Piper SB1161/rib replacement update
Old April 30th 06, 12:34 AM posted to rec.aviation.owning
Default Piper SB1161/rib replacement update
Updated pictures he
http://s66.photobucket.com/albums/h2...ardrider/Ribs/
Right wing is done. Left wing top rivet work is done and bottom rivet
work is in progress. Should be airworthy before the end of next week.
GNS-430 is back from Garmin (had to comply with an AD and get a hardware
& software update done).
Cheapest part installed on the plane to date: $6 luggage door strap from
Ground Tech. Has absolutely nothing to do with the rib repair...but
it's nice to know that not *everything* costs an arm and a leg. Well,
ok, nearly everything...but at least not a luggage door strap.
Jack Allison
PP-ASEL-Instrument Airplane
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Piper SB No 836 (alluminum wire replacement) Mike Noel Owning 11 August 3rd 05 09:05 AM
Rogue's Gallery Update -- Talk about diversity! Jay Honeck Home Built 52 May 11th 05 06:18 PM
Rogue's Gallery Update -- Talk about diversity! Jay Honeck Owning 51 May 11th 05 06:18 PM
Rogue's Gallery Update -- Talk about diversity! Jay Honeck Piloting 52 May 11th 05 06:18 PM
replacement rotating beacon for 64 piper cherokee Patrick Mathews Owning 2 October 1st 03 02:55 PM
