Spectrum's per engine average)27 gph, that puts out 800-1,200 pound-thrust, and weighs under 200 lbs? 15-20 gph* would be nice. (* For 2 to 4 hour trips at 35,000-45,000 feet. Shorter trips will burn more) Otherwise: Williams FJ33-4A [1,568 pound-thrust] @ 290 lbs it is. I feel so much like the Eclipse team, right now, it's scary! :-) http://www.spectrum.aero/downloads/competitive_analysis.pdf Competitive analysis Spectrum 33 vs. other Jets. 2 engines and... "4 passengers, NBAA IFR Reserves" [300 nm] 617 lbs. is 84.1 gal ....0 hr+53 (53 min) = 99.6 gph/2 engines [600 nm] 688 lbs. is 98.3 gal ...1 hr+41 (101 min) = 58.2 gph/2 engines [1000 nm] 1,096 lbs. is 156.6 gal ....2 hr+50 (170 min) = 55.2 gph/2 engines [1,600 nm] 1,647 lbs. is 235.3 gal ....4 hr+35 (275 min) = 51.6 gph/2 engines Team MontJet |
and just for "fun", how much would be the cost of a FJ33 ?
Montblack wrote: PROBLEM: I only allowed 60 lbs for "Everything else". Granted the S-33 is a 10 place jet vs the single seater MontJet. Still, their "everything else" is DOUBLE the weight of their wings+fuselage+engine(s). The MontJet "everything else" is only 1/5 (21%) the weight of the wings+fuselage+engine. Hmm.....? A) helium-filled inserts in the wing? B) install only a pilot that is equipped with a large supply (self-contained) of 'hot air'. |
Robert Bonomi wrote:
B) install only a pilot that is equipped with a large supply (self-contained) of 'hot air'. No no...not the pilot, the OP! Plenty of overly warm, dare I say hot? Why yes, hot indeed...air. :-) -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
("Jack Allison" wrote)
No no...not the pilot, the OP! Plenty of overly warm, dare I say hot? Why yes, hot indeed...air. :-) With a ceiling of 45,000 ft ...no [ride ABOVE the] soup for you! g Team MonJet |
Montblack wrote:
With a ceiling of 45,000 ft ...no [ride ABOVE the] soup for you! g Team MonJet Hey, wait...am I not a founding member and supporter of the MontBlack fan club? One (well, ok, maybe two...er...um...plus a few more) itty bitty comments and I'm booted off the plane (before the plane is even *on* the drawing board. Who died and left you CEO? :-) Besides...flying in the soup, so long as it's not turbulent, no embedded T-storms, no ice, is fun...in that twisted instrument flying sort of way. Ok, ok, so I beg forgiveness and start out as your web master. -- Jack Allison PP-ASEL-Instrument Airplane Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
Who died and left you CEO? :-) Speaking of, I wonder if BRS makes Golden Parachutes? http://www.brsparachutes.com/default.aspx Located in South St Paul, MN ...at the airport. "Team" MontJet |
MontJet update | Montblack | Piloting | 18 | May 1st 06 10:54 PM |
New info on MontJet numbers | Montblack | Home Built | 2 | April 24th 06 09:41 PM |
New info on MontJet numbers | Montblack | Piloting | 2 | April 24th 06 09:41 PM |
Latest Windows vulnerability UPDATE | john smith | Piloting | 1 | January 6th 06 08:43 PM |
8th Anniversary : Kiwi Aircraft Images Update | Phillip Treweek | Military Aviation | 0 | August 13th 04 01:45 AM |
