Does an IPC count as a BFR?
Old March 12th 04, 06:59 PM
Mike Z.
A buddy of mine actually got his II and had no intention of getting his CFI. He since relented but that is another story.
Mike Z
"Brad Z" wrote in message news:gTl4c.16400$bP2.83279@attbi_s53...
If your flight instructor certificate only has a "instrument-airplane"
rating (i.e. no airplane single engine or Airplane multi engine)
news:wgb4c.9456$bP2.70125@attbi_s53...
Not all CFII's can give BFR's.
You've lost me there. Why not?
Old March 13th 04, 02:50 AM
C J Campbell
That is one of the most bizarre things I have ever heard, and that despite
the fact that I have been reading the news groups for years.... :-)
Why on earth would any instructor do that, and how could he possibly do any
CFII instruction in an airplane that he is not allowed to give instruction
in?
Old March 15th 04, 02:31 PM
Dave Butler
C J Campbell wrote:
"Michael" wrote in message
om...
wrote
In a similar vein, does an instrument checkride count as a BFR? I
thought it did since it added a rating to the ticket.
It does. However, an instrument instructor ride does not - even
though it is the same ride (only from the right seat).
Of course there's no reason for it - it's just our policy.
It may be your policy, but it does not really follow the regs. Yes, I know
the argument that the instructor certificate is not a pilot certificate, but
it sure gets treated as a pilot certificate for all other purposes. I also
know that the policy varies from one FSDO to another. I also know that most
examiners will sign the ride off as a BFR if you ask them to do that.
Isn't there a requirement, or a guideline, or something, that the BFR should
include an hour of ground instruction? Seems like I've had that requirement put
on me by instructors on the last few BFRs. The time is spent
grilling^H^H^H^H^H^H^H^H instructing me on the FARs. I don't remember ever
having any ground instruction component as part of an IPC.
Dave
Remove SHIRT to reply directly.
Old March 15th 04, 04:06 PM
Michael
Actually, it varies from one inspector to another.
Not too long ago, we had a jumpship crash. The pilot did all the
right things, but when the engine of a heavy single fails in the climb
at 400 ft, you just don't have many options. The field was wet and
rough, and there was substantial damage but no injuries. The accident
was reported, and the investigation delegated to the FAA. The pilot
made the mistake of noting that he never seems to hear of automobile
engines having catastrophic failures, but certified airplane engines
fail with depressing regularity. Next thing you know, he's written up
for flying with an expired BFR - enven though he had taken his CFII
ride only a few months ago. Your tax dollars at work.
That's another gray area, worse than the original.
61.56 Flight review.
(a) Except as provided in paragraphs (b) and (f) of this section, a
flight
review consists of a minimum of 1 hour of flight training and 1 hour
of ground
training.
The FAA is pretty adamant that a checkride is not instruction.
Personally, I don't understand why the instructor doesn't just sign
the BFR. There's no way I would be comfortable signing someone off
for a CFI ride and not willing to sign off a BFR.
Michael
Old March 15th 04, 05:27 PM
Richard Kaplan
om...
What is the relationship between this statement and his being written up?
Richard Kaplan, CFII
www.flyimc.com
Old March 15th 04, 08:12 PM
Dale
In article m,
om...
Wondered that myself. If this is the incident I think it is, the pilots
problems probably stem from him having a bunch of water in the fuel,
which appears to have caused the loss of power.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old March 15th 04, 11:18 PM
Michael
Oh, I'm guessing the inspector took it as a slight against the FAA -
the implication being that FAA certification hasn't actually made our
airplanes any safer, and in fact has retarded progress. Thus he
decided to teach this pilot with a 'bad' attitude a lesson. Happens
more often than you might think.
Michael
Old March 16th 04, 01:49 AM
Mark Kolber
On Fri, 12 Mar 2004 18:53:55 -0800, "C J Campbell"
but
"All?" I have never seen even one FAR that =does= treat a CFI
certificate as a pilot certificate.
From a pure regulation standpoint, the FAR treats instructor
certificates separately from pilot certificates. Staring with
§ 61.1 Applicability and definitions.
(a) This part prescribes:
(1) The requirements for issuing =pilot, flight instructor, and ground
instructor certificates= and ratings; the conditions under which those
certificates and ratings are necessary; and the privileges and
limitations of those certificates and ratings.
(2) The requirements for issuing =pilot, flight instructor, and ground
instructor= authorizations; the conditions under which those
authorizations are necessary; and the privileges and limitations of
those authorizations.
(3) The requirements for issuing =pilot, flight instructor, and ground
instructor= certificates and ratings for persons who have taken
courses approved by the Administrator under other parts of this
chapter.
The differentiation continues throughout the FAR and general FAA
policy with amazing consistency, from medical certificate requirements
(a CFI doesn't need one unless he's also acting as PIC) to the
requirement to have each certificate available when exercising that
certificate's privileges to the requirement that, in order to teach in
an aircraft, a CFI must have both "A pilot certificate =and= flight
instructor certificate with the applicable category and class rating"
(61.195(b)(1).
There may be an FAR that =does= treat the flight instructor
certificate as a pilot certificate, but so far anyway, I haven't seen
one.
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 02:51 AM
Zzzz Campbell's Second Lawsuit Against Sun-N-Fun Zzzz Ron Wanttaja Home Built 23 October 6th 03 02:09 PM
Aerial duel to the death - count to ten then Fire! pac plyer Home Built 18 August 12th 03 12:35 AM
