Vector altitude for ILS below GS intercept altitude?
Old May 3rd 06, 02:48 AM posted to rec.aviation.ifr
Default Vector altitude for ILS below GS intercept altitude?
On 05/02/06 15:43, M wrote:
The clearance came well outside the approach fix, but at an altitude
below the GS intercept altitude on the IAP. It's also below the GS
altitude at the marker. The problem with this clearance is there's no
way I can verify my altimeter as I cross the marker. Normally on
during an ILS approach, we're suppose to check the altitude on the GS
as we cross the marker, and make sure it agrees with the GS altitude
over the marker printed on the IAP. This is an important crosscheck of
the altimeter settings.
Well, once you were cleared for the approach and established on the
initial approach segment, you can fly the altitudes published for
the approach - so couldn't you have climbed to 2100'?
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old May 3rd 06, 04:27 AM posted to rec.aviation.ifr
I guess. That would be a very odd way of flying an ILS.
Old May 3rd 06, 09:44 AM posted to rec.aviation.ifr
Robert M. Gary wrote:
Hey Steveo, define the word "required" in the context of FAA ATC. Does
it appear anywhere near "slam dunk" in your secret dictionary?
In my experience, when you get a slam dunk approach they don't clear
you for the approach but just tell you 'intercept the loc, decend
maintain 1,500". Once you are below the GS they clear you for the
approach.
-Robert
My experience has been different than your's.
Old May 6th 06, 12:11 AM posted to rec.aviation.ifr
"M" wrote in message
Is it common for the approach controller to vector for an ILS at an
altitude below the GS intercept altitude on the IAP? Today is the
third time in the last year or so that Victoria terminal vectored me
for the ILS into BLI at 2000 feet, instead of 2100. I'm very familiar
with the area and I did not bother to question them.
The Canadian controllers provide approach service for Bellingham
probably from an agreement between FAA and NavCanada. Maybe the rules
are somewhat different in Canada, or they just don't have the right
information on this approach?
See http://204.108.4.16/d-tpp/0604/00045I16.PDF
As has already been pointed out, FAAO 7110.65 5-9-1b requires US controllers
to vector "For a precision approach, at an altitude not above the
glideslope/glidepath or below the minimum glideslope intercept altitude
specified on the approach procedure chart."
So...
What was your assigned altitude prior to receiving the approach clearance?
Above 2100 or level at 2000?
If above 2100, what was the wording of the actual approach clearance? Any
"at or above" or other wording that would allow you to adjust your descent
to intercept the GS at the "altitude specified on the approach chart" rather
than level at 2000?
It could also be as simple as the MVA in that area is 2000 and the
controllers simply assign the round thousands MVA as a routine. They either
don't know or don't care (given the allowable error in altimeters and Mode
C) that they are supposed to add that extra 100ft for ILS approaches.
Old May 10th 06, 11:50 PM posted to rec.aviation.ifr
"Sam Spade" wrote in message
news:zI15g.174918$bm6.107215@fed1read04...
It means ya gotta do it.
Does it appear anywhere near "slam dunk" in your secret dictionary?
Secret dictionary?
Old May 11th 06, 02:25 PM posted to rec.aviation.ifr
nk.net...
Secret dictionary?
I'm afraid, Samo, you will have to show us where "slam dunk" is used by the
FAA in any of their publications.
Old May 20th 06, 12:00 AM posted to rec.aviation.ifr
Here is a common occurance at TPL, Temple, TX which I use
as a way of teaching students how to stay ahead of ATC:
We are VFR doing practice approaches and being vectored
for an ILS to RWY 15. Usually this results in being vectored
to the west side of the airport and told to maintain 3000'. At
about 8 miles out, the final clearance goes something like this:
"Cessna xyxxz, you are 5 miles from the outer marker, turn right
heading 120 to intercept the localizer, maintin 3000 until established,
cleared for the ILS approach to runway 15 Temple."
Normally, by the time the localizer needle comes off the peg,
we have already flown trhough the glideslope and are well above
the glide slope at this point. The MVA in that area (according to
one controller) is 2600', but they routinely keep you at 3000' usless
you ask for lower. The glide slope intercept altitude is 1700'.
I tell my students to expect this, but the first couple of times it happens
to
them they always seem to get behind, don't ask for lower and/or end up
failing to decend soon enough to recover. Makes for a nice game of
catch-up as they try to get back on the glide slope. After a couple of
times, they wise up and either ask for lower before being given the
approach clearance, or they are spring loaded and ready to descend
once the localizer needle gets within 3/4 scale deflection.
Ronnie
"KP" nospam@please wrote in message
controllers to vector "For a precision approach, at an altitude not above
the glideslope/glidepath or below the minimum glideslope intercept
altitude specified on the approach procedure chart."
So...
rather than level at 2000?
either don't know or don't care (given the allowable error in altimeters
and Mode C) that they are supposed to add that extra 100ft for ILS
approaches.
Old May 20th 06, 01:00 AM posted to rec.aviation.ifr
"Ronnie" wrote in message
. com...
happens to
Have you ever asked them why they assign altitudes to VFR aircraft?
Old May 20th 06, 01:27 AM posted to rec.aviation.ifr
On 5/19/06 8:00 PM, in article
t, "Steven P. McNicoll"
. com...
happens to
I assumed that they are in VFR conditions but on an IFR plan.
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
Old May 20th 06, 05:39 PM posted to rec.aviation.ifr
No, I have not asked, but I think it is because of tihs.
This facility is Gray Approach, an army ATC
facility that handles Gray Army Airfield and other military
airfiields associated with Forth Hood. In general, the controlers
treat all traffic, inlcuding VFR trafic, like IFR traffic unless you
continue to remind them that you are VFR. I usually don't bother
because I'm interested in letting my instrument students experience
the IFR handling, even if we are VFR.
Ronnie
nk.net...
. com...
happens to
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
GPS Altitude with WAAS Phil Verghese Piloting 38 October 5th 03 12:39 AM
